Hello please help mee with Audi concert Hello! I have a 1999 Audi A6 5.2 tdu. And repair time was disconnected batery, so my radio - ''audi concert'' creates a safe! when purchased machine for my audi service book had already expanded leaflet containing information about the code! I've already found how to enter the radio code for the buttons while holding the button combination allows you to enter a code! Please you help me the radio is photographed with all serial numbers and codes! And mybe it's posible reset code and enter my new code?Help me please, otherwise I will live without music:) And there is all codes: * AUZ5Z3x0 109622 * | HC 205 concert | made in japan 4B0 035 186 B | NP 2 7/99 SERIAL NO. 52200 |
also your profile is incomplete... |
tell mee what i need to do.. ;/ i got pictures of my audi concert radio with all serials and all .. sory for rules .. but i realy need help pls help mee! |
give mee then dump for my audi concert. and how to use dump ? |
then read the eeprom contents and post your dump for code.. |
okey i do as you say sory for eng if somthing .. hey i got question hove to create dump ? to post here ? please help mee im new user in this forum . |
http://forum.gsmhosting.com/vbb/f179...newbie-503264/ |
I have read and understood that and that needs to be done but I do not understand it, Should I present the radio? to retrieve a dump? or I can after this series of codes and numbers make this dump? |
1 Attachment(s) Quote:
post that file (DUMP) here for code.. Chip maybe like this: |
must expressly warranted to be seen inside the radio, has a chance to restart the code? enter a new code? or that it will restart the entire audi concert system? and install new code? or something else is possible? |
whether there is a chance to restart the entire audio system and the Rest enter a new code? |
I can't remove the radio: /and can't see emprom and see the code, and / or I think is a chance to restart the old code? |
the chip is like an SD/Memory card that holds you radio's file with code inside... The chip is an 'S220 smd' device and needs an eeprom reader to read it.. |
