Eeprom Tools V 4.0 Released Eeprom Tools V 4.0 - XP edition What's new: - This version has the ability to change or rebuild IMEI number removed. If you are in UK or country that prohibit altering the IMEI number of GSM handsets by law and you still use older version of Eeprom Tools, please delete them from your HD and use the provided version. - New MBUS/FBUS comunication API layer provide more stable behaviour of the program and allow XP compatibility. - Read Start Up Self Test has separate Form Window and show all tests not the Failed only. - Left button is only to read phone info, the padlock is to rebuild default SP data in eeprom (dct3), and the right one will update FAID. - DCT4 Logger Mode - checking the 'Logger' box will allow to use Eeprom Tools for a DCT4 SP rebuild. Needed cable is FBUS ( all DCT3 functions require Mbus), or F/Mbus dual switching cable. * Supported DCT4 handsets: - 8310 - 6510 - 8910 - 8910i - 3510 - 3510i - 7210 - 6610 - 6100 - 7650 - 3650 - 6800 - 5100 ... etc. * Please check the Readme.txt for more details how to use this function. You can use now your old DCT3 dual switching cable for all DCT3 and DCT4 handsets - simply change the connector with the needed one and play with the RTS/DTR check boxes till you make it to work in the required connection mode. Please feel free to download from our website. Best Regards, Alex |
Always the Best from you Alex ;) |
Great job !!!! |
Thanks:D :D :D |
What is your web site ...? |
Thanks |
Hi, Quote:
www.b-phreaks.co.uk Best regards Daniel |
Thx Alex Good work ;) |
Pointer To Not Supported Hash Table Hello M8's What Does This Mean ? When I Run This Programme I Connect to Com 1 and The Then Click Read Info And This Is The Message I Get. What Does It Mean ? "Pointer To Not Supported Hash Table" ?? Best Regards Adam Rest Vast Gsm Team |
good soft Thx |
hi m8 whenever i go on www.b-phreaks.co.uk i get Server Error in '/' Application. -------------------------------------------------------------------------------- Runtime Error Description: An application error occurred on the server. The current custom error settings for this application prevent the details of the application error from being viewed remotely (for security reasons). It could, however, be viewed by browsers running on the local server machine. Details: To enable the details of this specific error message to be viewable on remote machines, please create a <customErrors> tag within a "web.config" configuration file located in the root directory of the current web application. This <customErrors> tag should then have its "mode" attribute set to "Off". < !-- Web.Config Configuration File -- > < configuration > < system.web > < customErrors mode="Off"/ > < /system.web > < /configuration > Notes: The current error page you are seeing can be replaced by a custom error page by modifying the "defaultRedirect" attribute of the application's <customErrors> configuration tag to point to a custom error page URL. < !-- Web.Config Configuration File -- > < configuration > < system.web > < customErrors mode="RemoteOnly" defaultRedirect="mycustompage.htm"/ > < /system.web > < /configuration > btw ive put spaces in between < and command > so u can see it |
Re: Pointer To Not Supported Hash Table Quote:
This is error caused by reading the MSID from the phone or the MSID is simply not valid. To Face Off Mobile: Could it be some .Net compatibility issue with your browser ? Will have to ask our webmaster, since this is not my stronger side. Here the download link, I hope will work: http://www.b-phreaks.co.uk/downloads/EepromTools.zip Best Regards |
u was the first to rebuild imei on dct3 by log method thanks to all your team |
help with eeprom tools v4 i am new to all this what can this v4 software do.... can some tell how to use it ect..... can it unlock old dct3 and dct4 ???????? please reply..................... |
Thanks mate works a treat and the self tests option is a good one |
