please pinouts cable for flashing gx 29 , user cable nec 3g , problem instaled driver ... thanks |
don't spam the board with FOOLISHNESS the 17 flasher do not work that fuc..rs that say work wasted my time on the forum........ok for the last time flasher do not work maybe they have some nother problem and phone alive but the resason is not flasher ;):D |
tested goooooood woooooork thanks........ |
i need flash sharp gx29 200612 |
Oooooooooooooooohhhhhhhhhhhhhh Please!!!!!!!!!!!!!!!!!!!!!!! Gx17 Doesnīt Work On Gx29!!!!!!!!!! This Is A Waste Of Time!!!!!!!!!!!!!!!!!! U Canīt Flash Fully A Gx29 With Gx17 Flasher Of Platijet!!!!!! |
And this is the Reality ;) Gx17 Flasher not same as Gx29 :D Ask Platijet Why! |
Gx 92 Cable I HAVE MOFIFIED MY CABLE TO MAKE CHRGE MY GX29 BUT WHEN I CONNECT IT TO COMPUTER IT IS CHARGEING AND I CAN SEE THE USB ICON THE DISPLAY BUT THE COMPUTER SAYS UNKNOW DIVICE I TRY TO INSTALL DRIVER BUT WITH NO LUCK WHEN I CONNECT THE PHONE WITH OUT BATTRIES IT SHOW AS A UNKNOWN DEVICE BUT GO OFF WHEN I TRY TO INSTALL DRIVERS WHAT MUST I DO , I HAVE DOWNLOAD THE DRIVERS FOR PHONE IN THIS SITE AND I HAVE DOWNLOAD MODEM DRIVERS BUT CAN T GET PASS UNKNOW DEVICE . HELP HELP :confused::confused::confused::confused::confused: :confused: |
Gx 29 Cable I HAVE MOFIFIED MY CABLE TO MAKE CHRGE MY GX29 BUT WHEN I CONNECT IT TO COMPUTER IT IS CHARGEING AND I CAN SEE THE USB ICON THE DISPLAY BUT THE COMPUTER SAYS UNKNOW DIVICE I TRY TO INSTALL DRIVER BUT WITH NO LUCK WHEN I CONNECT THE PHONE WITH OUT BATTRIES IT SHOW AS A UNKNOWN DEVICE BUT GO OFF WHEN I TRY TO INSTALL DRIVERS WHAT MUST I DO , I HAVE DOWNLOAD THE DRIVERS FOR PHONE IN THIS SITE AND I HAVE DOWNLOAD MODEM DRIVERS BUT CAN T GET PASS UNKNOW DEVICE . HELP HELP :confused::confused::confused::confused::confused: :confused: |
Gx 29 I HAVE FOUND THE SOLUTION I CONNECTED THE D- AND D+ ON THE USB CABLE USB BACK WAYS , NOW I HAVE CONNECT THE PHONE WITHOUT BATTRIES AND INSTALL FLASH DRIVERS :p:p:p:p |
olds scraap but working as well ... |
Solution to unlock Sharp GX29 1 Attachment(s) Hello all I have unlocked a 200606 gx29 from vodafone spain with those files and with the next proedure. So, here we are: Software is the Albelektronik team gx17-gx29 flasher Full flash is here: gx29 and folow the specifications from the atached image. All of you, have to do is flash the phone, without batery, with the files selected, using a NEC E8 cable, just like the specifications from the image. Reply problems... |
i have.GX29 200610.DEAD.I FLASH IT WITH PLATIJIT.RESULT OK.BUT NO TRANSMISSION.HE RESTART IN CALL.CAN SOME ONE HELP ME.OR IF SOME ONE HAVE VODAFONE FILES 200610.THANKS. |
Try to flash your phone completly with the files posted above and might work. I flashed a gx17 200707 with a complete firmware from another gx17 made on 200702 and works. Check if you have the drivers corectly instaled and use the software from albelektronik, may be useful. After that, if you will have the same problem again, send me a ymsg, i will try to help you. |
And where is flasher and drivers??? |
