VLSI, Conexant, Skyworks and Old Models Old Models: SGH-600, SGH-2400, SGH-2200, SGH-2100, SGH-500, SGH-250, SGH-810, SGH-800. VLSI: A200, A208, A800, N100, N200, N288, N300, N400, N500, N600,N611, N620, N625, N628, R200, R201, R208, R210, R220,R225, T100, T108, T400, T408, T410, T500, T508. Conexant: A100, A110, A118, A300, A308, A400, A408 M100, T200, T208. Skyworks: A500, C100, C108, C110, P510, P518. |
01-09-2002, 00:23 | #1 (permalink) |
Crazy Poster Join Date: Nov 2001 Location: Portugal
Member: 7425 Status: Offline Thanks Meter: 0 | 100% working solution for Samsung R200/210s 1- Buy a connector (in Europe you can buy it at <a href="http://www.resolv-info.com)" target="_blank">http://www.resolv-info.com)</a> 2- Download IC-Prog at <a href="http://www.ic-prog.com" target="_blank">http://www.ic-prog.com</a> (this is a Ponyprog clone or vice-versa) 3- Build the schematics at <a href="http://members.tripod.com/vio_man/r-2xx.gif" target="_blank">http://members.tripod.com/vio_man/r-2xx.gif</a> 4- After you done all this, you can plug the "home made" cable to your phone. In the schematics picture says to read without the battery. Try to read with both ways (with and without battery) and see what way works for you.<br /> <br />5- Now you can use IC-Prog to read the phone's EEPROM. Configure the program to use JDM programmer in your COM port and select the EEPROM type as I2C -> 24c256<br />Of course, I will not teach you how to work with the program!<br /> <br />6- Now you must use the Samsung Code Reader 3.5a (SCR) or later available at <a href="http://clientes.netvisao.pt/jorgef04/index.html" target="_blank">http://clientes.netvisao.pt/jorgef04/index.html</a><br /> <br />7- On SCR select R200/210 for R200, and R200/210 or R210 for R210s. <br />N.B. Sometimes generated codes won't work with Samsung R210s, but most times they will.<br />For R210s you must try the two ways in the Samsung Code Reader: R200/210 or R210.<br />If your R210s don't accepts the codes, don't worry, Pajo is currently working on a solution it will be available in the next SCR release.<br /> <br />Violator(c), 2002 - Portugal |
01-09-2002, 01:31 | #2 (permalink) |
No Life Poster Join Date: Jul 2001 Location: Planet earth
Member: 5169 Status: Offline Thanks Meter: 684 | if dont aceppt the codes and say not personilize put this<br />#0151*first code read wahit pajo 3.5#<br />and voila the function is despersonolize<br />best regards<br />DUSKnenixs<br />PORTUGAL rullezzzz |
01-09-2002, 01:57 | #3 (permalink) |
Freak Poster Join Date: Nov 1999 Location: Osaka, Japan
Member: 696 Status: Offline Thanks Meter: 0 | And if your phone says "Illegal operation", just turn it off and leave it for a minute, turn on and type the code...that's all...Recomended external voltage for eeprom reading - 2,4V. MASHCO <img src="wink.gif" border="0"> |
01-09-2002, 04:32 | #4 (permalink) |
No Life Poster Join Date: Nov 2000 Location: EGYPT Age: 44
Member: 2583 Status: Offline Sonork: 100.88702 Thanks Meter: 203 | HI , <br />i tried all codes with all #XXX and *XXX in R210 without success !!<br />is it new ???<br />plz somone write here al codes if all failed<br />so its new version or can't unlock it .. !! |
01-09-2002, 15:46 | #5 (permalink) |
Member: 7425 Status: Offline Thanks Meter: 0 | If your phone does not accepts the code, just enter this code: *2767*2878# (Custom EEPROM reset) and try again Also, why reading the EEPROM with 2,4V? I think it reads with 3V... |
01-09-2002, 16:26 | #7 (permalink) |
Member: 7425 Status: Offline Thanks Meter: 0 | gsnbhagawan: Have you read your phone's EEPROM with 3V or other voltage? To unlock Samsung M100 by code: <a href="http://codedata.box.sk/mobile.box.sk/rylm1mp3.zip" target="_blank">http://codedata.box.sk/mobile.box.sk/rylm1mp3.zip</a> |
01-10-2002, 09:33 | #8 (permalink) |
Insane Poster Join Date: Jul 2001 Location: holland
Member: 5118 Status: Offline Thanks Meter: 0 | i use ic proggie it read the R210 all works fine<br />but all i cet are zero's on sreen ( 0 )i use 3 volt and 2,5 volt to read the processor<br />whar i am doing wrong can anybody help me thanks [email protected] |
01-10-2002, 10:26 | #9 (permalink) |
Freak Poster Join Date: Apr 2001 Location: uk
Member: 3995 Status: Offline Thanks Meter: 0 | aj1rtd,the thing your doing wrong is NOT USING YOU CLIP TO UNLOCK IT................ =====DEAD MAN INC===== <br /> <img src="redface.gif" border="0"> <img src="redface.gif" border="0"> <img src="redface.gif" border="0"> <img src="redface.gif" border="0"> <img src="redface.gif" border="0"> |
01-10-2002, 15:03 | #12 (permalink) |
Member: 3995 Status: Offline Thanks Meter: 0 | pico,youve got more chance of platting fog m8 than asking that guy for anything free....... ALL THE BEST!!!!!!!!! =====DEAD MAN INC===== p.s i asked for t20 unlock clip hex and scheme from him,he will probably direct you to his site... <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0"> |
01-10-2002, 18:09 | #13 (permalink) |
Member: 2583 Status: Offline Sonork: 100.88702 Thanks Meter: 203 | Hi , <br />i tried custom eeprom reset then re-try entering code <img src="frown.gif" border="0"> !! without succcess ..<br />illegal operation with #0111*code#<br />not personalized Yet with any code else ... i read 2.4V and eepprom is looks like good but with battery it read another eeprom but not looks like working one ..<br />with 3V too . <br />so i think 2.4 is better<br />but i still can't unlock my R210S why !!<br />- how to know the eeprom i read is 100% readed good ????<br />- i thought that i can write anoter R210S eeprom then unlock it ... but i tried write using ic prog without success ... why can't write ? and this eeprom clonable ? - some friends says they remove eeprom .. i tried find eeprom 24XXX on phone board and nothing there ... i think it emulated or there is 2 kind of boards ? |
01-10-2002, 22:38 | #14 (permalink) |
Member: 7425 Status: Offline Thanks Meter: 0 | Hi Makona: First enter *2767*2878# to reset your EEPROM. Then read it with 3V (use two 1.5V cells), WITHOUT THE BATTERY. Try to enter the code using #0151*code# if #0111*code# fails. It should work fine. N.B. Read the instructions on the schematics picture |
01-11-2002, 00:29 | #15 (permalink) |
Member: 2583 Status: Offline Sonork: 100.88702 Thanks Meter: 203 | Vio ....<br />thnx for replay friend ..<br /><a href="http://members.tripod.com/vio_man/r-2xx.gif" target="_blank">http://members.tripod.com/vio_man/r-2xx.gif</a><br />nothihng there .. empty page !! i'll try to read it as u told me and tell results here ... |
Here's 100% working solution for SONY Cmd C-5 | Brka | Various | 3 | 04-20-2006 14:36 |
100% working solution for eclispe 450 | buschell | Mitsubishi | 5 | 03-25-2005 18:21 |
100% working solution for C55 (micron) | sloper | E-Gold Based Phones | 42 | 06-10-2003 18:24 |
Any Solution for SAMSUNG R200 ???? | valdeira | VLSI, Conexant, Skyworks and Old Models | 0 | 08-12-2001 19:47 |
I'd like to buy 100% working solution for 8210 | beginer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-19-2000 23:46 |
