Lg G4 Dead boot Repair Qualcomm 9008 Tools Required: 1. Card Reader+Data Cable 2. A SD Card - 32 GB 3. SD Card Formatter 4. Win32DiskImager 5. Original KDZ 6. SystemImage Bin File Model vies 7. LGUP Tool Steps to Unbrick: 1. Insert your memory card in Card Reader and Format it using Windows Format. While formatting "uncheck Quick Format" and Change Type to "exFat". You can alternatively use SD Card Formatter but make sure that the card is in exFat format. 2. Once format is completed, install Win32DiskImager and open it. Add SystemImage.bin file. If it does not show the bin file just rename SystemImage.bin to SystemImage.img or select all and then select it. Select your memory card and Click Write. (You can alternatively change the file types on the win32diskimage from .img to all types) Win32diskimage 3. One the Write Completes. Eject Card and insert in your mobile. Press Volume Up Button while connecting the USB Cable. 4. There you go, it will open the download mode. Now Open LGUP Tool as admin. It will show the device as connected. Select the Original KDZ Firmware and Click Start. it will complete and your Mobile will reboot. 5. Now its Done. Enjoy! |
thank you for sharing this but I have to try this solution but no result thanks |
This method not work for bootloop only work for dead boot Qualcomm 9008 driver mode and you have correct system image file for your desire model I have one model G4 H811 correct system image 20o file this file link is https://mega.nz/#!5IoBkS6S!kxFixzRrg...wn_hYvDGgJYWxQ |
yes i have dead boot qualcomm 9008 but my phone is 815 |
You need 815 system image file to dump in sd card |
If the phone is Qualcomm 9008 conditions so you cant start to download mode |
anyone tried it? I don't think so that it will work |
I have to try this solution but no result |
meme probleme ...secure booting code error 1006 |
Hi, i have h818p and i cant find correct file system for this version maybe i can unpack it form orginall stuck kdz, but i don t now wichs file i must unpack? |
sd carte obligee 32go |
after repair boot phone restart in download mode and go lg logo every 5second restart . how solve it ??? pls help model h811 |
vs986. Qualcomm 9008 it. Is work Sent from my LG-D838 using Tapatalk |
Please. vs986. dump. file Sent from my LG-D838 using Tapatalk |
I need H810 System.img File Anyone have please upload I m stuck on Qcomm 9008 |
