Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications. |
03-14-2002, 13:30 | #62 (permalink) |
Freak Poster Join Date: Jan 2001 Location: I.C., R.P.
Member: 3165 Status: Offline Thanks Meter: 0 | Have successfully tried it on a 5110, 6150, 33XX, 6210. Have tried using Tones from 5210 (Side Step and Speedy) and all worked well. Just make sure you use FAID calculators that require the full flash as parameter. nk_calc, EepromTools, and nkTool wn't work. For new models that are unlocked using FFFFF on lock 1 and/or 4 (i.e 3310 v5.XX) PPM changing is rather impossible for now. Just changing 1 byte or swapping bytes from either MCU or PPM and no matter how many times you recalculate FAID, it still won't work. regards, aCe |
03-14-2002, 15:41 | #63 (permalink) |
Junior Member Join Date: Mar 2002
Member: 9835 Status: Offline Thanks Meter: 0 | no metter what I do I always get contact service. I have 6210 5.56 and I've tried every think: * just adding ringtone; * removing ringtone and then adding new one; just removing ringtone. I've tried this with all ringtoneman ver. and I always get CS |
03-14-2002, 19:42 | #65 (permalink) |
Freak Poster Join Date: Jan 2002 Location: Leon
Member: 8804 Status: Offline Thanks Meter: 4 | server down? guys can someone upload this prog. to the upload section, i v been trying to get it for some time now, no luck..... http://gsmsearch.com/nfree/nfreeboar...ingToneMan.exe Unable to determine IP address from host name for gsmsearch.com ,, my browser says... so i get my dns has a problem,, & when I try the IP for gsmsearch.com i get a "url not found" thanx. http://216.40.212.54/nfree/nfreeboar...ingToneMan.exe Last edited by fofodaman; 03-14-2002 at 19:49. |
03-14-2002, 20:09 | #68 (permalink) |
Member: 8804 Status: Offline Thanks Meter: 4 | anyone tried this on a 6210 ? if so, where should the flash be read from ~ to ? thanx, i tried it on original 3310 ppm file it listed the tones fine, but i get an error on 6210 ppm file. update: flash for 6210 should be from 002~005A as in both MCU &ppm. Last edited by fofodaman; 03-14-2002 at 20:26. |
03-14-2002, 20:23 | #69 (permalink) | |
Member: 8804 Status: Offline Thanks Meter: 4 | Quote:
03-14-2002, 20:30 | #70 (permalink) |
No Life Poster Join Date: Nov 2001 Location: Never Land
Member: 7277 Status: Offline Sonork: 100.42158 Thanks Meter: 68 | hi guys; the prog doesn't work for me.i don't know why..... it always hangs after adding ringtones and pressing do jobs. please help me what is the problem with it......... ------------------------------------------- kick butt first; take names later ------------------------------------------- MARKIE 2002.............. |
03-15-2002, 02:25 | #72 (permalink) |
Crazy Poster Join Date: Nov 2001
Member: 7406 Status: Offline Thanks Meter: 0 | Tested in a 5110 with two-tones at the same time, one from 6110 and the other from 6210 Calculated FAID with FAID******* Ok, working without major problems, only that the 6210 tone in my 5110 has this name "...", do not know why Best regards Xepuis |
03-15-2002, 05:35 | #73 (permalink) |
Freak Poster Join Date: Nov 2001 Age: 45
Member: 7327 Status: Offline Thanks Meter: 12 | tested on 5110 8 tones at same time hello m8s soft 100 % working tested by adding 8 tones from 8210 , 3210 at one time , faid calculated by tec . but the problem now is how to make *.re other than extracting from nokias ? kind regards . |
03-15-2002, 06:09 | #74 (permalink) |
No Life Poster Join Date: Jan 2000 Location: GSM Forum
Member: 871 Status: Offline Thanks Meter: 602 | Hello, Use WinDDP 2.60 or 2.70. It can download ringtones directly from phone and save it into "mytones.ton" file which if I am not mistaken, is very much similar to *.re format. I uploaded upto 42 ringtones on a 5110, now my 5110 has 72 rintones. 12 of the uploaded ringtones are cutomized and 1 of the customized ringtone was 45-seconds LONG! The other 60 ringtones came from 7110, 8210 and 3330... From 7110, I even got the tone for "Battery Low", Recharge Battery", "SMS ALert Specail" and a few funny tones ... You can also add Languages, but only from PPM files of the same version and kind. For example, you can add EURO languages to an ASPAC PPM. But somtimes chinese characters will be displayed as boxes if the phone cannot support the fonts. Although you need a VALID registration key for WinDDP 2.60 and not the KEY generated by KEY Generator released in this forum some time ago... If you need valid KEYS, maybe I can help you email me: [email protected] Best Regards, X-Shadow |
03-15-2002, 13:48 | #75 (permalink) |
No Life Poster Join Date: Nov 2001 Location: Mauritius Age: 47
Member: 7482 Status: Offline Thanks Meter: 24 | NOT working !!!!!!! Hi I have tried RingToneMan and after i wrote the ppm file to the phone it does not get network. I don't have M-BUS cable to update FAID with tek But i have EEPROM tool 3.0 Will the FAID be updated with EEPROM tool 3.0 I have tried it and no positive result. Still NO NETWORK. The phone does not have hardware problem because when i write backup of the same phone it works fine. How to add rinrtone then?????????? Please help me!!!!!!!!!!!!! [email protected] |
china phone imei changer new 100% work tested. | hmyeamin | Chinese Models & Cloned Phones | 0 | 01-25-2010 10:20 |
Upload Ringtone to A800, 100% work!! | petit_jack | VLSI, Conexant, Skyworks and Old Models | 15 | 08-03-2003 08:03 |
any 100 % working Ringtone changer download ? | nightxyz | Nokia Multimedia | 5 | 04-16-2002 13:10 |
100% Working Nokia Imei Changer, SP Unlock, FAID Calc For Exchange | nim444 | Exchange Section | 3 | 02-26-2002 01:42 |
T20 A26x8 Flasher & Imei Changer 100% work ***FREE*** | VsH-GsM | Old Ericsson Phones & Sony Phones | 9 | 01-31-2002 00:41 |
