Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Sharp
Old 01-18-2005, 14:15   #1 (permalink)
Bohosh's Avatar
Member: 14741
Thanks Meter: 119
Solution for GX15 and Furious cracked
I need solution for unlocking GX15 with Furious ckracked......what kind of cable i must use for????
Thanks !!!
Old 01-18-2005, 15:26   #2 (permalink)
OvidelGSM's Avatar
Member: 103544
Sonork: 100.75677
Thanks Meter: 155
Old 01-18-2005, 15:28   #3 (permalink)
OvidelGSM's Avatar
Member: 103544
Sonork: 100.75677
Thanks Meter: 155
i use the nec cable n21i....is on usb
Old 01-18-2005, 17:03   #4 (permalink)
Member: 107361
what is the sofe ware called to use the thing what does the gx15 look like
Old 01-18-2005, 19:25   #5 (permalink)
Bohosh's Avatar
Member: 14741
Thanks Meter: 119
@all
thanks problem solved !!!
Old 02-03-2005, 12:53   #6 (permalink)
Member: 59441
Thanks Meter: 9
Originally Posted by Bohosh
@all
How did solve your Gx 15 problem?
Old 02-03-2005, 14:14   #7 (permalink)
Member: 85718
Thanks Meter: 173
Dont forget install the drivers first and next run program, if you donīt do this the phone donīt enter in test mode.
Old 02-03-2005, 14:42   #8 (permalink)
jusluke's Avatar
Member: 26867
Thanks Meter: 3
k
gx15 unlock uses powered com cable on furious crack not usb
Old 02-03-2005, 14:49   #9 (permalink)
AWAIS's Avatar
Member: 16520
Sonork: 1580837
Thanks Meter: 90
but i am using nec cable and its working fine
tested on many pcs............
Old 02-03-2005, 15:05   #10 (permalink)
galaxi's Avatar
Member: 5915
Thanks Meter: 6
u can use Original USB cable or Nec USB cable
Old 02-03-2005, 15:57   #11 (permalink)
Ciubaka's Avatar
Member: 42304
Thanks Meter: 12
you can use nec cable an soft for furios cracked ! works 100%
Dont forgert to install drivers and check on what com port is using the phone !
Old 02-03-2005, 17:45   #12 (permalink)
MFC
MFC's Avatar
Member: 83741
Sonork: 100.1624702
Thanks Meter: 88
Thumbs up How to unlock GX15 & GX25 Simple!
No you can not unlock GX15 with com port, simply aply GX15 drivers then connect the handset powered on to Sharp or Nec Geniune or Generic USB cable,computer will find new hardware and will apply the drivers you installed previously (just follow the on-screen instructions),once done then open Furious cracked Sharp software select GX15 then select new com port(not com 1,2 or 3) which will be there if drivers were installed correctly then simply click unlock. Job Done.Once mastered it should take only 2/3 min to unlock!(Same procedure for GX25.Don't use this way to unlock GX30 & TM100,if you need to know how to unlock those models please ask).
Regards
MFC
Old 02-03-2005, 21:26   #13 (permalink)
Member: 4610
Thanks Meter: 3
but driver instaled on com 27 have an idea
Old 02-03-2005, 21:32   #14 (permalink)
taopheek's Avatar
Member: 44566
Thanks Meter: 7
Sharp Unlock= Gx15/25=usb
Gx30/tm100=com
Old 02-03-2005, 21:34   #15 (permalink)
taopheek's Avatar
Member: 44566
Thanks Meter: 7
YES THAT WOT U R GONNA USE IT COULD 20ANYTHING BUT DEFINITELY NOT 1,2,OR 3
ENJOY
Solution for unlock and IMEI change for few new Motorola phones Denis Main Sales Section 0 11-23-2009 15:50
Solution for unlock and IMEI repair for few new Motorola phones Denis Main Sales Section 0 11-09-2009 23:27
solutions for restarts and hang for nokia 5310 xpress music delchoni Nokia Hardware & Hardware Repair 2 02-21-2009 11:41
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.17845 seconds with 8 queries
