help for 550sh dead he bro help me for my sharp 550sh dead when my friend remove battry where phone in charge . what solution and whicht best box to flash this phone . thank's |
Check the fuse with multimeter, replace it if faulty. The fuse is the small black one below the battery connections. I have fixed many dead sharp by replacing the fuse. There is no box that can flash this model at the moment. I hope this helps. Please post result. Good luck. |
please can you give picture because i never fixed some problem thank`s griff26 lahdache |
just heat it ; you may not get the F.Files |
sharp 550sh fuse 1 Attachment(s) Here is a picture of the fuse. Replace it if you have spare part or you can remove it and join both sides with solder. That should work.:) |
hello I have a 550sh dead, and i bridged the fuse but it doesn't work. Is it dead forever? thanks |
