Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola ODM
Motorola ODM
  • BENQ(Acer): C113,C139,C168,C200,C205,C300,C257,C261, T205,T2688,T190,T191,V171,V290
  • CHIMEI: MPX200, MPX220, MPX300, V690, V878
  • COMPAL: E360, E365, MPX100, C115, C155
  • Reply
    Old 07-04-2008, 16:11   #1 (permalink)
    Member: 806861
    Thanks Meter: 92
    Exclamation New Version 9.2.17 C139 Trafone Firmware Dump!!! UNLOCKED!
    Here is the FULL Memory DUMP of the Firmware;
    BOOT.90.04
    Lets get together and figure this out..
    Or Contact that LAWYER GUY.. From Last Software he published..
    Here is some code I found in file..
    #02#
    *#06#
    **16379#
    *#15284#
    #09#
    *#23220#
    *#23221#
    *#23222#
    *#2317#
    *#23100#
    *#23101#
    *#23102#
    **0102#
    #090#
    #08#
    #88#
    #00000#
    #00#
    **0101#
    #78#
    #03#
    #04#
    **0108#
    **0105#
    **0109#
    **16378#
    *#33248#
    #55#
    #11#
    #22884646#
    #22#
    #10#
    *#2061#
    *#2062#
    *31#
    #31#
    *333? ÀF#333? ÀF*#333? À*332? ÀF#332? ÀF*#332? À*#331? À*331? ÀF#331? ÀF*#330? À*330? ÀF#330? ÀF*33? ÀFÀ#33? ÀFÀ*#33? ÀF*353? ÀF#353? ÀF*#353? À*351? ÀF#351? ÀF*#351? À*35? ÀFÀ#35? ÀFÀ*#35? ÀF*03*333? ÀFÀ*03*332? ÀFÀ*03*331? ÀFÀ*03*330? ÀFÀ*03*33? *03*353? ÀFÀ*03*351? ÀFÀ*03*35? *03*? ÀF**03*333? ÀF**03*332? ÀF**03*331? ÀF**03*330? ÀF**03*33? ÀFÀ**03*353? ÀF**03*351? ÀF**03*35? ÀFÀ**03*? À**042? À**04? ÀF**052? À**05? ÀF*77742? #77742? *#06# ÀF*002? ÀF#002? ÀF**002? À##002? À*#002? À*004? ÀF#004? ÀF**004? À##004? À*#004? À*21? ÀFÀ#21? ÀFÀ**21? ÀF##21? ÀF*#21? ÀF*67? ÀFÀ#67? ÀFÀ**67? ÀF##67? ÀF*#67? ÀF*61? ÀFÀ#61? ÀFÀ**61? ÀF##61? ÀF*#61? ÀF*62? ÀFÀ#62? ÀFÀ**62? ÀF##62? ÀF*#62? ÀF*#31# ÀF*#30# ÀF*30# ÀFÀ#30# ÀFÀ*#77# ÀF*77# ÀFÀ#77# ÀFÀ*#76# ÀF*76# ÀFÀ#76# ÀFÀ*43? ÀFÀ#43? ÀFÀ*#43? ÀF*55# ÀFÀ#55# ÀFÀ#*91*0# #*91*1# #*43*0# #*43*1# #*88* ÀF*1# *1*0# ÀF*1*1# ÀF*1*4# ÀFMANUAL ÀAUTO ÀFÀSPLMN ÀF*#77742#
    #02#
    #06#
    **16379#
    *#15284#
    #09#
    *#23220#
    *#23221#
    *#23222#
    *#2317#
    *#23100#
    *#23101#
    *#23102#
    **0102#
    #090#
    #08#
    #88#
    #00000# #00#
    **0101# #78#
    #03#
    #04#
    **0108#
    **0105#
    **0109#
    **16378#
    *#33248#
    #55#
    #11#
    #22884646#
    #22#
    #10#
    *#2061# *#2062#
    Old SW to unlock
    http://rapidshare.com/files/127072426/mot931c.rar.html
    U MUST USE THE USB T191 CABLE!!! NOT SERIAL..
    Here is the Memory Dump for the New UART Locked phone..
    http://rapidshare.com/files/12707067..._C139.rar.html
    Including the BOOT OF THE NEW C139 is in the file..
    AND EVERYTHING ELSE!!
    HAPPY PATCHING!!!
    The Following 6 Users Say Thank You to dump101 For This Useful Post:
    Old 07-04-2008, 16:40   #2 (permalink)
    Member: 806861
    Thanks Meter: 92
    New Version 9.2.17 C139 Tracfone Firmware Dump!!! UNLOCKED!
    FFN_C139_TP_T0H
    LPN_C139_NA_T0H
    SJUG3757CA
    prepaidEnable
    redeemAirTime
    The Following User Says Thank You to dump101 For This Useful Post:
    Old 07-05-2008, 00:18   #3 (permalink)
    bananin's Avatar
    Member: 150844
    Thanks Meter: 309
    How are you make dump/write for this phone??
    Old 07-05-2008, 03:53   #4 (permalink)
    Member: 220595
    Thanks Meter: 355
    sso, what tool should one use to write this file ?
    Old 07-05-2008, 04:02   #5 (permalink)
    rico_deep's Avatar
    Member: 159757
    Thanks Meter: 461
    can you upload it to other uploaders......we have a ploblem with rapidshare specially during peak hours....thanks and more power..
    Old 07-05-2008, 04:13   #6 (permalink)
    WeBoXGT's Avatar
    Member: 628110
    Thanks Meter: 87
    how to use this file?
    Old 07-05-2008, 06:46   #7 (permalink)
    Member: 621698
    Thanks Meter: 405
    Originally Posted by dump101 View Post
    FFN_C139_TP_T0H
    LPN_C139_NA_T0H
    SJUG3757CA
    prepaidEnable
    redeemAirTime
    I have this kind of C139 and Can you tell us how can we unlock it? thank you and where to get the files.
    Old 07-05-2008, 07:11   #8 (permalink)
    newfoundghori's Avatar
    Member: 575597
    Sonork: 100.1590575
    Thanks Meter: 559
    bro other link plsssss.....link not working.....
    Old 07-05-2008, 10:22   #9 (permalink)
    Member: 637625
    Thanks Meter: 39
    hello 139 sim not viliet
    Old 07-05-2008, 10:26   #10 (permalink)
    Member: 621698
    Thanks Meter: 405
    C139 tracfone
    SW: 9.2.17
    FLAG: 1
    is this included to be unlock now?
    hows the procedure?
    Thank you in advance.
    Old 07-05-2008, 10:43   #11 (permalink)
    Invisible's Avatar
    Member: 3956
    Sonork: galletto3 rules :D
    Thanks Meter: 55
    hi
    obviously some have to dissamble file, find simlock check and patch it,
    I assume file is Srecord from motorola,
    (S3220000002058501B0000FBFFFFB4179FE5B000D1E120008 0E3B000C1E11C101FE5A1AA) will be first unlock block
    flashing patched file will unlock the phone,
    same that old T191 phones,
    best regards
    Invisible
    Old 07-05-2008, 15:31   #12 (permalink)
    Member: 621698
    Thanks Meter: 405
    I'm sorry but probably all of us here are having trouble to use this unlocking method. Is there anyway you can tell us what is the procedure on unlock it. thank you
    Old 07-05-2008, 22:34   #13 (permalink)
    mrfixit's Avatar
    Member: 60899
    Thanks Meter: 792
    somebody patch it and upload soon
    Old 07-06-2008, 00:11   #14 (permalink)
    Member: 17362
    Thanks Meter: 242
    c139
    Some one needs to reverse this file
    Listen guys... This file has to be reversed to find out how they locked
    the UART or kill the boot like the old version..
    Simlocks is NOT the issue!Its the Communication port "UART FLAG set to 1" is the problem
    Figure it out so you can Flash default it..
    MSSBOX uses different boot process access and partially
    Flash the boot section to kill the boot section.. OR the other option is if
    TFLAWYER guy to reverse this file andadd this to his program..
    I found more liinks Here is the C139 Uart Locked file below;
    *********.mega.$.upload.com/?d=Y8N7M1LB
    *********.turbo.$.upload.com/download/v1VIPwsh8g2J/9_2_17C139.rar
    *********.wiki.$.upload.com/download_page.php?id=43989
    ******.bad.$.ongo.com/file/10237626
    ***deposit.$.files.com/files/6414325
    remove .$.
    Old 07-11-2008, 19:27   #15 (permalink)
    Member: 806861
    Thanks Meter: 92
    C139 Cingular memory Dump
    I will post Cingular Firmware dump soon..
    Remember guys these dumps contain everything on the phones.
    Boot+Flash
    Soon V171 Tracfone too, New Version........
    [IMG] code is Off
    Moto Tracfone C139 sw version 9.2.17 rontekgsm Infinity-Box 24 12-23-2008 07:12
    New Version 9.2.17 Unlocked! C139 gsm1999 Motorola ODM 8 03-18-2008 19:41
    Page generated in 0.32359 seconds with 9 queries
