Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications. |
10-05-2004, 16:08 | #1 (permalink) |
Junior Member Join Date: Sep 2004 Age: 39
Member: 82791 Status: Offline Thanks Meter: 0 | Nokia 7610 RS-MMC Card problem Please Help!!! Please Help b4 2 days i brought new N7610 in which RS-MMC (Reduced Size Multimedia Card) of 64kb was given. it is working perfect in my phone but i am not able to open in my card reader. I am using windows XP Pro when i select the card drive from my computer after some minutes (it does not take time when card is not inserted) it ask for inserting disk into it. i think card reader is not able to recognize the card. But Except this card all other cards are read by card reader. I am useing 13 in 1 card reader. so please help how can i make my MMC work in card reader. i has to upload via cable or Bluetooth which i dont want to do. |
10-05-2004, 17:09 | #2 (permalink) | |
Freak Poster Join Date: May 2004 Location: Malaysia Age: 50
Member: 66197 Status: Offline Thanks Meter: 2 | 7610 mmc problem Quote:
If u brought the new set u will notify that this rs mmc got a holder to be clip on to be insert in the card reader coz the size was reduce , the other problem was u already set the password on ur card otherwise the card reader can read it...... | |
10-06-2004, 06:56 | #3 (permalink) | |
Member: 82791 Status: Offline Thanks Meter: 0 | Quote:
Thankx for the responce. I am useing RS-MMC with clip. But problem is that card reader is not able to read it as you said there must be the password. But i had inserted the card after formating in the phone before that there was no password was set. As you said then i set the New password and removed then i againg format it still it is not working in Cardreader but it works good in N7610. Please help. | |
10-06-2004, 21:36 | #4 (permalink) |
No Life Poster Join Date: Aug 2004 Age: 41
Member: 78673 Status: Offline Thanks Meter: 1,253 | Only 1 Solution for that dude...u have 2 change ur card rader,u must be having the MMC card reader 1.1...Get the MMC card reader 2.0..n7610 mmc is only supported in the usb 2.0... |
10-07-2004, 11:44 | #5 (permalink) | |
10-08-2004, 19:05 | #7 (permalink) |
Junior Member Join Date: Jul 2004 Age: 41
Member: 72165 Status: Offline Thanks Meter: 0 | how to delete the mmc password. [QUOTE=hbyh]Thankx for the responce. I am useing RS-MMC with clip. But problem is that card reader is not able to read it as you said there must be the password. But i had inserted the card after formating in the phone before that there was no password was set. As you said then i set the New password and removed then i againg format it still it is not working in Cardreader but it works good in N7610. ************************************************** ******* since i have this problem also. i agree with ur thing the password is set but my question is??????????? how to delete the password i set since i forget....... any method to delete it. hope can help TQ |
10-08-2004, 19:11 | #8 (permalink) |
Member: 78673 Status: Offline Thanks Meter: 1,253 | hbyh--->>check the pack in which ur card reader is packed off...im sure some details is given in it...whether it is usb 1.1 or usb 2.0... and im sure urs is usb 1.1 coz earlier ive bought the same 13 in 1 reader but it fails to work... |
10-08-2004, 19:14 | #9 (permalink) |
Member: 78673 Status: Offline Thanks Meter: 1,253 | UC910--->>use Treo 600 or n9210i to remove the password from ur locked mmc card... The best is Treo 600 coz when u insert the mmc into it,it automatically asks u 2 format the mmc... |
NOKIA 7610 / 6670 Memory Card Probleme | suraj9860607689 | Nokia Hardware & Hardware Repair | 0 | 03-24-2009 06:58 |
..7610 MMC Reader Problem..Please help... | LoveLess | Nokia Hardware & Hardware Repair | 1 | 03-02-2006 13:37 |
unlock 7610 rs mmc card? | excelpass | Nokia Multimedia | 0 | 10-02-2004 10:38 |
7610 RS-MMC card not working in card reader | mobile_beee | Nokia Multimedia | 7 | 08-26-2004 20:00 |
Insert correct card problem please help..... | uwenk98 | Old Ericsson Phones & Sony Phones | 2 | 01-15-2003 09:24 |
