Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > LG
Old 08-30-2010, 13:22   #1 (permalink)
Miftah_Lutfi's Avatar
Member: 638396
Sonork: 100.1615405
Thanks Meter: 170
Thumbs up LG GW300 Software Upgrade / Flashing Tutorial
If you are LG GW300 users and have a problem with it ( software problem ) like Auto Shutdown AKA Restarting, Hanging or stuck, now you can repair it for free.
Ok, let startded..,
Tools & Materials
  1. Original Usb data cable, compatible with Nokia CA-101 Usb data cable
  2. Software updater / flasher ( GSMMULTI V3.0 ). click here to downlod
  3. LG GW300 Firmware click here to download
Step by Step
  1. Download & Extract LG GW300 Flasher
  2. Execute / Install SETUP_GSMULTI_V30, and then C:\GSMULTI folder will be created
  3. Find MultiGSM_V30.exe on C:\GSMULTI folder, then right click, send to desktop
  4. Execute / Install Setup_USB_PortMapping_04.exe, and the result will be stored in C:\GSMULTI\UsbDrivers\MTK
  5. Connect phone ( in power off condition ) to PC via Usb data cable, wait until detected by PC
  6. When PC asking for driver, go to C:\GSMULTI\UsbDrivers\MTK, wait until driver installed
  7. Open MultiGSM_V30.exe ( at desktop ), go to Tab Setting ==> Configuration. For DLL, choose GW300_090625.dll at LG GW300 Flasher folder, for S/W file choose LG GW300 Firmware. For other setting don't changed
  8. Final step.., just click on START button and wait untill all process done / pass.
The Following 27 Users Say Thank You to Miftah_Lutfi For This Useful Post:
Old 09-17-2010, 09:17   #2 (permalink)
Member: 805962
Thanks Meter: 2
how about if the mobile is not able to work longer? My mobile life just 5 seconds and then die and my pc can not detect it goes .. any suggestions?
The Following User Says Thank You to fatan For This Useful Post:
Old 09-17-2010, 14:54   #3 (permalink)
nasirahmed's Avatar
Member: 57760
Sonork: 100.1579298
Thanks Meter: 3,510
In that case you need to use UART mode (flash with COM cable).
The Following User Says Thank You to nasirahmed For This Useful Post:
Old 09-17-2010, 16:07   #4 (permalink)
Member: 805962
Thanks Meter: 2
whether this method must use a box or can with software from LG (GSMULTI V3.0), if I could, how the settings in the software? please enlightenment once again brother .. thnx
Old 10-13-2010, 09:17   #5 (permalink)
nykocam's Avatar
Member: 67494
Thanks Meter: 71
phone hang,cant select right usb port in time,need scheme of UART cable.
The Following User Says Thank You to nykocam For This Useful Post:
Old 10-13-2010, 09:50   #6 (permalink)
nykocam's Avatar
Member: 67494
Thanks Meter: 71
Ok, let startded..,
Tools & Materials
Step by Step
attention please!!!
phone hang,cant select right port....
here solution:
after install all drivers (phone continue to hang)
go to c: gsmulti,open USBMap_V04.exe
choose MTK(ADI)
press MAPPING START
connect phone whit usb(off mode)
wait the phone hang and u see phone connect by USB or maybe another one but phone be recognized
open flasher and start.
all done.
br.
The Following 8 Users Say Thank You to nykocam For This Useful Post:
Old 10-15-2010, 09:44   #7 (permalink)
Member: 742276
Thanks Meter: 9
Originally Posted by nykocam View Post
attention please!!!
here solution:
choose MTK(ADI)
press MAPPING START
all done.
br.
After open USBMap_V04.exe, I can see phone recoqnized. But software MultiGSM stuck at wait phone connecting for long time. Phone is still hang.
How to solve?
The Following User Says Thank You to chikubie For This Useful Post:
Old 10-15-2010, 13:12   #8 (permalink)
nasirahmed's Avatar
Member: 57760
Sonork: 100.1579298
Thanks Meter: 3,510
How to solve?
after USBMap is being finished disconnect the phone, and when GSMulti stuck at wait for connecting phone, connect the phone again.
The Following 2 Users Say Thank You to nasirahmed For This Useful Post:
Old 10-30-2010, 08:25   #9 (permalink)
Member: 13382
Thanks Meter: 9
Helo I have an another probelem: the usb map is finding the port, the multi gsm is findung too the phone, after "waiting for connect the phone". After 5sec write failed and the phone display paver on "battery full..." i have tryed whitout the battery then too power on the display and the writed "insert battery".
Please help. Thx
The Following User Says Thank You to ocikem For This Useful Post:
Old 10-30-2010, 08:36   #10 (permalink)
Member: 13382
Thanks Meter: 9
Please help. Thx
Resolved whit reinstall.
Old 11-06-2010, 10:40   #11 (permalink)
Member: 283018
Thanks Meter: 46
Hi. I flashed an lg gw300 with this method, want to unlock, but said "incorrect code". what is the problem? how can be unlocked?
The Following User Says Thank You to loryka82 For This Useful Post:
Old 11-17-2010, 03:53   #12 (permalink)
Member: 1444581
Thanks Meter: 2
I tried my best to connect the lg gw300 in off condition and install driver, but its automatically installing driver and simultaneously giving msg on phone BATTERY FULL,,and on pc,,,DEVICE UNPLUGGED,,,
PLEASE help.......
The Following User Says Thank You to Akskal For This Useful Post:
Old 11-17-2010, 21:02   #13 (permalink)
nasirahmed's Avatar
Member: 57760
Sonork: 100.1579298
Thanks Meter: 3,510
Flashing has no relation with unlock. For unlock, you need professional tool or need to buy code.
Old 11-17-2010, 21:09   #14 (permalink)
nasirahmed's Avatar
Member: 57760
Sonork: 100.1579298
Thanks Meter: 3,510
PLEASE help.......
Use Windows XP SP2 .
Old 11-21-2010, 18:20   #15 (permalink)
Member: 1444581
Thanks Meter: 2
how can i play you tube videos in my lg gw300,,,,,every time i try it gives not supported exiting. do i need to install some software for it,,,,,,plse suggest..........thnx!
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
Page generated in 0.29195 seconds with 9 queries
