Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Multimedia
Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications.
Old 07-19-2008, 00:17   #1 (permalink)
Member: 689101
Thanks Meter: 282
[Guide] VERY EASY WAY TO SIGN UNSIGNED APPS!! Even my grandma can do it!!
Now this is what i call a fast signing procedure of unsigned applications. It doesnt take more than 5 seconds and 4 clicks on your computer to sign a unsigned application!
First, install 2 sis application on your phone.
Then open the RootSign.exe on your computer
Choose the unsigned application that you want to sign.
And its done!
In order to install “Unsigned” releases, you need to go through a one-time procedure. You will need to run the in the release included “SecMan.exe”. This program allows you to install our future “Unsigned” releases, without signing them every time.
For this, you will need to have TRK (included in this package) installed, and connected to your pc via USB connection.
s60_3_0_app_trk_2_8_6.sisx for SymbianOS9 devices WITHOUT FP1 s60_3_1_app_trk_2_8_6.sisx for SymbianOS9 devices WITH FP1
To get this app properly running, make sure you have installed the newest Nokia PC Suite, and your phone connected via “PC Suite” mode. On the phone, run the TRK app, in applications folder. When it asks for bluetooth connection, don’t turn it on, and change connection settings to USB. After you have done that, click “Next” and follow the instructions on screen.
When the installation is done, look in the Applications folder on your phone, and find SecMan. Open it, and click on “Install Root Certificate”.
After this is done, you will be able to install our future “Unsigned” releases like normal “Signed” applications.
Please keep in mind, if you format / upgrade your phones firmware, you’ll need to do this step again and after that manually install those apps from Application Manager.
NOTE: To install previous unsigned releases, use RootSiGN v1.0 (Included in the package) first to sign these releases with our root certificate. This can be used to sign and install any unsigned .sis(x) file
Thx to X.Factor for the info and BiNPDA for creating this app!
Download the needed file to sign your unsigned applications
The Following 257 Users Say Thank You to almostdone For This Useful Post:
Old 07-22-2008, 08:54   #2 (permalink)
dynamic-gsm's Avatar
Member: 166385
Thanks Meter: 282
Easy!! maybe ! to do this u need PC , cable , PC_Suite , driver..and it is old solution , i have already post a easy one without use PC , cable or anything and tested by many menbers .. ( https://forum.gsmhosting.com/vbb/f18/finally-broke-s60-3rd-certificat-553602/ )
I forget , plz modertaor , can you say me wich the standards of sticky thread ? we must knwo , to do better for our forum
The Following 24 Users Say Thank You to dynamic-gsm For This Useful Post:
Old 07-22-2008, 16:06   #3 (permalink)
Member: 741877
Thanks Meter: 43
Thanks to both of you, dynamic-gsm, you was was very lengthy, no hard feeling.
The Following 8 Users Say Thank You to DrJPB For This Useful Post:
Old 07-23-2008, 18:28   #4 (permalink)
Member: 291160
Thanks Meter: 6
Thanx you for your sharing, i tried to install the two sis file onto my 6220 Classic phone it gives me an error message says "component is built-in" what should i do now?
The Following 6 Users Say Thank You to aycan555 For This Useful Post:
Old 07-24-2008, 19:52   #5 (permalink)
Member: 498507
Thanks Meter: 4
Finally, got it to work on the n95 8gig. Many thanks
The Following 4 Users Say Thank You to sammyx For This Useful Post:
Old 07-25-2008, 18:09   #6 (permalink)
Registered User
amrutbairy's Avatar
Member: 153229
Thanks Meter: 28
And its done!
Link to download the file is not working........pls upload the proper link
The Following 11 Users Say Thank You to amrutbairy For This Useful Post:
Old 07-25-2008, 18:35   #7 (permalink)
Member: 322417
Thanks Meter: 940
link working fine chk again
The Following 5 Users Say Thank You to Formingus For This Useful Post:
Old 07-26-2008, 08:58   #8 (permalink)
Member: 56216
Thanks Meter: 11
same error on my E71
The Following 4 Users Say Thank You to HeavyHMS For This Useful Post:
Old 07-26-2008, 09:03   #9 (permalink)
Member: 810101
Thanks Meter: 39
thanks mate.............
The Following 3 Users Say Thank You to simpleboy For This Useful Post:
Old 07-26-2008, 12:44   #10 (permalink)
Registered User
amrutbairy's Avatar
Member: 153229
Thanks Meter: 28
Checked the link again still not working........
The Following 3 Users Say Thank You to amrutbairy For This Useful Post:
Old 07-29-2008, 20:37   #11 (permalink)
Member: 689101
Thanks Meter: 282
The link is working fine for me but anyway here is a mirror:
http://rs303.rapidshare.com/files/13...ymobile.se.rar
The Following 7 Users Say Thank You to almostdone For This Useful Post:
Old 07-30-2008, 08:14   #12 (permalink)
Member: 823982
Thanks Meter: 6
works perfect thanks
The Following 6 Users Say Thank You to jk,zlh.i For This Useful Post:
Old 07-30-2008, 10:11   #13 (permalink)
Member: 689101
Thanks Meter: 282
6220 Classic and E71 is both FP2 (Feature Pack 2) devices. This if for non-FP1 (devices before FP1) and FP1...
My only suggestion is to try use other hacks available. If still doesn't work you need to wait for hack to become available for FP2...
The Following 5 Users Say Thank You to almostdone For This Useful Post:
Old 07-30-2008, 11:55   #14 (permalink)
Member: 689101
Thanks Meter: 282
EDIT: E71 is FP1 but with some FP2 features. I guess it's the FP2 features that are causing the same error message as 6220c. These are the latest OS9.3 devices so you'll have to wait until new hack is available...
Old 08-01-2008, 20:58   #15 (permalink)
Member: 56216
Thanks Meter: 11
the problem is s60_3_0_app_trk_2_8_6.sisx: this version is not compatibile with new phones, but the new protection is included in s60_3_0_app_trk_2_8_9.sisx (compatible with fp2 and "hibrid" E71)
If i install this version in a old phone Signsis was unable to recognize the device, but s60_3_0_app_trk_2_8_6.sisx works.
The Following 7 Users Say Thank You to HeavyHMS For This Useful Post:
VERY EASY WAY TO SIGN UNSIGNED APPS!! Even A 5 year child can do it!! malikraghav Nokia Multimedia 1 05-09-2011 07:03
EASY way to SIGN unSIGNED apps!!! PROVED!! j_Antonio Nokia Multimedia 4 03-15-2011 14:57
sign to unsign applications very easy way 5 year child can do it malikraghav Nokia Multimedia 0 07-16-2009 17:23
Very easy way to sign unsigned apps jignesh_1000 Nokia Multimedia 1 04-02-2009 17:41
Very easy way to unlock lg2030 telm Various CDMA/TDMA Cell Phones 16 08-31-2004 12:23
Page generated in 0.26581 seconds with 11 queries
