Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications. |
07-19-2008, 00:17 | #1 (permalink) |
Major Poster Join Date: Jan 2008
Member: 689101 Status: Offline Thanks Meter: 282 | [Guide] VERY EASY WAY TO SIGN UNSIGNED APPS!! Even my grandma can do it!! First, install 2 sis application on your phone. Then open the RootSign.exe on your computer Choose the unsigned application that you want to sign. And its done! In order to install “Unsigned” releases, you need to go through a one-time procedure. You will need to run the in the release included “SecMan.exe”. This program allows you to install our future “Unsigned” releases, without signing them every time. For this, you will need to have TRK (included in this package) installed, and connected to your pc via USB connection. s60_3_0_app_trk_2_8_6.sisx for SymbianOS9 devices WITHOUT FP1 s60_3_1_app_trk_2_8_6.sisx for SymbianOS9 devices WITH FP1 To get this app properly running, make sure you have installed the newest Nokia PC Suite, and your phone connected via “PC Suite” mode. On the phone, run the TRK app, in applications folder. When it asks for bluetooth connection, don’t turn it on, and change connection settings to USB. After you have done that, click “Next” and follow the instructions on screen. When the installation is done, look in the Applications folder on your phone, and find SecMan. Open it, and click on “Install Root Certificate”. After this is done, you will be able to install our future “Unsigned” releases like normal “Signed” applications. Please keep in mind, if you format / upgrade your phones firmware, you’ll need to do this step again and after that manually install those apps from Application Manager. NOTE: To install previous unsigned releases, use RootSiGN v1.0 (Included in the package) first to sign these releases with our root certificate. This can be used to sign and install any unsigned .sis(x) file Thx to X.Factor for the info and BiNPDA for creating this app! Download the needed file to sign your unsigned applications |
The Following 257 Users Say Thank You to almostdone For This Useful Post: |
07-22-2008, 08:54 | #2 (permalink) |
No Life Poster Join Date: Jul 2005 Location: In Original_Space Age: 42
Member: 166385 Status: Offline Thanks Meter: 282 | Easy!! maybe ! to do this u need PC , cable , PC_Suite , driver..and it is old solution , i have already post a easy one without use PC , cable or anything and tested by many menbers .. ( https://forum.gsmhosting.com/vbb/f18/finally-broke-s60-3rd-certificat-553602/ ) I forget , plz modertaor , can you say me wich the standards of sticky thread ? we must knwo , to do better for our forum |
The Following 24 Users Say Thank You to dynamic-gsm For This Useful Post: |
07-23-2008, 18:28 | #4 (permalink) |
Junior Member Join Date: Jun 2006
Member: 291160 Status: Offline Thanks Meter: 6 | Thanx you for your sharing, i tried to install the two sis file onto my 6220 Classic phone it gives me an error message says "component is built-in" what should i do now? |
The Following 6 Users Say Thank You to aycan555 For This Useful Post: |
07-25-2008, 18:09 | #6 (permalink) | |
Registered User Join Date: Jun 2005 Age: 42
Member: 153229 Status: Offline Thanks Meter: 28 | Quote:
Link to download the file is not working........pls upload the proper link | |
The Following 11 Users Say Thank You to amrutbairy For This Useful Post: |
07-29-2008, 20:37 | #11 (permalink) |
Member: 689101 Status: Offline Thanks Meter: 282 | The link is working fine for me but anyway here is a mirror: http://rs303.rapidshare.com/files/13...ymobile.se.rar |
The Following 7 Users Say Thank You to almostdone For This Useful Post: |
07-30-2008, 10:11 | #13 (permalink) | |
Member: 689101 Status: Offline Thanks Meter: 282 | Quote:
My only suggestion is to try use other hacks available. If still doesn't work you need to wait for hack to become available for FP2... | |
The Following 5 Users Say Thank You to almostdone For This Useful Post: |
07-30-2008, 11:55 | #14 (permalink) |
Member: 689101 Status: Offline Thanks Meter: 282 | EDIT: E71 is FP1 but with some FP2 features. I guess it's the FP2 features that are causing the same error message as 6220c. These are the latest OS9.3 devices so you'll have to wait until new hack is available... |
08-01-2008, 20:58 | #15 (permalink) |
Junior Member Join Date: Feb 2004 Age: 47
Member: 56216 Status: Offline Thanks Meter: 11 | the problem is s60_3_0_app_trk_2_8_6.sisx: this version is not compatibile with new phones, but the new protection is included in s60_3_0_app_trk_2_8_9.sisx (compatible with fp2 and "hibrid" E71) If i install this version in a old phone Signsis was unable to recognize the device, but s60_3_0_app_trk_2_8_6.sisx works. |
The Following 7 Users Say Thank You to HeavyHMS For This Useful Post: |
VERY EASY WAY TO SIGN UNSIGNED APPS!! Even A 5 year child can do it!! | malikraghav | Nokia Multimedia | 1 | 05-09-2011 07:03 |
EASY way to SIGN unSIGNED apps!!! PROVED!! | j_Antonio | Nokia Multimedia | 4 | 03-15-2011 14:57 |
sign to unsign applications very easy way 5 year child can do it | malikraghav | Nokia Multimedia | 0 | 07-16-2009 17:23 |
Very easy way to sign unsigned apps | jignesh_1000 | Nokia Multimedia | 1 | 04-02-2009 17:41 |
Very easy way to unlock lg2030 | telm | Various CDMA/TDMA Cell Phones | 16 | 08-31-2004 12:23 |
