Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > VLSI, Conexant, Skyworks and Old Models
VLSI, Conexant, Skyworks and Old Models Old Models: SGH-600, SGH-2400, SGH-2200, SGH-2100, SGH-500, SGH-250, SGH-810, SGH-800.
VLSI: A200, A208, A800, N100, N200, N288, N300, N400, N500, N600,N611, N620, N625, N628, R200, R201, R208, R210, R220,R225, T100, T108, T400, T408, T410, T500, T508.
Conexant: A100, A110, A118, A300, A308, A400, A408 M100, T200, T208.
Skyworks: A500, C100, C108, C110, P510, P518.
Old 07-04-2006, 11:06   #1 (permalink)
Member: 101863
Unlocking T319 anyone????
Hello there, can anyone please tell me is it possible to unlock this model with any kind of software or box, I'd prefer Saras Box and HWK.
Thanks in advance
Old 07-05-2006, 21:19   #2 (permalink)
MR PROTEC's Avatar
Member: 86655
Thanks Meter: 385
Thanks in advance
Software: T319UVFD4
Hardware: REV1.0A0
IMEI: XXXX-XX-XXXXX
Key M: 79843320, 1
Key 2: 63650170, 00000000
Key 3: 00000000, 00000000
Key 4: 00000000, 00000000
Key 5: 00000000, 00000000
Key 6: 00000000, 00000000
Key 7: 00000000, 00000000
Key 8: 00000000, 00000000
YES WORKING WITH ANY SARAS SOFT
USE X600 OR X620 OR X640
SALAM
Old 07-05-2006, 21:24   #3 (permalink)
Mr/konsowa's Avatar
Member: 84100
Thanks Meter: 69
Originally Posted by MR PROTEC
Software: T319UVFD4
Hardware: REV1.0A0
IMEI: XXXX-XX-XXXXX
Key M: 79843320, 1
SALAM
good work Mr/۞ þŘόŤỄç ۞
Old 07-11-2006, 02:56   #4 (permalink)
Member: 222180
thanks dude! very helpful! had also t319 here and it really really works!
Old 07-11-2006, 16:48   #5 (permalink)
MR PROTEC's Avatar
Member: 86655
Thanks Meter: 385
any time bro
Old 07-16-2006, 00:40   #6 (permalink)
Member: 312264
[EDITED]:
Answered my own question:
1. Put a non-T-Mobile SIM in, turn on phone, "Wrong Card" message;
2. #7465625*638*[UNLOCK CODE]#;
3. Reboot phone;
4. *#7465625# to check Network LOCK Status
Can you please tell me how to enter the unlock code? I had an unlock code from T-Mobile, it says #0111*[unlock code]# then press SEND, but I then get the error message as "Please wait network action", then "Unable to process request", seems like it is trying to make a phone call.
Software: T319UVFD4
Hardware: REV1.0A0
IMEI: XXXX-XX-XXXXX
Key M: 79843320, 1
SALAM
Old 07-16-2006, 16:09   #7 (permalink)
MR PROTEC's Avatar
Member: 86655
Thanks Meter: 385
DID YOU TRIED ANY CODE BEFOR YOU RECIVED YOUR COD FROM T-Mobile ??
COZ I THINK YOU NOW NEED MAKE DIRECT UNLOCK BY CABLE
GOOD LUCK
Old 07-18-2006, 19:59   #8 (permalink)
Member: 314062
Smile Noob needs help with t319!
Hi All!
I am totally new to this whole thing. I have no cables or knowledge on how to unlock this or any other phone for that matter. I recently purchased this phone as a replacement for my wife's broken LG phone. I paid some guy on ebay for the SIM unlock code, which works, but has to be unlocked every time the phone is powered off and back on. We are subscribed with Cingular. This was a tMobile To Go phone. I have tried contacting Cingular so that I can get this thing to work with their system, but they don't have this model. They did try to help, but no luck. I can make and receive calls, but no internet access. I don't know anything about any of this.
If anyone can help, it would be greatly appreciated!
Old 09-07-2006, 20:39   #9 (permalink)
toptro's Avatar
Member: 74438
Thanks Meter: 4
Super ! thanks a lot
Old 09-20-2006, 09:09   #10 (permalink)
Member: 124943
Sonork: 100.1573954
Thanks Meter: 19
any body can unlock t309 unlock ????????
Old 09-20-2006, 09:21   #11 (permalink)
Crazy Poster
Member: 159859
read codes with ufsxsamsung, x600 model
3. Reboot phone;
Old 09-24-2006, 19:18   #12 (permalink)
Member: 206846
can anyone change samsung t319 to 900/1800mhz band? please help!!
thanks !
Old 10-20-2006, 05:43   #13 (permalink)
Member: 374053
thanks !
t319 works only on 850,1800,1900mhz
you can try this code
*#8999*8378#
then press 5 and choose what band selecton you like.
Old 10-20-2006, 05:45   #14 (permalink)
Member: 374053
more t319 secret codes
*2767*688# = Unlocking Code (May not work on your phone)
*#8999*8378# = All in one Code
*#4777*8665# = GPSR Tool
*#8999*523# = LCD Brightness
*#8999*3825523# = External Display
*#8999*377# = Errors
#*5737425# = JAVA Something{I choose 2 and it crashed}
*#2255# = Call List
#*536961# = Java Status Code
#*536962# = Java Status Code
#*536963# = Java Status Code
#*53696# = Java Status Code
#*1200# = AFC DAC Val
#*1300# = IMEI
#*1400# = IMSI
#*2562# = ??? White for 15 secs than restarts.
#*2565# = Check Blocking
#*3353# = Check Code
#*3837# = ??? White for 15 secs than restarts.
#*3849# = ??? White for 15 secs than restarts.
#*3851# = ??? White for 15 secs than restarts.
#*3876# = ??? White for 15 secs than restarts.
#*7222# = Operation Type (Class C GSM)
#*7224# = I Got !! ERROR !!
#*7252# = Operation Type (Class B GPRS)
#*7271# = Multi Slot (Class 1 GPRS)
#*7274# = Multi Slot (Class 4 GPRS)
#*7276# = Dunno
#*7337# = EEPROM Reset (Unlock and Resets Wap Settings)
#*2787# = CRTP ON/OFF
#*3737# = L1 Dbg data
#*5133# = L1 Dbg data
#*7288# = GPRS Attached
#*7287# = GPRS Detached
#*7666# = SrCell Data
#*7693# = Sleep Act/DeAct (Enable or Disable the Black screen after doing nothing for a while)
#*7284# = Class : B,C or GPRS
#*2256# = Calibration Info
#*2286# = Battery Data
#*2527# = GPRS Switching (set to: class 4, class 8, class 9 or class 10)
#*2679# = Copycat feature (Activate or Deactivate)
#*3940# = External loop test 9600 bps
#*4263# = Handsfree mode (Activate or Deactivate)
#*4700# = Half Rate (Activate or Deactivate)
#*7352# = BVMC Reg value
#*8462# = Sleeptime
#*2558# = Time ON
#*3370# = EFR (Activate or Deactivate)
#*3941# = External looptest 115200 bps
#*5176# = L1 Sleep
#*7462# = SIM phase
#*7983# = Voltage/Frequenci (Activate or Deactivate)
#*7986# = Voltage (Activate or Deactivate)
#*8466# = Old time
#*2255# = Call ???
#*5187# = L1C2G trace (Activate or Deactivate)
#*5376# = ??? White for 15 secs than restarts.
#*6837# = Official Software Version
#*7524# = KCGPRS
#*7562# = LOCI GPRS
#*7638# = RLC allways open ended TBF (Activate or Deactivate)
#*7632# = Sleep mode Debug
#*7673# = Sleep mode RESET
#*2337# = Permanent Registration Beep
#*2474# = ???
#*2834# = Audio Path
#*3270# = DCS support (Activate or Deactivate)
#*3282# = Data (Activate or Deactivate)
#*3476# = EGSM (Activate or Deactivate)
#*3676# = Flash volume formated
#*4760# = GSM (Activate or Deactivate)
#*4864# = Dunno doesn't work on newer versions
#*5171# = L1P1
#*5172# = L1P2
#*5173# = L1P3
#*7326# = Accessory (I got Vibrator)
#*7683# = Sleep variable (Cool
#*7762# = SMS Brearer CS (Activate or Deactivate)
#*8465# = Time in L1
#*9795# = wtls key
#*2252# = Current CAL
#*2836# = AVDDSS Management (Activate or Deactivate)
#*3877# = Dump of SPY trace
#*7728# = RSAV done# (Everything went to standart but nothing was deleted)
#*2677# = ARM State (None or Full Rate)
*#8999*636# = Have no clue what it is, i see 20 lines
*#9999# = Software version
*#8999*8376263# = HW ver, SW ver and Build Date
*#8888# = HW version
*#8377466# = Same HW/SW version thing
__________________
Old 05-07-2007, 05:54   #15 (permalink)
Member: 421415
Thanks Meter: 19
[quote=agronx;1852370]Hello there, can anyone please tell me is it possible to unlock this model with any kind of software or box, I'd prefer Saras Box and HWK.
Thanks in advance[/quote
1st Make Full Eprom Reset *2767*3855#
After Rebooting Mobile
then enter...
*7465625*638*00000000*00000000# (to change NCK code to 00000000)
then enter...
#7465625*638*00000000# (to permanently unlock the phone)
check the lock status...
*#7465625#
Tested by me 100% working!!!!!!!!
[IMG] code is Off
I can't unlock T319 and A237 makroud SRS (Simlock Remote Server) 1 02-15-2010 10:20
unlocking T319,t809,t309,etc everblue UST Pro II 20 12-06-2007 03:39
How to unlock T319? EL_DIABLO NSPRO 0 12-04-2006 10:29
Anyone unlocking t319? erickxson NSPRO 1 07-22-2006 02:00
Unlock 3330? Anyone did it? laxxe Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-16-2001 19:45
Page generated in 0.37676 seconds with 9 queries
