Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications. |
07-17-2007, 11:36 | #1 (permalink) |
Freak Poster Join Date: Oct 2006
Member: 364835 Status: Offline Thanks Meter: 16 | Remove java application security questions in nokia 40 v3 mobiles This tutorial will help you to remove the security questions while openning folders in your memory card... **Please Strictly follow the steps...otherwise it not be working** Download and install the patched mobiMb media browser and hex editor that i have attached here 1.first install the java application that you want to remove the security prompt 2.Run the application and close it after some time 3.Go to application access>phone access>add and edit user data> enable ask every time 4.Go to application access>phone access>read user data> enable not allowed 5.Go to application access>phone access>add and edit user data> enable not allowed 6.Open mobiMb browser you can see a drive named 'A'...copy the file _jmr_suite_attrib_file.jmr located in A:\hiddenfolders\ to your desktop and rename it into x.jmr 7.close moilMb Browser 8.take ur mobile and Go to application access>phone acces>read user data> enable ask everytime 9.Go to application access>phone acces>add and edit user data> enable ask every time 10.Again open the MobiMb browser and copy the _jmr_suite_attrib_file.jmr file into ur desktop and no need to rename it. 11.open the hex Editor and open the above two jmr file ..go to tools and click compare files..click find alldifference.. 12.Then you can find one differrence like 01 01 00 and 02 02 00 or something like it 13.Change the values in the _jmr_suite_attrib_file.jmr files 01 01 00 to 06 06 00 (**Note this key cominations may be differ with handsets so try with 02 02 02 ,03 03 03 or 04 04 04 or ...to 09 09 09...for my nokia 6270 ,06 06 00 is works**) and save it..make sure that you have edited the values in the _jmr_suite_attrib_file.jmr file...no need to change the value of x.jmr 14.copy this edited _jmr_suite_attrib_file.jmr file in to ur mobile phone using moilmb in A:\hiddenfolders\ 15.Run the application if all are success you don't have any security prompt...and works like a signed application This tricks work with most applications like mobyexplorer v3,operamini mod ,jzipman, lyric show player and for other application ...i am sure this method work with all applications... Don't forget to post ur replies... Hope you understand...enjoy download link for mobiMB and hexeditor http://www.sendspace.com/file/b9z2us |
The Following User Says Thank You to sujeshtc For This Useful Post: |
07-17-2007, 16:19 | #2 (permalink) | |
Member: 364835 Status: Offline Thanks Meter: 16 | Quote:
it works | |
08-08-2007, 17:00 | #6 (permalink) |
Junior Member Join Date: Aug 2007
Member: 558603 Status: Offline Thanks Meter: 0 | Thanks for sharing. Does it work with setting that is not available for change? For example, messaging (application access - Communication - Messaging) can only be set to either "Ask every time" or "Not allowed" for S40 v3. The "Always allow" option is grey out. Can I use this method to set it to "Always allow"? |
08-09-2007, 05:39 | #7 (permalink) | |
08-09-2007, 11:07 | #8 (permalink) |
Member: 562559 Status: Offline Thanks Meter: 0 | I canot access java aplication like flurry, opera in my Nokia 5300.I am using BSNL WAP from India, Kerala.How can I set my Accesspoint configuration.All other website can be accessed.But no jar application can access net .HELP ME |
08-09-2007, 16:24 | #9 (permalink) | |
Any way try this go to configuration settings set bsnlwap as default configuration settings...activate default in all application... I think the problem with the preferred access point.. set bsnlwap as prefered access point ..if no bsnl access point is shown in access points ..then go to personal config.settings..click option>add new>access point> Access point name bsnlwap...packet data access point is bsnlwap... hope it will work..if it not work reply me | |
08-09-2007, 17:46 | #10 (permalink) |
Member: 364835 Status: Offline Thanks Meter: 16 | if the above method is not working then try this also go to configuration settings>personal config settings>Add new>web Account name bsnlwap home page any address u like usename ppp password ppp123 use prefered access pt no access point settings proxy enable proxy proxy address 10.31.54.2 proxy port 9401 data bearer packetdata packet data accesspt bsnlwap authentication type normal activate this account as default config settings and activate default in all application if this also not working then do the same process except set proxy disable.. i am sure it should work... |
10-19-2007, 12:36 | #13 (permalink) |
Junior Member Join Date: Oct 2007
Member: 605011 Status: Offline Thanks Meter: 0 | Mobile media browser doesnt work with 6300 hello!!!! I downloaded the mobile media browser added detnator to common fils->logo manager but i dont really see a:\.I tried the russian made one too but it didnt help.I have nokia 6300 firmware v. 5.0.I am attaching a screen shot of the application. hope you can help me out. |
How 2 Remove java application security questions in my N73 | Muhammed2 | Java, iOS, Android, Symbian development | 4 | 08-10-2008 11:26 |
[Question] On how to retrieve lost security code in Nokia 1680c | shiver21 | Nokia Hardware & Hardware Repair | 3 | 07-22-2008 09:51 |
How 2 Remove java application security questions in my N73 | Muhammed2 | Nokia Base Band 5 ( BB-5 ) | 1 | 06-06-2008 05:37 |
How To Remove Security Code In Nokia 6708 | rajan nishchal | MT-BOX | 5 | 11-05-2006 08:31 |
converting nokia 40 s mobile too 60 s | niceguylove | Nokia CDMA | 0 | 06-16-2006 18:27 |
