Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Multimedia
Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications.
Old 04-01-2013, 14:46   #1 (permalink)
Member: 1905721
How to Recover Data from Memory Card
Sometimes we may encounter some suffering of data loss from the memory card, it would bring us so much worries and trouble for the inconvenience it bring to us cause lot of data stored on the card. But how to recover data from memory card? The big question will always about the data recovery. Please hold your horses to review this article; it will give you the satisfactory even greatly appreciated the answer.
To solve the problem, we must search the answer from the origination of the issues. What the exact problem was to the memory card? Let me list the symptom of this disease of data lose. It happens all the time in any of the devices of CF (Compact Flash) Card, Memory Stick, SD (Secure Digital) Card, MicroSD, xD Picture Card, MMC (Multi-Media Card), MicroDrive, Smart Media Card, SDHC, MiniSD and etc. As the problem’s symbol could be the seeing of the error messages as "format error", or some mess code for your disturbing mood. When you see that, the valuable data of memory card may go away following. Or there’s the chance that your PC indicate that your memory card will reformat and the computer refuse to read your memory card’s data.
The possible causes of the above symptoms may be the too old of the Memory card; or the file system could not be recognized by Windows, it should be reformatted; the incompatibility problems only concern the format procedure; the format errors that happened on the memory card itself; and the last reason is the physical damage.
Then you need to recover the error format data on your card before it’s too late! Firstly try to put the error memory card on another normal computer to see if it can be worked well. If it won’t help, try to recovery the inner data in the first time via a card reader to connect for safe. The following step is to try format the error memory card from the root directory of disk management. The final but the most important one, try to use the data recovery software to re-scan the drive to harvest more data because the format won’t keep the data in a permanent way.
The memory card recovery software would help you out of the serious hindrance of data managing. It will make the data delete no longer to be a dreaded situation to save time and money to us. It would not only recover PDF, text files documents, MS Office documents, Access databases, music & movies in format like MP3, MP4 and more, but also professional at recovering images in formats like PSD, TIFF, GIF, BMP, PNG, JPEG, etc. in all the version of Windows OS, Vista, XP, 2003, 2000, etc. It has the easy user interface of the trusted equipment for the common user. It can restore formatted data of the original formatting.
Though the data loss may happen here and there, when you accessing the memory card to connected to the computer or the formatted data or photos lost from memory card or making the original data overwritten, the acquirement of the ownership of the memory card data recovery software may thoroughly reduce the risk of your damage by data recovery.
Source:Bestsoft4u.com
Old 09-10-2014, 11:05   #2 (permalink)
Member: 2254727
Sonork: http://sonork.com/eng/cli
Thanks Meter: 2
You can use Amrev memory card repair software. This software is certified by Microsoft as well as available with free demo version.
Page generated in 0.13228 seconds with 8 queries
