02-16-2006, 16:45 | #1 (permalink) |
Junior Member Join Date: Feb 2006
Member: 233689 Status: Offline Thanks Meter: 0 | GX25 SIM MEP Problem I tried to unlock a Sharp GX25 with SHARParm.exe (that one that unlocks the mobile by bluetooth). The four *'s appeared and i completed the process sucessfully (i thought...lol). The problem is that now when i turn on the phone with the SIM inside it says something like SIM MEP Fail! The Phone was locked to SFR - France! I really don't know what else to do...please help! With best regards, r3d0x P.S:Sorry for the bad english...i'm portuguese! |
02-18-2006, 23:57 | #4 (permalink) |
Member: 233689 Status: Offline Thanks Meter: 0 | No problem! CAUTION: I take no responsabilities of the procedure here described! In simple steps: (NOTE: Be sure you have the battery with enough charge) 1 - Connect your Sharp GX25 Bluetooth with your computer with the SIM Card on it. 2 - Shutdown the mobile and remove SIM Card and power on the phone with no SIM Card. 3 - You'll see that the Bluetooth Icon is still active besides of the message "Insert SIM Card". 4 - Open the SHARParm.exe and select the COM that your bluetooth dongle on the computer is using (Bluetooth Serial port COMx - where x is the number to select). 5 - Select the Option "Liberar Gx15 / Gx30" and click on the Apply Button. 6 - When the process is done the phone will restart and 4 * will appear on the screen (don't worry...it's Diagnosis Mode). Now you have to follow these steps: Press 1 Press 99 Press the Right Select Key Press 3 Press the Right Select Key Press 1 You will see: EE_FORMAT START DIAG_FORMAT START DIAG_FORMAT OK FINISHED PRESS ANY KEY Press 2 times the Right Select Key Press 08 Press the Right Select Key Press 1 Press the number of your operator (ex: Vodafone Portugal is 48...i don't have the list of all operators :s but i think that the one that apears by default is the correct one) Press 2 times the Joystick Key Press 0 Press 0 Press the Right Select Key Press 1 (The Flag "1.Product Flg: ON" goes OFF) Press the Joystick Key Press the Right Select Key (The Phone will shutdown) Done! =D |
05-26-2006, 00:33 | #7 (permalink) |
Junior Member Join Date: May 2006
Member: 282910 Status: Offline Thanks Meter: 0 | can't find the SHARParm.exe file Hi. My bluetooth is not working, always that i try to send a file to the pc or vice, the phone displays "failure" I've tried to do the procedure but i can't find or i don not know where this file "SHARParm.exe" is !! Can you give me a clue ? thanks a bunch. John |
Gx10 Invalid network sim and sim mep | Keke | Sharp | 4 | 12-11-2004 08:45 |
Gd55: Sim Mep Lock | dannyogolo | Panasonic | 1 | 10-28-2003 19:40 |
"GD55 SIM MEP Lock Failed" Solution | datalife2000 | Panasonic | 13 | 10-20-2003 00:55 |
GD55 SIM MEP Lock Failed | jerrel | Panasonic | 5 | 05-04-2003 01:32 |
