Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > LG
Old 04-29-2005, 17:05   #1 (permalink)
Member: 88848
8138 locked on all networks
I have a 8138 ive flashed and ive done full reset but it still dont work on any network. is there any way i can get this 2 work on all networs or can i just get it working back on 3g and i will apprecite sum help please.
Old 04-29-2005, 17:30   #2 (permalink)
chowdary's Avatar
Member: 91102
Thanks Meter: 34
what are u using to unlock it
br
Old 04-29-2005, 17:57   #3 (permalink)
Member: 88848
ive used furious, ive used the 4 battery clip, gsm key and blazer, didnt work on any
Old 04-29-2005, 18:06   #4 (permalink)
Unlocker AL's Avatar
Member: 3617
Thanks Meter: 517
Did you see before my friend which version have your phone
if is LG 8138 version 102+ you cant unlock this phone with blazer,forius ,gsm key,etc
you have tryed with clip that is the reason which your vphone does not work with any sim card ,also original card
The solution is to flash phone and to make with ver 100 and after you can unlock the phone
Good luck
Old 04-29-2005, 18:15   #5 (permalink)
nabil2000's Avatar
Member: 101449
Sonork: 100.1585880
Thanks Meter: 10
yeah my friend the clip can't unlock all version for lg u8138 i've setool2 on my n-box and it work good no problem............
Old 04-29-2005, 20:15   #6 (permalink)
chowdary's Avatar
Member: 91102
Thanks Meter: 34
not a problem
u downgrade the phone to v100. it will be italian or austrian
by using furious
relock it to anyother network 12345(voda) or23420
then check newer version and read codes
just save these codes in text folder
put voda sim in it and go to unlock menu and enter the codes
failin that try to relock to 23420 3G
failig that try to get hold of MOTOROLA TEST CARD
PUT THE TEST CARD IN IT AND THEN GO TO UNLOCK MENU 2945#*88110#
AND TYPE NCK CODE IN
FAILING THAT IF U ARE FROM UK THEN
TRY TO GET HOLD OF FIRMWARE 103+ UK
AND FLASH WITH IT AND IT WILL WORK ON 3G
LG 8180 lock on all network koa Cruiser Suite 2 01-13-2006 09:29
T610 lock on all network? koa Cruiser Suite 1 08-24-2005 15:57
NEC 338 (v 1.04) Locked on all networks bbmad FuriouS II 10 07-15-2005 17:35
Lg 8138 Locked To All Networks chowdary FuriouS II 8 04-02-2005 21:52
E700 Lock on all network Sebb4u Trident/AGERE Platform 7 02-27-2004 12:43
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.15396 seconds with 8 queries
