Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > Java, iOS, Android, Symbian development
Java, iOS, Android, Symbian development No SIS,JAVA,IPA Files to download here, this section is created to those who are Interesting in Programming JAVA,Android,iOS or Symbian Applications.
Old 11-09-2010, 06:37   #1 (permalink)
Member: 1355616
Sonork: 5816885
Java Standard Edition 5 and 6, Certified Associate Exam
The NowExam Certification Exam for the Sun Certified Associate 310-019
for the Java Platform, Standard Edition, Exam Version 1.0 exam provides students with preparation for Sun certification by acquainting them with the format of the exam and its questions, providing instant feedback. The exam includes sample test questions and the correct answers.
This Sun NowExam exam is comprised of 150 questions, divided into three forms of 50 questions each. You will have access to this exam for 180 days from the date that is on your Activation Key Code Letter. 310-019
Once you have purchased the NowExam exam, you will receive an Activation Key Code Letter that will contain an activation link, instructions to use the activation key code, links to FAQs and support information.
Section 1: Fun*****tal Object-Oriented Concepts
Describe, compare, and contrast primitives (integer, floating point, boolean, and character), enumeration types, and objects.
Describe, compare, and contrast concrete classes, abstract classes, and interfaces, and how inheritance applies to them.
Describe, compare, and contrast class compositions, and associations (including multiplicity: (one-to-one, one-to-many, and many-to-many), and association navigation.
Describe information hiding (using private attributes and methods), encapsulation, and exposing object functionality using public methods; and describe the JavaBeans conventions for setter and getter methods.
Describe polymorphism as it applies to classes and interfaces, and describe and apply the "program to an interface" principle.
Section 2: UML Representation of Object-Oriented Concepts
Recognize the UML representation of classes, (including attributes and operations, abstract classes, and interfaces), the UML representation of inheritance (both implementation and interface), and the UML representation of class member visibility modifiers (-/private and +/public).
Recognize the UML representation of class associations, compositions, association multiplicity indicators, and association navigation indicators.
Section 3: Java Implementation of Object-Oriented Concepts
Notes: code examples may use the 'new' operator.
Develop code that uses primitives, enumeration types, and object references, and recognize literals of these types.
Develop code that declares concrete classes, abstract classes, and interfaces, code that supports implementation and interface inheritance, code that declares instance attributes and methods, and code that uses the Java access modifiers: private and public.
Develop code that implements simple class associations, code that implements multiplicity using arrays, and recognize code that implements compositions as opposed to simple associations, and code that correctly implements association navigation.
Develop code that uses polymorphism for both classes and interfaces, and recognize code that uses the "program to an interface" principle.
Section 4: Algorithm Design and Implementation
Describe, compare, and contrast these three fun*****tal types of statements: assignment, conditional, and iteration, and given a description of an algorithm, select the appropriate type of statement to design the algorithm.
Given an algorithm as pseudo-code, determine the correct scope for a variable used in the algorithm, and develop code to declare variables in any of the following scopes: instance variable, method parameter, and local variable.
Given an algorithm as pseudo-code, develop method code that implements the algorithm using conditional statements (if and switch), iteration statements (for, for-each, while, and do-while), assignment statements, and break and continue statements to control the flow within switch and iteration statements.
Given an algorithm with multiple inputs and an output, develop method code that implements the algorithm using method parameters, a return type, and the return statement, and recognize the effects when object references and primitives are passed into methods that modify them.
Given an algorithm as pseudo-code, develop code that correctly applies the appropriate operators including assignment operators (limited to: =, +=, -=), arithmetic operators (limited to: +, -, *, /, %, ++, --), relational operators (limited to: <, <=, >, >=, ==, !=), logical operators (limited to: !, &&, ||) to produce a desired result. Also, write code that determines the equality of two objects or two primitives.
Develop code that uses the concatenation operator (+), and the following methods from class String: charAt, indexOf, trim, substring, replace, length, startsWith, and endsWith.
Section 5: Java Development Fun*****tals
Describe the purpose of packages in the Java language, and recognize the proper use of import and package statements.
Demonstrate the proper use of the "javac" command (including the command-line options: -d and -classpath), and demonstrate the proper use of the "java" command (including the command-line options: -classpath, -D and -version).
Describe the purpose and types of classes for the following Java packages: java.awt, javax.swing, java.io, java.net, java.util.
Section 6: Java Platforms and Integration Technologies
Distinguish the basic characteristics of the three Java platforms: J2SE, J2ME, and J2EE, and given a high-level architectural goal, select the appropriate Java platform or platforms.
Describe at a high level the benefits and basic characteristics of RMI.
Describe at a high level the benefits and basic characteristics of JDBC, SQL, and RDBMS technologies.
Describe at a high level the benefits and basic characteristics of JNDI, messaging, and JMS technologies.
Section 7: Client Technologies
Describe at a high level the basic characteristics, benefits and drawbacks of creating thin-clients using HTML and JavaScript and the related deployment issues and solutions.
Describe at a high level the basic characteristics, benefits, drawbacks, and deployment issues related to creating clients using J2ME midlets.
Describe at a high level the basic characteristics, benefits, drawbacks, and deployment issues related to creating fat-clients using Applets.
Describe at a high level the basic characteristics, benefits, drawbacks, and deployment issues related to creating fat-clients using Swing.
Section 8: Server Technologies
Describe at a high level the basic characteristics of: EJB, servlets, JSP, JMS, JNDI, SMTP, JAX-RPC, Web Services (including SOAP, UDDI, WSDL, and XML), and JavaMail.
Describe at a high level the basic characteristics of servlet and JSP support for HTML thin-clients.
Describe at a high level the use and basic characteristics of EJB session, entity and message-driven beans.
Describe at a high level the fun*****tal benefits and drawbacks of using J2EE server-side technologies, and describe and compare the basic characteristics of the web-tier, business-tier, and EIS tier.
[IMG] code is Off
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-15-2011 13:08
how the **** do i make wintesla 6.03 work Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-16-1999 08:41
wt603 and .pkd ARt Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-13-1999 19:18
Page generated in 0.21443 seconds with 9 queries
