v180 won't unlock HELP! I have an older v180 that I was able to unlock fine using moto unlocker, but my dad just got a newer v180: Flash Version: R365_G_0B.D2.2ER Flex Version: GSIV180M0CIN04NA16D_1FF Bootloader:07.B0 and I can't seem to unlock it with any software. I tried motounlocker, all the PDS editors I could find and I even tried chfaken, but no luck! Any ideas on what I can do? Thanks for the heads up. |
[QUOTE=canja]I have an older v180 that I was able to unlock fine using moto unlocker, but my dad just got a newer v180: Flash Version: R365_G_0B.D2.2ER Flex Version: GSIV180M0CIN04NA16D_1FF Bootloader:07.B0 and I can't seem to unlock it with any software. I tried motounlocker, all the PDS editors I could find and I even tried chfaken, but no luck! Any ideas on what I can do? Thanks for the heads up.[/QUOT Downgrade to R364 use chfaken or motorola unlocker 2005 to unlock then upgrade it back with a none locking R365 MP or reflash |
...know where I can get a unbranded R365 (that won't lock my phone backup)? Thanks. |
downgrading is a dangerous because if you stop when flashing or if you put wrong flash file, phone will be dead. use smart clip 100% safe 100% efficient good luck |
I don't have a smart clip :( ... I guess I will risk it since it's now "backup" phone. I just got a new v551. I will keep you posted! |
just insert a travel charger... and unlock whit SC, or software... |
I tried downgrading to r364 and running the motounlocker and it all went smoothly, but when i put in the sim card the phone still ask me for a subsidy code! :( Any thoughts? |
so it is not unlocked. I had problems like this with v180/v220. Turn on phone, plug smart-unlocker to phone, Press unlock, wait til it puts in the flash mode and let it do its stuff. After the flash mode is gone, phone should off so you need to turn on the phone manually right after phone turns off and let it work. Post the results. |
dest I don't have a smart-unlocker; i'm using a usb cable and motounlocker.exe software.... but I still can't unlock the phone! :( |
mybe you can damage your moto if you test it in many craked soft its' time to bay smart-clip and all wil fixed |
