Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications. |
06-23-2003, 12:50 | #1 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Nigeria
Member: 18200 Status: Offline Sonork: 100.1608286 Thanks Meter: 82 | Knokphoenix Not Working On My Pc I wanted to flash this 5210 using The above software which has been noted to be the best for it, But when I double-click on the icon, it cant start, only showing the frame and disappearing in less than 1 second !!!!. I have tried it on WIN 98se & WIN 2000 Pro, same thing !!! What do I do? PLS HELP. dannyogolo |
06-23-2003, 13:01 | #2 (permalink) |
No Life Poster Join Date: Jan 2003 Location: Hong Kong. Age: 47
Member: 19979 Status: Offline Thanks Meter: 116 | SAAMMMEEEEEE PROBLEM WITH ME MAN.......i also have the same problem but i found the solution..... there is an option for erasing the full flash ....use it and erase the flash first then write the flash it will work okay ..if still not solved then forget knok and and use rolis select 3330 as model and write a full flash image(4 MB) ur phonwe will be okay again |
06-23-2003, 13:24 | #3 (permalink) |
Member: 18200 Status: Offline Sonork: 100.1608286 Thanks Meter: 82 | Hello syed, I had used Rolis and full-flashed it B4, but it doesnt get any network, they say the best is KNOKPHOENIX !!! The issue is this, using the old KNOK can not erase all flash, it stops somewhere then starts writing, (& U know that Rolis cant show U the erase address, so I also assume it cannot erase that same address). My problem is getting this KNOKPHOENIX to work for me. Did you get the NO NETWORK experience? OR what do I do?? Thanks |
Motorola RAZR H3 Bluetooth Headset not working w/ my PC | joe7dust | Bluetooth-Software | 3 | 01-04-2009 05:48 |
p2k easy tool v5.1 not work on all PC too | xiaoyuz | Motorola P2K (USB-Smart) | 51 | 07-18-2006 10:06 |
DCT4 Calculators not working on my Nokia 8390 | shopsite | Nokia Multimedia | 5 | 07-24-2003 00:32 |
help: dejan not work on my nbtebook | gsmonline | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-01-2001 20:29 |
