Lg U8120 Drivers Could some kind soul help me for drivers for the LG U8120 Please I have try lg web but not got for this model |
i think tha LG u8110 drivers are the same ones so it should work. give them a try. They are on LG website regards |
I have tryd the LG U8110 drivers they went in ok but the unlocking software cant find the phone i looket in device manger for port which was 9 and still the program wont read so i tryd the normal software to try a ring tune still no luck what i am trying to do it unlock it i have got the furous unlocker for this phone any ideas will be greatfull i am on win xp if that helps |
hey u got the free software? i got the same problem the unlocking software dont find phone.. i made a thread,i need help to unlock my 8110 using the usb cable that came with phone to test if the 8110 drive are fully working try the phone manager if the finds ur phone via USB cable then the drives are working fine regards |
For all 3G handsets you can find drivers directly from THREE websites around the world, you just need searching. I think that you can find them at www.drei.at or www.tre.se. |
regards |
spawn you need serial cable if you have latest universal box all cables work 100% |
here is the code that unlocket the 2 LG U8120 1/ Type the following 2945#*88110# 2/ Press ok 3/ press ok 4/ type 00000000 5/ turn off your phone 6/ switch back on your phone You should now be able to select your network. I got this infomation from a m8 and works for me but dont no if it will work on others but has done 2 of the above phones. hope some one can send me the drivers and on hunt for the software to alter something has got an other that is blocket to do to do the factory reset is 277634#*# and you can test many parts of your phone LG U8120 In Joy please try at your own risk all i can say it worket on 2 of them so far |
1 Attachment(s) USB Drivers for LG U8120: Regards |
I have LG U8110 but when i do: 1/ Type the following 2945#*88110# 2/ Press ok 3/ press ok 4/ type 00000000 5/ turn off your phone 6/ switch back on your phone The phone does not unlock. If I reset it to factory default will it be unlocked, so all I do is put a sim in and it works??? Please help. |
this worket on ver 1.00 but i try on ver 1.05 and wont work but not tryd on other ver yet till get the other ver software |
thank you Quote:
thank you for the drivers they work a treat |
