T72o Almost dead HELP!! Frist of all,hi to everyone and sorry for my english... Today i tryed to upgrade the software of my t720 with VictorGSM 3.2.3,it seemed that the procedure was ok but when i try to turn on the phone the screen blink for 1 second(only the on/off buttob seem to do some effect on the phone). When i connect the phone to pc via USB cable for a second the system find an "Unknowed USB Device" that suddenly disapper. now i read a lot of topic over internet (even on this forum)but don't understand what to do. I try to short the 13 and 14 pin(is the meaning of short join?)and what i resolve is that now sometime the "unknowed USB device" remain and windows found it but either PST nor VictorGSM find the phone.... What i have to do?Can you post a complete procedure for me and for the others many unlucky person who are in a such situation Plese Help me :confused: tnx in advance |
Helpppp Plz Help, pheraps i don't short porperly the pins 13and14, Can you esplain me how to do. Do i have to open the cable? |
The way I did it is to take the phone end apart and soldered a small wire from 13 to 14. Just plug it into the phone and press the power button on the phone, then you can plug the cable into computer or use a different cable. It works, but I'm still having problems with the flexing part. Maybe I have the wrong flash/flex combo for my phone. Good luck! |
tnx but is this the right numeration: |1|2|3|_|4|5|6|7|8|9|10|11|12|13|14|15|16|17| and you solderd the pin from the internal of the cable or properly the external pins? tnx again |
ok but.... Ok. i short the 13 and 14 pin and succesfully flashed the phone and now it is correctly found by windows as Motorola USB modem but now when i turn on the cell the display remain black(but illuminated) and when i try to flex the phone with VictroGSM it say me "Access violation error at 000000036.Read error at 0000000036"(the number change beetween 000000000 and 0000000XXX).With Pst it say me impossible to suspend the phone. I have the Downgrade Pack Plese HELP tnx in advance |
ok man wen i short 13-14 and pres on flash model search the are no p2k devic but wen i short 4-5 p2k devic fund |1|2|3|_|4|5|6|7|8|9|10|11|12|13|14|15|16|17| 1-2-3 is for charge thank u 4 explane me |
im glad to help you but what i need to know is how to flex now i flashed the phone and it is ok now but the screen is black Do yoy have some solution? |
Are you using windows XP? If so, try with windows 2000 or 98, happened the same to me while trying to read phone info on victor 323, but with windows 2000 got OK. |
THANK YOU MANS I use windows 98 and now,after 24 hours of agony the phone ia already alive....Yahooo If someone need something i will be glad to help him!!! P.S: Now i want to upgrade my T720 to T720i or T722i(in Italy its called New look)Can you tell me how version of Flash and flex i have to use,if possible in italian,and logically unlockes! BYE and TNX AGAIN |
may be u wont kill ur phone forewer?:D :D :D |
