VLSI, Conexant, Skyworks and Old Models Old Models: SGH-600, SGH-2400, SGH-2200, SGH-2100, SGH-500, SGH-250, SGH-810, SGH-800. VLSI: A200, A208, A800, N100, N200, N288, N300, N400, N500, N600,N611, N620, N625, N628, R200, R201, R208, R210, R220,R225, T100, T108, T400, T408, T410, T500, T508. Conexant: A100, A110, A118, A300, A308, A400, A408 M100, T200, T208. Skyworks: A500, C100, C108, C110, P510, P518. |
01-15-2002, 22:30 | #1 (permalink) |
Crazy Poster Join Date: Nov 2001 Location: Portugal
Member: 7425 Status: Offline Thanks Meter: 0 | Cannot read R210S EEPROM (only zeros) - NEED HELP! Thanx. |
01-16-2002, 22:39 | #3 (permalink) |
Junior Member Join Date: May 2001 Location: Eindhoven/Netherlands
Member: 4575 Status: Offline Thanks Meter: 0 | Hi, I have unlocked 8 r210s til now by eeprom.<br />I read all bin-files throug phone-connector, and also desoldered all eeproms and read with ponyrog. All files are compared, and matched 100 %.<br />But i use 3.6 volt, when i use 3V somtimes all 0000000, or don't bin don't match with one read direct on eeprom. You can also try settings for windows direct I/O, to API and vice versa. Battery must be remove before reading !! |
01-16-2002, 22:56 | #4 (permalink) |
Member: 7425 Status: Offline Thanks Meter: 0 | I tried different settings (I/O, API) and still reads empty EEPROM. I don't have a 3,6V DC source. I used 2 1,5V batteries. I think I must buy the factory cable available at ******'s. |
01-20-2002, 11:26 | #9 (permalink) |
Freak Poster Join Date: Sep 2000 Location: Hungary Age: 46
Member: 2208 Status: Offline Thanks Meter: 1 | i use simple easy ic2 cable, connent to lpt port !!!!<br />i connent 3 cable to phone pin: 8-gnd<br />12-scl<br />13-sdl i read with ponyprog2000, phone is on!!!With own battery. this is the simple way, i think.<br />after use payo's reader, to open bin. dollyb here is the scheme:<br /><a href="http://briefcase.yahoo.com/dollybgsm/nokia/" target="_blank">http://briefcase.yahoo.com/dollybgsm/nokia/</a><br />cs repairer+cable.zip |
01-20-2002, 23:43 | #10 (permalink) |
Member: 7425 Status: Offline Thanks Meter: 0 | I know why IC-Prog read only zeros on the EEPROM dump. The pinout on the I2C cable schematics image is wrong (should be left to right, and not right to left). Here is the updated image:<br /><a href="http://members.tripod.com/vio_man/r-2xx.jpg" target="_blank">http://members.tripod.com/vio_man/r-2xx.jpg</a> |
01-21-2002, 21:15 | #12 (permalink) |
Member: 2208 Status: Offline Thanks Meter: 1 | With lpt easy ic2 cable + ponyprog!!!!<br />solution is 1000000000000% phone pin 8-gnd<br />12-scl<br />13-sda or 8-gnd<br />12-sda<br />13-scl i dont remember, but it works, pone is on, and read!!!!!If you had eeprom dump, calculate nck with payos soft. dollyb |
01-22-2002, 12:53 | #14 (permalink) |
Member: 2208 Status: Offline Thanks Meter: 1 | Here is it the schema: enjoy!! <a href="http://briefcase.yahoo.com/bc/dollybgsm/" target="_blank">http://briefcase.yahoo.com/bc/dollybgsm/</a> in nokia folder(csrepairer+cable) download dollyb |
problem read user code from E6 need help | msantar | Smart-Clip | 1 | 02-05-2009 13:50 |
V6 dead cannot put unit in boot mode need help | kungpaoski | Smart-Clip | 2 | 02-05-2008 10:47 |
QteK SV10A only boot need help | ba7bou7a | HTC & PDA WM( With Touchscreen) | 3 | 10-03-2006 13:48 |
help r210 eeprom read | Blueman1 | VLSI, Conexant, Skyworks and Old Models | 2 | 07-25-2003 14:31 |
r210 eeprom content urgently needed | chrisro | VLSI, Conexant, Skyworks and Old Models | 0 | 12-14-2001 23:38 |
