samsung sgh600 i have no reception on any network help me please someone regards faz |
can you tell me how to unlock sgh600???? |
using software via the imei regards faz |
via imei regards faz |
i already tried but i can't put last digit and the phone then respost not yet personalised can you help me |
what software are you using? faz |
i'm using sgh600 unlocker that program has a large button saing MAKE-THIS can you send me information about this 10x |
SAMSUNG SGH-600 SECRET CODES ============================ *#06# -> Show IMEI *#9999# -> Show Software Version *#0001# -> Show Serial Parameters *2767*3855# -> Full EEPROM Reset ( THIS CODE REMOVES SP-LOCK!!!! but also change IMEI to 447967-89-400044-0, you must use CHGIMEI to restore it) *2767*2878# -> Custom EEEPROM Reset *#9998*228# -> Battery status (capacity, voltage, temperature) *#9998*246# -> Program status *#9998*289# -> Change Alarm Buzzer Frequency *#9998*324# -> Debug screens *#9998*364# -> Watchdog *#9998*377# -> EEPROM Error Stack *#9998*427# -> Trace Watchdog *#9998*523# -> Change LCD contrast *#9998*544# -> Jig detect *#9998*636# -> Memory status *#9998*746# -> SIM File Size *#9998*778# -> SIM Service Table *#9998*785# -> RTK (Run Time Kernel) errors *#9998*786# -> Run, Last UP, Last DOWN *#9998*837# -> Software Version *#9998*842# -> Test Vibrator *#9998*862# -> Vocoder Reg *#9998*872# -> Diag *#9998*947# -> Reset On Fatal Error *#9998*999# -> Last/Chk *#9998*9266# -> Yann debug screen (=Debug Screens?) By Keypad! GOODLUCK! |
this version doesn accept the code can somebody help me????? |
Mail me to [email protected] if you want solution via EEPROM!!! |
can somebody help me?????[/B][/QUOTE] Send me dump eeprom and I send you unlock code for your phone. |
How can you read that eeprom ( pins 1,2 seems to go to pin 8 not to gnd ) ? |
can anyone help with my no reception on any network!!!!! please someone regards faz |
Somebody said that you can use a data cable to read EEPROM. I have a cable schem with lines named GND? SCL , SDA , like pin 5 an pin 6. You have to dessolder the 24CXX in order to read it with PonyProg, very hard. |
