Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Multimedia
Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications.
Old 02-19-2006, 16:53   #151 (permalink)
Member: 160722
hi! where can i find skype for n6630?thanks!
Old 02-19-2006, 18:31   #152 (permalink)
Khatulistiwa's Avatar
Member: 209644
Thanks Meter: 113
Smartphoneware Best Safe v2.00 S60 incl HSpda-Keygen
Best Safe is an easy-to-use, reliable and secure manager and organiser for your private data. With Best Safe you can store your passwords, credit cards and banking information, login information and other your data in one place and to keep it with you always.
Best safe interface is very easy to use. You can create cards and quick notes, then arrange them into folders. To view any existing card just select it and press joystick button. If you want to modify the card just use 'Edit' command in the card view.
Arranging cards
* You can move existing cards up and down in list using Pen+Joystick up/down or the corresponding command from menu.
* You can move existing cards to any folder using 'Move card to folder' command
Security
You can password protect and encrypt your data stored in Best Safe. To enable security use 'Set Password' command. After you specify a password all your data will be encrypted. Every time you open Best Safe the application asks you for the password. When you work with the application all data encryption/decryption is performed on the fly and absolutely transparent to you.
If you want to disable password protecting of your data by some reason you can use 'Change password' command and specify empty password.
To keep your data secure we use ****Fish encryption and MD5 message digest algorithms.
Please note: your password is not stored anywhere inside the application or on the device in order to increase safety. Password verification is performed by checking digital signs (digital signs say nothing about your password nature). It means that no person (including the application developers) can open and see your data without specifying correct password. Please don't forget your password as there's no way to access your data without it!
Security options
You can set up automatic application lock (password screen appears when the application is locked). To do so you can use Security options command and specify incactivity time period. E.g. specifying 15 seconds here means if during 15 seconds you don't work with your device (don't touch any key, etc) Best safe application will ask the password again before you can continue to work with the application.
Appearance
You can use 'Appearance' command to change the application appearance. There are several skins already preinstalled with the application to allow you to customize view of Best Safe.
Export/Import
If you want to backup your data you can use Export command. The application exports your data in comma separated text file. Please note that this file is not encrypted and you can open it in readable form in Excel application on your desktop PC. You can import your data to the application using "Import" command. Please note that when you import data it just adds cards listed in the importing file to the existing database. If you already have the same card in the database you will get its duplicate.
Search
You can find the needed card using "Find", "Find next" commands in Search menu. Just specify a part of text you want to find and application will look for the needed card for you. Search function will analyse all cards in all folders and will search for specified text in all fields in the card.
What's new in version 2.00
* Export/import functions added. Now you can backup your data using export functions and even open exported file in Excel in readable form.
* Search function added.
* Card view has been improved. Now you can see more information on screen at one moment.
* Screen flicking when changing folder removed.
* Some other minor improvements.
Compatible on All S60 Devices!
File Type: rar Smartphoneware.Best.Safe.v2.00.S60.incl.keygen-HSpda.rar (274.9 KB, 2688 views)
Old 02-19-2006, 18:35   #153 (permalink)
Member: 209644
Thanks Meter: 113
Intellsys.Alarm.Pro.v1.012.S60.SymbianOS7.Cracked-BiNPDA
Alarm Pro is multi alarm manager designed for a wide range of tasks: it can remind you to take your medicine or simply wake you up in the morning. It can run any number of alarms.
Alarm Pro will help you to be always in time. It has three types of alarm which will cover almost all situations. At the same time it has a simple interface that is fast and easy to use.
Alarm Types
“One Time” alarms – you can define this type of alarm for any event that will happen only once, like a meeting or to remind you to wait somebody at the *******
“By Day” alarms – this type of alarm will be triggered on the selected days of the week. For example you can set it up to awake you in the morning only for certain days.
“Periodic” alarms – any periodic event can be handled by this type of alarm. Taking medicines on schedule is important, with this type of alarm you simply select the time interval (for example 8 hours) and the number of pills to take.
Key Features
selectable alarm tone
snooze option
short message for each alarm
Old 02-19-2006, 19:20   #154 (permalink)
Member: 209644
Thanks Meter: 113
that file too big bro, i can't load here....
sorry...
Old 02-19-2006, 19:58   #155 (permalink)
Member: 209644
Thanks Meter: 113
symantec virus definitions as of 17th Feb 2006
File Type: rar symantech mobile security definition update 17-02-06.rar (10.3 KB, 1746 views)
Old 02-20-2006, 15:27   #156 (permalink)
Member: 209644
Thanks Meter: 113
Symbian toys V1.01
Symbian toys V1.01
And 20-February will be released FlashSms (also donateware): First Series60 software capable of sending sms-flash without needing of external additional services.
Sms Notification -
Guardian avvisa con un sms l'avvenuto cambio sim e riportera' informazioni quali il numero di telefono del nuovo possessore, l'identificativo della cella GSM a cui il terminale e' attualmente agganciato, l'identificativo del paese e l'operatore utilizzato. Da notare che l'sms viene inviato senza che il nuovo possessore ne abbia notifica.
- AutoStart -
Guardian parte in automatico ad ogni avvio del cellulare, e' sufficiente installarlo e configurarlo affinche' svolga il suo lavoro.
- AutoHiding -
Sostituendo la sim con una non autorizzata (oppure accendendo il terminale senza sim inserita) il programma nascondera' la propria presenza (di conseguenza non piu' accessibile). Quindi il nuovo utilizzatore non avra' modo di accorgersi immediatamente della presenza di un antifurto installato. Reinserendo una sim autorizzata Guardian ritornera' visibile.
- Multilanguage -
Guardian e' predisposto per essere Multilingua, al momento il programma e' disponibile in 7 lingue: Inglese, Italiano, Francese, Spagnolo, Tedesco, Greco, Malese.
- Uninstall Protection -
Fornisce una protezione contro le disinstallazioni non autorizzate. Il programma non compare neppure tra la lista dei programmi installati, per la sua rimozione e' presente una apposita procedura accessibile dall'interno del programma.
- Hard Reset Protection -
I terminali odierni, sono dotati di una particolare procedura (l'hard-reset) che consente di riportare il terminale alle impostazioni di fabbrica (rimuovendo ogni software installato). I software analoghi possono essere completamente "raggirati", attraverso questa procedura. Guardian e' dotato di un innovativo sistema di copia *******ta che gli permette di "sopravvivere" illeso ad un hard-reset nel 90% dei casi.
- Low Overhead -
Durante l'utilizzo quotidiano del cellulare con una sim autorizzata, Guardian non occupa alcuna risorsa, non viene eseguito neppure in background. Il programma viene avviato esclusivamente all'accensione del cellulare e se la sim e' autorizzata, semplicemente si chiude senza occupare inutilmente preziose risorse.
(*) Remote Control Plugins
Dopo che e' stato segnalato l'avvenuto cambio sim e' possibile inviare a Guardian dei comandi attraverso sms. E' ad esempio possibile cancellare i propri dati sensibili quali sms/foto/rubrica/video/audio, tutto inviando un singolo sms. Per una descrizione approfondita, vedere la sezione Plugins.
(*) Sim White List
NOTE! I've not found english description if someone found it please post it .Thank you but the applications is in english
Compatible with :
Nokia: 3230, 6260, 7610, 6600, 6630, 6670, 6680, 6681, N 70, N 90
Old 02-20-2006, 16:23   #157 (permalink)
Member: 209644
Thanks Meter: 113
OggPlay S60 non-MMF v1.091
This is the Release Note for Release 1.091 of Oggplay for Series60.
This release is only experimental and hasn't been thoroughly tested.
Please use the official release 1.0.0 , unless you are willing to
beta test our new features.
If you experiment problems please report them to our public forums
and remember to include the version number.
What's new in Release 1.091:
Added alarm clock
Some internal changes / one very minor bug fix
Notes:
In order to use the alarm clock you must leave OggPlay running.
It is best to move OggPlay to the background as less processing power is used when OggPlay runs in the background.
To select a particular track for the alarm:
1. Make sure OggPlay is not currently in the middle of a track (paused)
2. Leave the track highlight on the track you want to play as the alarm
If you want a random alarm:
2. Turn on "Shuffle play"
3. Leave the track highlight on "(titles)"
What's new in Release 1.0.9b:
Bug fixes:
1. Support 8KHz mono playback (this should also allow streaming over bluetooth)
2. Fix audio skips and "slow motion" on NGage
3. Fix pause / play not updating position
4. Frequency analyzer now works for all supported oggs (8KHz-48KHz, mono/stereo)
5. Support stereo down sampling (e.g 48KHz stereo -> 44.1KHz stereo)
6. Fix "Not so random" random playback
What's new in Release 1.0.9a:
Fixed start from shortcut crash
What's new in Release 1.0.9:
Working frequency analyzer
Some bug fixes
What's new in Release 1.0.8:
Experimental new playback engine (see Options->Playback)
3 buffering modes:
No buffering - best for multi-tasking but unresponsive OggPlay UI
Single thread - Fewer audio dropouts but still unresponsive OggPlay UI (needs an extra 256K free memory)
Multi thread - Fewest number of audio dropouts, responsive OggPlay UI (needs an extra 1MB free memory)
2 thread priorities:
Normal - the default value, best for multi-tasking
High - Fewer audio dropouts, but not so good for multi-tasking
-24dB volume boost added
What's new in Release 1.0.7:
Fix for new Sendo X firmware 1.198.8.2
What's new in Release 1.0.5:
Support for playlists within playlist.
Plenty of bug fixes.
What's new in Release 1.0.4:
Misceleaneous bugfixes. Ogg decoder fix for very bass-heavy music.
Playlist support added (WinAmp format). For now they can be read only.
Added Portuguese and Russian languages.
Further SendoX audio level adjustments.
What's in Release 1.0.1:
All the features of 1.0.0 plus:
+ New shortcut option for next/previous song
+ 'Dynamic' random play. No need to shuffle the playlist anymore.
+ Quite a lot of internal changes.
+ New shortcut option for engaging keylock
Old 02-20-2006, 16:31   #158 (permalink)
Member: 209644
Thanks Meter: 113
MobiFun.Soft.LockMe.v1.05.S60v2.SymbianOS.incl.Key gen-HSpda
Update
Now you can enjoy great customization and enhaced phone security with LockMe . One key can unlock your keypad, one SMS will lock your phone.
With "LockMe" you can easily lock your keyboard and the whole phone. You can set a keypad auto lock period which will prevent the phone from accidental calls.
"LockMe" allows you to choose the most convenient unlock combination for yourself. Nokia users, you can forget now the boring "Unlock" + "*"!
Another feature allows you to set a day period during which the phone will light the display after any key activity. Thus, unlocking keypad in the night will be as easy as in the day.
"LockMe" also provides a way to protect your phone and its data in case you have lost it. By sending one SMS with the last 4 digits of the IMEI and a text, you will lock your phone remotely and the text will appear on the screen. So you can ask the conscientious person that finds the phone to signal you on another address/phone. Or you can use the feature in your own creative way. In case of a going phone call, your SMS will end the call before locking the phone, thus saving you a lot of troubles if the phone has been stolen.
Note: Please make sure you know the device lock code, before sending the lock sms (because you will need it latter to unlock the telefone)
Note: Full contextual help is available.
SMS format:
Code Lock Text
where Code are the last 4 digits of the phone's IMEI code for security reasons. Lock is the command for the phone.Text will be displayed on the phone after the SMS is received.
Example: If you have a device with IMEI 352350-10-248688-8 and you want to display on the phone 'The phone has been forgotten! Please call +1887389675', you should send the following SMS:
6888 Lock The phone has been forgotten! Please call +1887389675
Compatible Devices
Nokia 3230, 6260, 6630, 6680, 6681, 7610, N70
Old 02-20-2006, 16:36   #159 (permalink)
Member: 209644
Thanks Meter: 113
ActivBits.MatchLog.v1.5.0.S60.Cracked
ActivBits' MatchLog is a multi-sport application for keeping track of individual or team matches, storing match information, and providing vital statistics. You can easily follow players’/teams’ wins and losses, evaluate strength based on the winning ratio, create ranking based on earned points, and be better prepared for the next matches.
If you are a sport enthusiast, professional player, amateur, coach, sport-fan, or just want to keep track of your matches, that’s the right application for you!
MatchLog Features
Insert and modify match information
You can add, edit, and delete matches. In each match entry you can store:
opponent name
match score
match time and date
match result (win/loss/tie)
number of earned points
match comments
event info
View sorted matches
Matches and corresponding scores are displayed on the list. A graphical icon beside each match tells you if a match resulted in a win, loss, or tie. When you scroll through the list of matches the corresponding match date is displayed on the bar. For your convenience you can sort the list based on date, result, or opponent name.
Group matches into profiles
Matches are grouped into profiles that allow you to separate matches to different sport categories or different players / teams (in case of group sports). Typically, in each profile you store information about matches of one player / team. For example, you can create a profile for yourself, where you can store information about matches you played. In a separate profile you can store matches of your favorite team. You can add, edit, and delete profiles.
View ranked profiles
Each profile displayed on the list has automatically calculated total number of points earned in the matches. You can sort profiles based on total number of earned points, thus creating ranked profile list. Also you can sort profiles based on profile name or sport category.
Generate statistics
Statistics are generated automatically for each profile and include the following:
profile name
winning ratio
total number of played matches
number of wins
number of losses
number of ties
Trial version contains all features of the full product. You can use application trial version for 15-day trial period for FREE!
History
(updates are FREE of charge and preserve your already existing data)
19.02.2006 MatchLog v1.5.0 has been released.
14.02.2006 MatchLog v1.4.0 has been released.
11.02.2006 MatchLog v1.0.0 has been released.
File Type: rar ActivBits.MatchLog.V 1.5.0.S60.Cracked.rar (25.2 KB, 456 views)
Old 02-20-2006, 16:43   #160 (permalink)
Member: 209644
Thanks Meter: 113
Inventis.AG.mNote.v1.11.S60.SymbianOS 7&8.incl.Keygen-HSpda
Update...
Author's Description
With mNote it is possible to show your last note directly on the desktop (idle screen) of your mobile. Your ideas and thoughts never get lost any more due to the permanent displaying on the desktop. mNote collaborates with the existing note program on your mobile. Every note is stored and read there.
Restrictions: The notes usable for mNote have to be shorter than 128 characters.
Old 02-20-2006, 17:32   #161 (permalink)
Member: 227586
I have a 6682 and I'm running SmartProfiles. I like the app, but it doesnt have one feature that I really wanted. Like on a series 40 nokia phone, I want to be able to select another profile and after a certain time (i.e. 30mins) it goes back to the orginial profile.
I am also looking for an app that has a countdown timer simialar to the on a series 40 nokia as well. An app that I can put in a number (i.e. 45mins) and after that time has passed sound an alarm.
If you know any apps that have these features please let me know.
Lastly, does anyone have VoiceSignal? I love this app as well.
Thanks in Advance.
Old 02-20-2006, 20:46   #162 (permalink)
MisterX GSMFREE's Avatar
Member: 37125
Thanks Meter: 19
I need this Solution FULL Version from http://www.math-solution.com/full/ can you please post this ?
Old 02-20-2006, 21:18   #163 (permalink)
serwo120's Avatar
Member: 175125
Thanks Meter: 8
I hope this is what u want
Solution.Group.Solution.Lite.v1.00.S60.SymbianOS.F reeware
Solution Lite is an easy-to-use program for applying basic mathematics. It can be used for graph plotting and as scientific calculator.
Supported functions
— Standard functions: +, —, /, *, ^, sqrt(x), sin(x), cos(x), tan(x), ctg(x), arcsin(x), arccos(x), arctan(x), arcctg(x) exp(x), log(x), ln(x), abs(x).
Graph Plotter
—Instrument which helps you to create a two-dimensional plot of functions easily and quickly.
Scientific Calculator
— Calculator, which can do real computations
Compatible Devices
Nokia 6260
Nokia 6600
Nokia 6620
Nokia 6630
Nokia 6670
Nokia 6680
Nokia 6681
Nokia 6682
Nokia 7610
Nokia 7650
...ooooOOONokia N-GageOOOoooo...
....////Nokia N-Gage QD////....
..//Nokia N70 //..
Siemens SX1
//ooo//
oo
Old 02-20-2006, 21:25   #164 (permalink)
Member: 37125
Thanks Meter: 19
@Serwo120 thanks but I have this LITE Version allready .
I'am searching the FULL Version .
Old 02-20-2006, 22:26   #165 (permalink)
Member: 118195
Thanks Meter: 2
Hi
I Need ScanR for S60 (6600)
With This, We Can Scan From a Doc by Mobile Camera. (Scan & Copy & Fax)
Thx - RaMiN
""New Java Applications,Symbian Application & More"" saadhome Java, iOS, Android, Symbian development 0 04-15-2009 20:32
Symbian Games 2006 Series 60 Non-3rd Edition dsfugabanjr Nokia Multimedia 38 08-01-2007 17:57
Symbian Games 2006 Series 60 Non-3rd Edition dsfugabanjr Nokia Multimedia 3 11-19-2006 15:00
Free Symbian Applications tha_nox Nokia Multimedia 0 03-07-2006 11:29
Symbian applications,games, java games, ringtones, wallpapers - ALL FREE armkbdotcom GSM Mobile Links 0 09-24-2005 21:29
Page generated in 0.68047 seconds with 10 queries
