Solution for GX15 and Furious cracked I need solution for unlocking GX15 with Furious ckracked......what kind of cable i must use for???? Thanks !!! |
i use the nec cable n21i....is on usb |
what is the sofe ware called to use the thing what does the gx15 look like |
@all thanks problem solved !!! |
Dont forget install the drivers first and next run program, if you donīt do this the phone donīt enter in test mode. |
gx15 unlock uses powered com cable on furious crack not usb |
but i am using nec cable and its working fine tested on many pcs............ :rolleyes: |
u can use Original USB cable or Nec USB cable |
you can use nec cable an soft for furios cracked ! works 100% Dont forgert to install drivers and check on what com port is using the phone ! |
How to unlock GX15 & GX25 Simple! No you can not unlock GX15 with com port, simply aply GX15 drivers then connect the handset powered on to Sharp or Nec Geniune or Generic USB cable,computer will find new hardware and will apply the drivers you installed previously (just follow the on-screen instructions),once done then open Furious cracked Sharp software select GX15 then select new com port(not com 1,2 or 3) which will be there if drivers were installed correctly then simply click unlock. Job Done.Once mastered it should take only 2/3 min to unlock!(Same procedure for GX25.Don't use this way to unlock GX30 & TM100,if you need to know how to unlock those models please ask). Regards MFC |
but driver instaled on com 27 have an idea |
Sharp Unlock= Gx15/25=usb Gx30/tm100=com |
:D :D Quote:
ENJOY :D |
