Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > LG
Old 09-25-2016, 13:14   #1 (permalink)
Member: 2564724
Lg g4 h815 is brick
Lg g4 h815 is brick, any solution? guidance
Old 09-25-2016, 16:53   #2 (permalink)
Member: 2627895
Thanks Meter: 6
If it has Custom recovery, than unbrick it with it.
If you don't have it, than just while the phone is powered off hold Volume + and try to put it in Download mode.
If it can get in Download mode, than download either lg support tool or download lg flash tool 2014.
When using lg support tool, keep the phone in download mode. To unbrick it with support tool, after installing it and running it. Go to the option tab and select emergency upgrade. Fill out the asked info, and wait for it to start searching for phone. Than put it in download mode and connect it to your computer. After that it should do the rest on it's own.
PLEASE KEEP IN MIND THAT YOU NEED TO HAVE, AT LEAST 50% BATTERY! (SO CHARGE IT)
To use "Lg flash tool 2014", you need firmware for your h815. Please carefully look on your sticker, that is says h815 and NOT h815p etc...
Than download your desired firmware (file format is .kdz), and run Lg flash tool 2014.
PLEASE KEEP IN MIND THAT YOU NEED TO HAVE DRIVERS INSTALLED FOR YOUR DEVICE! (You can find them online!)
Setting for Flash tool:
Select type should be CMDA.
Phone mode should be DIAG.
Do not touch any other settings!
Than open your kdz file.
And click "Normal Flash".
Than Start.
Than OK. (No need to change anything)
Your phone will start flashing as soon as it's found.
If this helped you, please press Thanks button.
For more question on how to use LG flash tool, please use XDA.
Source for this Guide is from XDA.
The Following User Says Thank You to Line of life For This Useful Post:
Old 09-25-2016, 18:32   #3 (permalink)
Member: 2564724
thank you sir,
i try and report
Old 10-03-2016, 08:07   #4 (permalink)
Member: 2564724
the phone gets into download mode but for some time only.
then it goes blank screen. any clue? is it some hardware fault or any other..,.,.regards.
Old 11-15-2016, 06:58   #5 (permalink)
Member: 2649189
Thanks Meter: 2
Qfil
There are some QFIL files in easy-firmware site that can unbrick all dead lg G4 variants. try it and report the success %.
The Following User Says Thank You to astenter1 For This Useful Post:
Page generated in 0.14313 seconds with 8 queries
