03-04-2008, 05:24 | #1 (permalink) |
Junior Member Join Date: Mar 2008
Member: 717249 Status: Offline Thanks Meter: 46 | World's First Solution for Change IMEI and Bluetooth address of KU990 Without any NV In order to change IMEI and Bluetooth address, you need the following tools: QPST : http://rs50.rapidshare.com/files/213..._build_231.rar NV Editor : http://www.siemensplanet.com/SandSto...s/NVeditor.zip the tutorial to enable the BT adress item with IMAGES .rar http://www.siemensplanet.com/forum/d...669853347d5b77 NOTE: many of these work are written by someone else on a different phone, but!!! they all use Qualtumm Baseband! If you had problems downloading, go to this page: http://www.siemensplanet.com/forum/viewtopic.php?t=4378 Same tools can be downloaded from there! Believe it or not, all these phones are exactly the same internally! START FROM HERE: IMEI: Turn the Phone Off, disconnect it from the PC, turn it on, re-connect it to the PC. Go Start -> (All) Programs -> QPST -> QPST Configuration. Click on the PORTS tab. If your phone is NOT listed... Click the ADD NEW PORT button in the lower right... From the list of ports in the box on the left, click the entry that says COMxx - QC/Diag modem and click OK. you will be brought back to the main QPST Configuration program displaying the "ports tab" this time with your phone listed as SURF6280 in the phone column... You are now ready to make use of QPST and its features. Use the Start Client pull down, click on Service Programming. Make sure your phone is selected, and click OK. Click READ FROM PHONE button in the lower left. for the Service Programming code... use 000000 (should be filled in that way anyway).. and click OK... After it reads the data in... go to the IMEI section on the first tab(NAS). TAC is the first 6 digits of your IMEI, FAC is the next 2, SNR is the next 6. The 15th digit of the IMEI is calculated by your phone, DO NOT enter the 15th digit. Click on WRITE TO PHONE button in lower left. This can take 1 minute, be patient! Wait for the read from file button become clickable again or simply wait 5 minute then Go to connection---close. Power the phone off, wait a few seconds.. then back on. IMEI Restored. Bluetooth Address: Since you upgraded the phone, you already have the usb drivers. Now, launch the QPST configurator. Click on "add new port" Type the port number your phone is using now. (you put it COM5, COM10, etc, its just one example) -----------------If you already added your port in QPST then skip this. Now, launch the NV editor, maximize the window. on connect, select the com port, and press connect server. press the file button and select upload all from mobile Then, press the search button, and type "447" Move the file to the "selected" window. Once you double click it, in another window you will see loads of firlds with 0 Change the to 1, all of them. also, change the string value to "true" Now, you press the "file" button and press "download selected & active to mobile" Disconnect the server, close the program, unplug the phone, and restart the phone. Now, try to enable the bluetooth. Remember, once you do the 6th image step, you go to connection and select disconnect server. All fixed! |
The Following 46 Users Say Thank You to coolmomisher For This Useful Post: |
03-04-2008, 17:17 | #2 (permalink) |
No Life Poster Join Date: Jul 2001 Location: A Place called Earth Age: 47
Member: 5285 Status: Offline Thanks Meter: 82 | 100% working tested solution ..................................... THANKYOU TESTED ON ku990 3 UK x 3 units |
The Following User Says Thank You to unlockgod For This Useful Post: |
03-04-2008, 19:10 | #4 (permalink) | |
Member: 5285 Status: Offline Thanks Meter: 82 | Quote:
Anyways worked for me tested by others also 5/5 units.. Respect to all who help us....... | |
03-05-2008, 03:40 | #5 (permalink) |
No Life Poster Join Date: May 2004
Member: 64893 Status: Offline Thanks Meter: 221 | Yes i agree this solution works 100% I had 10 units to repair. First one took 10 mins but the rest took just a few minutes. It actually takes longer for the bloody phone to boot-up than do the repairing processes |
03-08-2008, 22:52 | #11 (permalink) |
Cheater -Don't Deal with him- Join Date: Jan 2002 Age: 48
Member: 8879 Status: Offline Sonork: 100.84016 Thanks Meter: 327 | Damn, it must jsut be me then, cos it doesnt bloody work for me! After unlock using vygis, phone is all good, but when i try to write new imei with QPST i get error, and then says phone is no longer detected on com! Imei isnt changed either! Any ideas guys? |
03-09-2008, 21:58 | #14 (permalink) | |
Freak Poster Join Date: Mar 2005 Location: Hungary Age: 39
Member: 132496 Status: Offline Thanks Meter: 34 | Quote:
Nv_readonly_s.... Someone? | |
03-15-2008, 06:47 | #15 (permalink) |
Member: 723992 Status: Offline Thanks Meter: 0 | lost last 3 IMEI digits Originally LGMDP showed ******-xx-******-y-yy After unlock and follow up with QPST , i lost the last 5 characters "-y-yy" Does anyone know how to restore the last 3 digits? Mine is a TU720 Thanks RR |
solution for change imei to GX-20 Free with cable??? | humbedj | Sharp | 2 | 12-21-2005 16:34 |
help with solution for changing imei of T2288 with clip | MichieMax | Motorola Old Legacy (EMMI) | 0 | 04-01-2004 10:55 |
-=Need Solution for change IMEI S500=- | -=SanSanyc=- | Trident/AGERE Platform | 8 | 10-12-2003 20:41 |
Solution For Change Imei On M50 | Pandemonio100 | x1x to x45/x50 | 1 | 06-29-2002 15:23 |
