09-07-2008, 23:46 | #1 (permalink) |
Freak Poster Join Date: Aug 2007 Age: 50
Member: 565867 Status: Offline Thanks Meter: 15 | LG KG800 Chocolate not turn on I have a KG800 Chocolate that would turn on,but only stay on for around 1 minute then turn off again. Even when plugged into the charger, it would not turn on. Only once every few mins the screen would light up and show that it is charging. So- I bought a new battery and when fitted the phone turned on ok and stayed on until the battery was flat. Once it was flat I charged it overnight, and now the phone will not turn on at all. What is the problem? |
09-08-2008, 11:59 | #3 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Yemen Age: 53
Member: 41256 Status: Offline Thanks Meter: 74 | that it charging problem, try to use tornado flasher with KG800 cable to charge the phone , if it does not help then there is hardware problem with the phone ( charging circuit ). |
The Following User Says Thank You to raid For This Useful Post: |
Cheap LG KG800 Chocolate phone on EBaY! | tazz_99 | GSM Mobile Links | 0 | 04-17-2007 02:57 |
LG KG800 Chocolate | incredibleh | LG | 3 | 10-21-2006 18:44 |
Lg Kg800 Chocolate | H_TSOPELAS | LG | 6 | 07-27-2006 02:04 |
First in the world LG KG800 CHOCOLATE unlocking clip | fonegroup | Main Sales Section | 0 | 07-06-2006 19:02 |
lg 8130 do not turn on after flash, but display works during charge!! | cubalibre0975 | LG | 1 | 03-06-2005 13:17 |
