Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Multimedia
Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications.
Old 07-17-2007, 11:36   #1 (permalink)
Member: 364835
Thanks Meter: 16
Remove java application security questions in nokia 40 v3 mobiles
This tutorial will help you to remove the security questions while openning folders in your memory card...
**Please Strictly follow the steps...otherwise it not be working**
Download and install the patched mobiMb media browser and hex editor that i have attached here
1.first install the java application that you want to remove the security prompt
2.Run the application and close it after some time
3.Go to application access>phone access>add and edit user data> enable ask every time
4.Go to application access>phone access>read user data> enable not allowed
5.Go to application access>phone access>add and edit user data> enable not allowed
6.Open mobiMb browser you can see a drive named 'A'...copy the file _jmr_suite_attrib_file.jmr located in
A:\hiddenfolders\ to your desktop and rename it into x.jmr
7.close moilMb Browser
8.take ur mobile and Go to application access>phone acces>read user data> enable ask everytime
9.Go to application access>phone acces>add and edit user data> enable ask every time
10.Again open the MobiMb browser and copy the _jmr_suite_attrib_file.jmr file into ur desktop and no need to rename
it.
11.open the hex Editor and open the above two jmr file ..go to tools and click compare files..click find
alldifference..
12.Then you can find one differrence like 01 01 00 and 02 02 00 or something like it
13.Change the values in the _jmr_suite_attrib_file.jmr files 01 01 00 to 06 06 00
(**Note this key cominations may be differ with handsets so try with 02 02 02 ,03 03 03 or 04 04 04 or ...to 09 09
09...for my nokia 6270 ,06 06 00 is works**)
and save it..make sure that you have edited the values in the _jmr_suite_attrib_file.jmr file...no need to change
the value of x.jmr
14.copy this edited _jmr_suite_attrib_file.jmr file in to ur mobile phone using moilmb in A:\hiddenfolders\
15.Run the application if all are success you don't have any security prompt...and works like a signed application
This tricks work with most applications like mobyexplorer v3,operamini mod ,jzipman, lyric show player and for other
application ...i am sure this method work with all applications...
Don't forget to post ur replies...
Hope you understand...enjoy
download link for mobiMB and hexeditor
http://www.sendspace.com/file/b9z2us
The Following User Says Thank You to sujeshtc For This Useful Post:
Old 07-17-2007, 16:19   #2 (permalink)
Member: 364835
Thanks Meter: 16
Originally Posted by rejaulkarim View Post
There is no A: drive with mobilMB
So where i get that folder A:\hiddenfolders\
Replace nokia.ini with this patched nokia.ini file in C:\Program Files\Common Files\LogoManager
it works
File Type: rar Detonator_v.2.rar (786 Bytes, 428 views)
Old 08-02-2007, 14:21   #3 (permalink)
Member: 559072
thanks ,works with my N6280 ,i successfully remove the read write prompt for the mobyexplorer v3 cracked,opera mini mod,kd player and lyric show player thanks once again
Old 08-08-2007, 13:13   #4 (permalink)
Member: 288491
Thanks Meter: 2
yes its working bro thanx for sharing ur good work
Old 08-08-2007, 13:53   #5 (permalink)
Member: 364835
Thanks Meter: 16
Originally Posted by zabhi View Post
Not working in 6300............
It should work with nokia 6300...try this russian made mobimb this will show hiddenfolder of 6300
Old 08-08-2007, 17:00   #6 (permalink)
Member: 558603
Thanks for sharing.
Does it work with setting that is not available for change? For example, messaging (application access - Communication - Messaging) can only be set to either "Ask every time" or "Not allowed" for S40 v3. The "Always allow" option is grey out. Can I use this method to set it to "Always allow"?
Old 08-09-2007, 05:39   #7 (permalink)
Member: 364835
Thanks Meter: 16
Originally Posted by jcl1234 View Post
Thanks for sharing.
i am not sure...may be this trick also works with messaging also...try yourself
Old 08-09-2007, 11:07   #8 (permalink)
Member: 562559
I canot access java aplication like flurry, opera in my Nokia 5300.I am using BSNL WAP from India, Kerala.How can I set my Accesspoint configuration.All other website can be accessed.But no jar application can access net .HELP ME
Old 08-09-2007, 16:24   #9 (permalink)
Member: 364835
Thanks Meter: 16
i also face the same problem with my nokia 6270..i can acccess internet through the default web browser but through opera mini i can't access internet ...somehow i solve the problem...but i don't exactly remember what have done..now i am not using gprs in my mobile...
Any way try this go to configuration settings set bsnlwap as default configuration settings...activate default in all application...
I think the problem with the preferred access point..
set bsnlwap as prefered access point ..if no bsnl access point is shown in access points ..then go to personal config.settings..click option>add new>access point>
Access point name bsnlwap...packet data access point is bsnlwap...
hope it will work..if it not work reply me
Old 08-09-2007, 17:46   #10 (permalink)
Member: 364835
Thanks Meter: 16
if the above method is not working then try this also
go to configuration settings>personal config settings>Add new>web
Account name bsnlwap
home page any address u like
usename ppp
password ppp123
use prefered access pt no
access point settings
proxy enable
proxy proxy address 10.31.54.2
proxy port 9401
data bearer packetdata
packet data accesspt bsnlwap
authentication type normal
activate this account as default config settings and activate default in all application
if this also not working then do the same process except set proxy disable..
i am sure it should work...
Old 08-10-2007, 05:29   #11 (permalink)
Member: 364835
Thanks Meter: 16
some operator only gives wap access like aktel in bangladesh. if ur operator only gives wap access u can not access internet by j2me application.
ok you are right ...but in india using bsnl wap we can access all internet...
Old 09-08-2007, 10:28   #12 (permalink)
Member: 62016
Thanks Meter: 48
sir is thir gps system for 6300 pls
Old 10-19-2007, 12:36   #13 (permalink)
Member: 605011
Mobile media browser doesnt work with 6300
hello!!!!
I downloaded the mobile media browser added detnator to common fils->logo manager but i dont really see a:\.I tried the russian made one too but it didnt help.I have nokia 6300 firmware v. 5.0.I am attaching a screen shot of the application.
hope you can help me out.
Old 05-25-2008, 14:07   #14 (permalink)
Member: 363127
Thanks Meter: 23
i want to Remove java application security 6500 slide.....can any one help me...........? any mobimb who show the hidden file in 6500 slide..
Old 09-06-2008, 07:38   #15 (permalink)
Member: 854914
Can s.b upload detnator file in rapidshare or somewhere else?
I can`t download it.
How 2 Remove java application security questions in my N73 Muhammed2 Java, iOS, Android, Symbian development 4 08-10-2008 11:26
[Question] On how to retrieve lost security code in Nokia 1680c shiver21 Nokia Hardware & Hardware Repair 3 07-22-2008 09:51
How 2 Remove java application security questions in my N73 Muhammed2 Nokia Base Band 5 ( BB-5 ) 1 06-06-2008 05:37
How To Remove Security Code In Nokia 6708 rajan nishchal MT-BOX 5 11-05-2006 08:31
converting nokia 40 s mobile too 60 s niceguylove Nokia CDMA 0 06-16-2006 18:27
Page generated in 0.26223 seconds with 10 queries
