12-20-2015, 21:37 | #2 (permalink) |
Registered User Join Date: May 2006 Location: ROMANIA - BISTRITA Age: 44
Member: 279656 Status: Offline Sonork: 1684319 Thanks Meter: 7 | With friend google nothing to be found about LG x150 - lg l bello II .No oficial LG solution ! No gsm box suport this phone for firmware flash or upgrade ! I managed to enter in recovery mode for hard reset - wipe data ,but still stuck on logo after restart ! I managed to unlock bootloader via fastboot but can't flash any other coustom rom ! Waiting for solution ! |
02-20-2016, 16:20 | #7 (permalink) |
Member: 279656 Status: Offline Sonork: 1684319 Thanks Meter: 7 | Furious Gold Packs 2/3/5/6 Update New Hot Models ! 20 feb 2016 ! OTSmart v1.0.0.1259 Added full support for the following models: MTN S620 LG X150 LG X160 Features: [x] READ-WRITE FLASH / READ-WRITE FIRMWARE [x] PATTERN/PIN/PASSWORD/PRIVACY - READ AND/OR RESET [x] FRP RESET (ANDROID 5.x.x) [x] PARTITION READ [x] SIM_LOCK REMOVE (UNLOCK+COUNTERS RESET) MEMORY_DUMP_MTN_S620_883232d8cb52bea90d565e2d6ecec df1.osp MEMORY_DUMP_LG-X150_5f3926619d5e941115565cd18ba0deb4.osp http://forum.gsmhosting.com/vbb/f475...odels-2054887/ |
The Following User Says Thank You to oto_electronics For This Useful Post: |
03-30-2016, 10:12 | #8 (permalink) |
Freak Poster Join Date: Sep 2004 Location: Spain Age: 48
Member: 83104 Status: Offline Thanks Meter: 12 | not work correctly with Furious Gold Packs 2/3/5/6 Update New Hot Models ! 20 feb 2016 ! OTSmart v1.0.0.1259 Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MTK USB Port (COM128)) Preparing to start flash mode; Preparing to open COM128 Connecting; Downloading DA; Initializing; Rid: 5e344b10eb1ed1d63b646f6ace228ec2 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (DA USB VCOM Port) TRYING TO OPEN COM92; DEVICE INFO: BB CHIP: MT6582_S01 [CA01, 01, 6582, 05] HW_STORAGE_EMMC: 0x51000115 0x4D533237 0x1C2C0042 0xBBA232C2 [SIZE=0x1D2880000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 9=8?87-00-9>9004-4 PROVIDER: N/A USRDATA INFO: 0xC1F00000 SIZE: 0x10980000 Loading the file ... Cfg done ... ERROR: S_NOT_ENOUGH_MEMORY Time needed - 00:00:58 Log file saved to: LOG_30_03_2016_11_11_31.txt |
05-06-2016, 15:48 | #10 (permalink) |
Junior Member Join Date: May 2016
Member: 2569402 Status: Offline Thanks Meter: 1 | LG X150 Hard Reset Good Evening every one! After lot of search, i'd like to tell you that i found a solution to Factory Reset LG X150 mobile Phone. 1) Power off the phone 2) Remove battery for 2 sec 3) Plug in battery and press Volume Down and Power Button simultanously 4) After few seconds bootloader screen appears. Select recovery mode. (If you accidentaly press fastboot mode then you will have to remove battery) 5) The phone will shows LG logo and after few seconds appears the green android robot with a red triangle above it 6) After that press Power Button and then press volume UP key (When press Power just wait half a sec before pressing volume UP) 7) Android System Recovery Appears . (Navigate with Volume UP+Down, Power Batton for initiating the available options) 8) Wipe Cache partition, Wipe Data/Factory Reset ( Yes --delete all user data) 9) reboot the system... The reboot usually is slower than usual reboot procedure Hope helping some fellows... Have a nice evening 9) |
The Following User Says Thank You to rakis1985 For This Useful Post: |
10-10-2016, 14:12 | #12 (permalink) | |
No Life Poster Join Date: Feb 2008 Location: SPAIN
Member: 698210 Status: Offline Sonork: 100.1578921 Thanks Meter: 3,591 | Quote:
Bellow shoudl get u to reset/backup/update menu 6) After that, short press these three bottons (both volumes + Power) This has been test on a lolipop version with firmware LGv10-00-FEB-16-2015 Regards RotelcaM | |
The Following User Says Thank You to rotelcam For This Useful Post: |
