02-27-2013, 18:53 | #1 (permalink) |
No Life Poster Join Date: Aug 2012 Location: India Age: 39
Member: 1792140 Status: Offline Sonork: 100.1618782,gaba Thanks Meter: 6,087 | [Guide] sharp pv300 hang on airtyme logo : solution here Upgrade the Software Upgrade the Software First Install Epro Tool in your PC. Power-on the device while holding w key doing this until you enter in recovery screen. It has a menu in the left with languages, a device icon in the center of the screen and Reboot button in the bottom right corner; this is how you know you are in the corresponding screen. 1. Connect the device to the PC with the USB cable. 2. If a driver install dialog appears for "Hiptop Diagnostics" then cancel it and ensure that no other dialogs with driver installation are started. 3. Start EPro from Start -> Programs -> Danger Hiptop -> Epro. 4. Ensure that in the title bar of EPro in the left side at the device indicator you can see [Online]. If you see [Offline] then unplug and plug again the USB cable. 6. From menu select Device -> Flash Image .. and select m3-factory-keyfile-253612_waverley_signed.jar. 7. Wait until the flashing is finished, on the device indicator dialog disappear. 8. Then Flash danger_airtyme_m3_trial-FP_275805.jar 9. Wait until the flashing is finished, on the device indicator dialog disappear. 10. Select REBOOT then unplug the device. https://hotfile.com/dl/182846515/03f...rtyme.rar.html br umesh gaba |
The Following 14 Users Say Thank You to Umesh_Arora For This Useful Post: |
04-14-2013, 23:01 | #2 (permalink) | |
No Life Poster Join Date: Aug 2008 Location: peru
Member: 830163 Status: Offline Sonork: 100.1584058 Thanks Meter: 838 | Quote:
07-22-2013, 04:45 | #4 (permalink) |
No Life Poster Join Date: Aug 2011 Location: caribbean island
Member: 1643797 Status: Offline Thanks Meter: 183 | have this mobile in hand t moble usa which was in offline mood this model pv300 tmobile not airtyme not was hang in airtyme mood now as say here i flash phone and it work i get pass offline mood but my main problem now it this phone was not unlock now trying to unlock phone iam having driver problem iam getting this driver in pc FLAUNT and each time restart phone it start with airtyme logo and this is tmobile . my main point is i think i mess up the phone by doing this and now can't unlock because this seems debrand it are something like that for many days now trying to unlock and can't because of driver problems. software not read code ...FLAUNT driver not work Last edited by Rahul_Bhutani; 03-04-2015 at 13:33. Reason: Big Quote Removed |
04-07-2014, 15:57 | #6 (permalink) |
Freak Poster Join Date: Nov 2012 Location: rewa m.p
Member: 1846157 Status: Offline Sonork: [email protected] Thanks Meter: 25 | help me umesh sir i was install this own pc so 0xc000135 error on rum epro tool help me anybudy Last edited by Rahul_Bhutani; 03-04-2015 at 13:33. Reason: Big Quote Removed |
04-14-2014, 02:30 | #7 (permalink) |
Insane Poster Join Date: Mar 2013
Member: 1900065 Status: Offline Thanks Meter: 3 | How to obtain Epro Tool / flashing options Hi all, Can anyone confirm that the Epro Tool can be used to extract (backup) and then import/flash [i.e. to a Sharp/T-Mobile PV300] the Flaunt, Jump, PV300GC, or PV300GR images? Also, how can the Epro Tool be obtained? I cannot seem to find it anywhere online. Is it instead part of the Flaunt software, activated upon USB connection [as to PC] ??? ~Thanks in advance, carry on then~ Last edited by IceOnMars; 04-14-2014 at 02:36. Reason: modified format |
04-14-2014, 09:04 | #8 (permalink) |
Member: 1900065 Status: Offline Thanks Meter: 3 | Well I have finally been able to download the .rar file, which includes not only the Flaunt software image, but also a few tools and utilities, including EPro! So that's where it is , in case anyone else wonders...you download the .rar, and then unzip it using a compatible zip utility (do a bit of simple research). then you will be able to follow the wonderful guide that has been graciously prepared for us by br umesh gaba! |
