Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Sharp
Old 08-23-2007, 18:37   #46 (permalink)
SekingServer's Avatar
Member: 565161
Sonork: 100.1585588
Thanks Meter: 44
thank, man very good working
Old 08-23-2007, 18:38   #47 (permalink)
Member: 565161
Sonork: 100.1585588
Thanks Meter: 44
thank, is good, m8
Originally Posted by sokettro View Post
Hello all
I have unlocked a 200606 gx29 from vodafone spain with those files and with the next proedure. So, here we are:
Software is the Albelektronik team gx17-gx29 flasher
Full flash is here: gx29
and folow the specifications from the atached image. All of you, have to do is flash the phone, without batery, with the files selected, using a NEC E8 cable, just like the specifications from the image.
Reply problems...
Old 09-29-2007, 22:02   #48 (permalink)
irfanmajeed's Avatar
Member: 594068
Sonork: 100.1574613
Thanks Meter: 121
Files Selection
I Think For Unlock We Have To Select All Three Files Or Only Unloack Diag.mot Plz Reply Tanx
Old 09-30-2007, 06:24   #49 (permalink)
shahzaadbutt's Avatar
Member: 123458
Sonork: 100.1594535
Thanks Meter: 3,415
to unlock select only Unlock Diaq File, no need to flash all three files
Old 10-03-2007, 20:31   #50 (permalink)
Member: 104927
Thanks Meter: 60
Right shahzaadbutt. But, irfanmajeed, dont forget to make backup of the original software of the phone. In case the unlock by the unlocked diag will not work, you have to flash him completly. I have full flashed, those days, a 200704 gx29 with the firmware from my above link, wich is from 200606 and the phone is working, after trying diferent newer, but not exactly versions of unlocked diags and firmwares. Try it, maibe you will have luck.
Old 10-03-2007, 21:57   #51 (permalink)
bocahklaten's Avatar
Member: 295100
Thanks Meter: 212
thx bro, good job.............
Old 10-11-2007, 06:29   #52 (permalink)
Member: 220595
Thanks Meter: 345
I have the same problem than someone here had, I cant install the driver, it fails on n INF section, I have the original sharp drivers posted here, installed already, the modem has a com port Com19, no prob, but in flash mode the driver doesn't install
any trick ?
Old 10-11-2007, 06:29   #53 (permalink)
Member: 220595
Thanks Meter: 345
How can I make a backup of my phone, just in case I need to restore it ?
any soft for this ?
Old 10-11-2007, 06:48   #54 (permalink)
Member: 220595
Thanks Meter: 345
damn, cant update post
I cant Edit my own post past 10 minutes, sh*t
Well, I pointed the hardware wizard to the folder where the original sharp drivers were installed, at program files\SHARP....drivers\win2000
the installation sarts, but makes the same error on the Inf Section.
any hint ?
Originally Posted by kasamiko View Post
Used the FULL Driver installer not the one in the folder with just 2 files..
This One
any trick ?
Old 10-11-2007, 07:55   #55 (permalink)
Member: 80599
Sonork: 1621236
Thanks Meter: 273
sharp usb driver good
any hint ?
Her frend and dont forget to copy past gxdlusb to c:windows/system32/driver
then go install driver manually your pc must ask u 4 driver gx xx twis 2 time
good luck
The Following 2 Users Say Thank You to ramoon20 For This Useful Post:
Old 10-11-2007, 09:04   #56 (permalink)
Member: 220595
Thanks Meter: 345
Yes, I had figured out that already, thanks anyways
Thats what I did that make it work, I copied the .sys file to the system32\drivers directory and tried to intall the driver included on the Drivers folder which comes on the Flasher Archive, and it got intalled.
For thos of you who may be scared because of the phone disconnecting and connecting itself, dont worry, when the flasher start to read or write the phone it wont happen again until it finishes, this is confirmed 100% to be true
I figured out also that the same software do Reads the FW, FS and Diag, so I read a full backup just inc ase.... and I needed !!!
I flashed the unlocked Diag of the posted 200606 archive on my 200604 phone, and after finish it, result: Phone Dead, so, be careful !!
I just flashed back the original Diag and phone came back to life, so: BACKUP BEFORE FLASHING ANYTHING, YOU HAVE BEEN WARNED
Then I flashed all the stuff, Program(FW), Filesystem(FS) and the Diag included on the archive, and all worked nice, phone is now UNLOCKED.
Good luck
just my .2 cents
Old 10-11-2007, 13:32   #57 (permalink)
Member: 104927
Thanks Meter: 60
Good luck
just my .2 cents
The best explanation, from someone who knows how to do it. For the people who are asking for the procedure, this post is the best to describe it. I have to learn english and to be a good teacher, to do this the same like @yurays. Thanks for the good intention and for the veto of the procedure.
Old 11-19-2007, 16:02   #58 (permalink)
Member: 297718
Thanks Meter: 4
thank's verry much ...................
Old 11-27-2007, 20:45   #59 (permalink)
Member: 627068
Thanks Meter: 6
someone can help me i have a gx17 dead in start ng, i have a gx17 flasher by platijet v8.0 but i dont know use it
can i help me?
Old 11-27-2007, 21:22   #60 (permalink)
Member: 627068
Thanks Meter: 6
the computer not find the phone
sharp gx29 flash ok not power on Formingus Sharp 31 06-02-2014 19:16
sharp gx29 flash ok not power on Formingus Sharp 1 02-20-2007 12:26
I am lookinf for GX29 flash + flasher !! makroud Sharp 13 02-19-2007 14:16
Sharp Gx29 Flash Procedure yoni93320 Sharp 11 02-08-2007 16:14
Page generated in 0.22365 seconds with 10 queries
