Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications. |
11-25-2006, 15:42 | #1 (permalink) |
Junior Member Join Date: Mar 2006
Member: 239590 Status: Offline Thanks Meter: 0 | 33 EASY STEP TO REGISTER UR LCGJukebox...Get it here... NOTE: THIS TRICK IS ONLY WORKING WITH Lonely.Cat.Games.LCGJukebox.v1.11..NOT WORKING WITH v.1.12..So Please Take Note... You can get those file right down my post..thanks.. IT WORKS ON MY N-GAGE CLASSIC.. So,Giv your phone a try..^^ 1) Uninstall any of your Lonely.Cat.Games.LCGJukebox 2) Use any file manager ( Fileman or Fexplorer ) 3) Go to c:\system\data 4) You can observe many files and folders there.. 5) Mark all the file ( NOT FOLDER )..Just file.. 6) Cut them all to a new folder..you can place them where you like..example c:\data 7) Paste them all inside the folder... 8) If the file explorer tells you the files are in use or read-only..just skip that file..leave them originally inside c:\system\data... 9) Now you have a clean C:\System\Data folder.. 10) Use a pen or your brain to copy down those file left in c:\system\data..it should be a few only.. 11) Install the Lonely.Cat.Games.LCGJukebox.v1.01.S60.SymbianOS.Cr acked-BiNPDA.. Sorry..add on here..( After you finish install,Dont RUN IT..Go to c:\system\data,there will be new files inside there..so add their file name inside the paper you used just now..just add them inside the list..) 12) Run it and register it with any key.. 12) Exit the program.. 13) Run the file manager and go to c:\system\data... 14) Take out ur paper just now and find out which file is added into the folder.. 15) In my case, Jukebox make a file name "realplayer.cfg"..so figure out yours.. 16) After u get that file..Copy that file and paste it inside any folder as you like..example c:\crack.. 17) You will have a cracked file now.. 18) Now Install Lonely.Cat.Games.LCGJukebox.v1.11.S60.SymbianOS.Cr acked-BiNPDA.. 19) Dont Run it yet..!!! 20) Use File Manager and go to c:\system\data 21) You will note some new file appears again in your c:\system\data...( IF DONT HAVE JUST SKIP Step 21 and 22 ) 22) Again,copy down those file's name in a paper or you memorize it.. 23) Run the LCGJukebox v1.11.. 24) Exit the LCGJukebox v1.11... 25) Go back to the c:\system\data... 26) You will found out that more than 1 file are new in your c:\system\data.. 27) Write down the new file found in the c:\system\data folder.. (Note: There must be a file with the size 100byte~300byte) (In my case,after i install LCGJukebox v1.11,there are two files added in my c:\system\data..one is "enssc.dat" and the other is "prcparam.tok") 28) Rename the cracked file( realplayer.cfg ) in c:\crack to ( the name of the file which its size is between 100byte~300byte ).. Sorry again..add on..( Cut the renamed file and place them back into c:\system\data..IF IT ASKS FOR REPLACE..just choose "YES",replace it..) 29) Now the LCGJukebox should be fully cracked now.. 30) Open your c:\data folder.. 31) Cut them all and paste inside c:\system\data... 32) Please be careful..what file you should replace and which file u should not replace..( DONT REPLACE THE FILE NAME WHICH YOU HAD RENAME TO ) ( IN MY CASE,I REPLACE ALL THE FILE EXCEPT "enssc.dat" ) 33) Run Your LCGJukebox AND YOU WILL HAVE A FULL Version of it.. GIV ME A LITTLE THANKS IF YOU HAVE SUCCESSFUL REGISTER IT.. If You faced any problem please reply here or PM me..I will try my best to help you..~ Credit goes to me.. |
*** [4] Buttons And Easy Steps To Repair DCT4 RPL *** | Ron2pet | ufs-rpl | 4 | 08-18-2009 17:22 |
7 easy steps to solve BB5TP not connected | DJTEKKEN | Universalbox | 4 | 10-04-2008 16:06 |
easy step to unlock bb5 phones | JAGGANATH | Nokia Base Band 5 ( BB-5 ) | 1 | 05-21-2007 08:13 |
easy step to use UBL | mj_0990 | Ultima Box Light | 3 | 02-25-2007 10:59 |
want to be the first get it here first | einstien | Nokia Multimedia | 1 | 08-06-2006 10:14 |
