03-23-2008, 06:06 | #1 (permalink) |
Junior Member Join Date: Feb 2008
Member: 698577 Status: Offline Thanks Meter: 0 | lg cu575 help Thanks |
03-24-2008, 06:34 | #2 (permalink) | |
Freak Poster Join Date: May 2006 Location: San Diego (USA)
Member: 276663 Status: Offline Thanks Meter: 39 | Quote:
2- then select from the drop menu vygis USB don't select any COM# port 3- to unlock this phone you need to use rj45 cable 4- don't use the right rj45 port use the left rj45 one 5- last one toolbox power on allways good luck www.mygswireless.com | |
03-24-2008, 06:53 | #4 (permalink) |
Member: 276663 Status: Offline Thanks Meter: 39 | check always should be the last one in the bottom and regarding witch rj45 cable to use to unlock the cu575 when you select the phone model look at the right the new software should tel you witch cable you should use, |
03-24-2008, 17:19 | #6 (permalink) |
Member: 276663 Status: Offline Thanks Meter: 39 | OK will check the new version today and let you know and I will take screen shot for you to show you, any how if you need free software to unlock your LG CU575 I can email it to you until we figure out what's going on with your vygis box |
03-30-2008, 05:52 | #7 (permalink) | |
1-make sure your battery is fully charge 2-plug the USB cable in to your phone and computer (make sure your phone must be on) 3-your computer will find new hardware, make sure to install the USB driver manually in to your Vygis file and it will ask you to do it for a couple of times that is normal 4-after you install every thing sucssefully you should be able to detect the phone and unlock it, 5-very important make sure you select baudrate 115200 and Enumerate ports and Auto find Port, and you are all done enjoy the unlocking www.mygswireless.com | |
Help lg cu575 how to do factory reset | AbdulKadir | FuriousGold | 3 | 10-19-2009 09:41 |
Lg cu575 att unlocking | mrfixit | LG | 5 | 02-12-2008 01:14 |
Lg Cu575 Help !!! | Lorelas | LG | 6 | 02-06-2008 21:37 |
LG CU575 How to ge unlock code? | eyestrain | LG | 0 | 11-21-2007 09:33 |
