Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola P2k
Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200
C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980
E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070
P-Series: P280
T-Series: T280,T720,T721i,T722i
V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050.
other-Series: like L6,L7,U6.
Old 06-11-2004, 23:58   #1 (permalink)
Member: 68707
Question Using serial port in T720i
Hello,
I am working in a project that needs to use one barcode reader connected to celular by serial port or USB.
I am using a program in Java to receive this data and the terminal choosen,following instructions, was Motorola T720i, and I am using RS-232.
According Motocoder instructions, to do it works I need to :
- open connection in Java
- send from device
AT
At+mode=19
I emulate this in two ways:
1) using hyperterminal
2) wroting a program to do this from PC
( I am sure that cable is working fine, since I received answer from At commands )
But after send the last command ( I can heard one sound in the celular side ),
in both cases I can't send anything more ( hyperterminal freeze ) or either get anything in Java side.
Does anyone know what I need to do ? What is wrong ?
( I am thinking that may be that this model cannot accept this kind of implementation - If it is right, is there other celular phone that I can do this ? )
Regards
Paulo S
[IMG] code is Off
Serial Port in VB .NET 2008 Dave.W GSM Programming & Reverse Engineering 68 08-15-2022 20:06
Problem Serial Port in Widcomm 5.1.0.1100 Nuker5 Bluetooth-Software 3 07-04-2006 12:45
Unlocking using WinIMEI 1.16 and no serial port or cable. It really works!!!! JasonD QUALCOMM Models (3G) 3 06-09-2006 11:35
out serial port to upgrade t610 using flashing gold kencash Sony Ericsson 0 01-10-2004 17:33
Serial Port error using Cb2000 BbOyPoLo69 Panasonic 3 09-17-2003 03:50
Page generated in 0.17957 seconds with 10 queries
