11-02-2003, 12:19 | #1 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Karabakh - Azeris motherland Age: 45
Member: 9856 Status: Offline Thanks Meter: 2 | LG 510w problem with flashing I have an LG510w and I want to flash it. FLoader v2.0 responds but RAM loading is not completed. After that FLoader stops. I am using the free scheme for LG510w. I tried with both 5V and without it. I tried 28800 and 115200 baud rates. Problem remains. Anybody could flash it with FLoader v2.0? Thanks Sean Archer |
11-03-2003, 06:07 | #2 (permalink) |
Freak Poster Join Date: Jun 2003 Location: Russia Age: 45
Member: 31044 Status: Offline Thanks Meter: 0 | 1. Try to hold Power button until RAM loading completed. 2. If phone is dead, sometimes it can connect, but can't flash. 3. Try to use Monitor soft. 4. Try to erase flash, then download flash. |
11-03-2003, 10:41 | #3 (permalink) |
Member: 9856 Status: Offline Thanks Meter: 2 | Thanks for the help. I will be more precise now. - Phone is working. It is OK! I just wanted to upgrade its firmware. - I have tried with the Max232 scheme that is powering from COM port (B1200 works fine here) but phone is not detected even with DTR is ON from Port Settings. Rx & Tx voltage is around 2,60 - 3,60 V. - I have tried with Max232 scheme where power is external 5V. Detection is OK but RAM loading stops at the end. - Monitor does not respond. - I have tried all the settings and possibilities with COM port baud rate, DTR, RTS and flow control but nothing helps Thanks Sean Archer |
problem with flashing LG u8180 | bhogpurmail | Cruiser Suite | 3 | 08-05-2006 11:48 |
i have problem with flashing e600 with ufs-3 | petcy | UFS2 + UFS3-Tornadoflasher | 3 | 12-07-2004 19:58 |
Big Problem with flashing nokia 3650 with griffin | Slavonac | Griffin | 11 | 06-12-2004 20:57 |
LG-510w-problem | macak612 | LG | 1 | 01-18-2004 10:57 |
Problem with flashing N3330 with full dejan box | pali | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 02-20-2002 02:02 |
