09-01-2009, 18:03 | #1 (permalink) |
Freak Poster Join Date: Sep 2008 Location: london
Member: 863844 Status: Offline Sonork: 100.1587943 Thanks Meter: 40 | kp 170 no signal after unlock |
The Following User Says Thank You to evolutions For This Useful Post: |
09-02-2009, 08:37 | #3 (permalink) | |
Freak Poster Join Date: Jul 2007 Location: TNC B A N G L A D E S H
Member: 541511 Status: Offline Sonork: 1583582 Thanks Meter: 51 | 100% solution no signal after unlock Quote:
flash with furious gold 100% ok with this file: KP170AT-00-V10g-EUR-XXX-OCT-23-2008+0 tested by me | |
The Following 4 Users Say Thank You to bashir telecom For This Useful Post: |
10-19-2009, 05:18 | #7 (permalink) |
Banned Join Date: May 2004 Location: Mauritius
Member: 64823 Status: Offline Thanks Meter: 439 | First you need to know which box you unlock IT. if the box make any eeprom backup, then you might get the network again by just flashing the phone with its original eeprom. Else need to read a full LG phone and copy it to your phone. Cheers and tested 100% work. |
The Following User Says Thank You to zakiyyboss For This Useful Post: |
11-06-2009, 17:05 | #8 (permalink) |
No Life Poster Join Date: Aug 2004 Location: india Age: 51
Member: 78028 Status: Offline Thanks Meter: 90 | if u have infinity box select model kp 215 and write this file KP170_eeprom_calibration_04.B1E.bin 100% tested |
The Following 7 Users Say Thank You to devika For This Useful Post: |
02-23-2010, 14:47 | #12 (permalink) |
No Life Poster Join Date: Nov 2005 Location: .:GSM WORLD:.
Member: 203158 Status: Offline Sonork: 100.1592032 Thanks Meter: 358 | COM3 [VCP0] selected module v1.39 Device: LG-KP215 Checking data, wait... advanced flash detection enabled Action: flash write Skip: Firmware (code) Skip: File system Skip: Alchemy data Write: Eeprom "smart write" active Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E223C2200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb id: 00005283 Boot Done Set baud ... 921600 Set baud Done Check flash ... current eeprom imei: 350305260000001 file saved: C:\Documents and Settings\Farrukh\Desktop\eeprom_350305260000001_LG-KP215_20100223-184608.B1E.bin .................................................. .............. Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write: Eeprom flash: 01227E223C2200:FEEA0000000000 Write Done Finished, time used: 42 sec Remove/Install battery now ! |
03-05-2010, 14:09 | #13 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: Mumbai--Great INDIA
Member: 665441 Status: Offline Sonork: 100.1670531 Thanks Meter: 603 | Quote:
here the log COM5 [VCP0] selected module v1.39 Device: LG-KP170 (under test) Checking data, wait... advanced flash detection enabled Action: flash write Skip: Firmware (code) Skip: File system Skip: Alchemy data Write: Eeprom "smart write" active Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E223C2200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb id: 00005283 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 350305260000001 file saved: C:\Program Files\InfinityBox\LGA\eeprom_350305260000001_LG-KP170 (under test)_20100305-182751.B1E.bin .................................................. .............. Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write: Eeprom flash: 01227E223C2200:FEEA0000000000 Write Done Finished, time used: 76 sec Remove/Install battery now ! | |
The Following User Says Thank You to hanif007 For This Useful Post: |
kp 170 no signal after unlock | shoaibrao | FuriousGold | 15 | 03-02-2012 07:52 |
error unlock nokia 1112 sw 6.46 phone is no signal after unlock | residentdenuevo | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-16-2010 08:26 |
KP-570Q without signal after UNLOCK | Diviclaro | VygisToolbox | 4 | 06-18-2009 22:33 |
kp 170 still locked after unlock why | chitawira | HWK | 20 | 04-21-2009 16:39 |
E50 Rm-170 no netwok after unlock :( | stargsm_ro | MT-BOX | 4 | 10-15-2008 19:18 |
