Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications. |
04-02-2011, 08:42 | #1 (permalink) |
Junior Member Join Date: Apr 2011
Member: 1547702 Status: Offline Thanks Meter: 0 | BlackBerry PlayBook VS iPad, enjoy DVD/Video with a tablet PC and mobile phone. Let’s start with physical design, the PlayBook is just 10mm thick, whereas the iPad is 13.4mm thick, also the PlayBook weighs less at just 0.9lbs, whereas the lightest iPad weighs 1.5lbs. To be honest the weight difference isn’t surprising as the iPad’s 9.7 inch display is larger than the PlayBook’s 7 inch display. The clarity of the displays should be pretty similar, this is because the PlayBook’s 7 inch display supports a resolution of 1024 x 600, whilst the iPad’s 9.7 inch display outputs at 1024 x 768. The PlayBook should offer a great web experience as it features full Adobe Flash 10.1 and HTML 5 support, at the moment a high percentage of websites use Flash, however in the future it is thought that HTML 5 will take over, therefore the PlayBook should be compatible with pretty much every website you tried to view. One thing I dislike about the iPad is the need for accessories such as the iPad Camera Connection Kit and the iPad Dock Connector to VGA Adapter, the PlayBook features a built-in microUSB connector and micro HDMI, these standardized connectors should allow you to easily connect your PlayBook to a wide-range of devices with a wide-range of cables. The micro HDMI output allows your to connect your PlayBook to an external HD display, according to RIM’s website you will be able to stream video at 1080p, which is far superior to the iPad’s 576p output (via the Apple Component AV Cable). Reprinting from:http://b+e+s+t+-d+v+d-r+i+p+p+e+r+.+...com/16224.html |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
