Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
Motorola ODM BENQ(Acer): C113,C139,C168,C200,C205,C300,C257,C261, T205,T2688,T190,T191,V171,V290 CHIMEI: MPX200, MPX220, MPX300, V690, V878 COMPAL: E360, E365, MPX100, C115, C155 |
![]() | #1 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Mar 2002
Member: 10201 Status: Offline Thanks Meter: 0 | T19x sevice software Tamper Alert option does not work with t190 a phone killed I've already killed a phone. After that no comunication.Maybe soft writes t191 boot for t190. so t190 can't operate and communicate with any flasher. It comunicates with kima's v7.7 but can't flash cause it is t190 not t191. the worst is that the phone was new and I only wanted to test T.A . option with new working t190 Any Ideas? Any help would be appreciated |
![]() | #11 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2002 Location: TURKEY Age: 43
Member: 18442 Status: Offline Sonork: 111110 Thanks Meter: 622 ![]() | :( Sorry but one solution Makona T190 solution desolder flash another board plug and reflsah and again remove flash again plug. More info search button ![]() ![]() |
![]() | #12 (permalink) |
Member: 10201 Status: Offline Thanks Meter: 0 | I've already changed flash of t190 with programed f160 from nokia 3210. But after revive I cant change language or flex 'cause the IC has another flash ID from the original flash and this silly DMtools can't flash it or flex it or change it's imei. I started this thread 'cause I think that there is a software solution. After killing with allt19x TA option phone accept boot mode but can't accept second boot and send boot acknoledge . Some software as omega t191 flasher can communicate in such case but unfortunately only with t191 ( flas IC F320). With proper boot this tool can revive such T190's . I made another experiment-I changed flash IC of T191 with Ic for T190. Does anyone have a solution to downgrade T191 to T190. In most of the cases this is a silly thing but in this case this T191 had a broken flash IC and had only F160 |
!!Prepare option does not work!! restore operation failed | luigivsf | Smart-Clip | 2 | 01-30-2007 23:20 |
N500 works with Airtel( 1800mhz) but does not work with BPL,Orarange( 900 mhz)service | sunil9200 | VLSI, Conexant, Skyworks and Old Models | 1 | 03-01-2004 09:32 |
t68i does not work with usb cable? | Boz | Sony Ericsson | 1 | 08-05-2002 07:53 |
Why GoldCard does not work with Siemens C35? | CrazyBoy | Sim Cloning and Scaning | 9 | 07-26-2002 20:39 |
wulfgang does not work with normal data cable | tecra | Panasonic | 2 | 05-17-2001 11:10 |
