Trident/AGERE Platform C200, C210, C225, C230, D100, D410, D415, D418, D428, D520, D825, D710, D720, D730, E105, E300, E310, E315, E316, E318, E360, E400, E530, E600, E608, E610, E620, E650, E658, E710, E715, E718,E720, E728, E750, E770, E810, E818, E850, E860, E880, Q100, Q105, Q200, Q300, Q400, Q605, I700, N700, P100, P108, P400, P408, P710, P718, P720, P730, P738, P777, S100, S105, S108, S200,S 208,S300, S300m, S341, S342, S400, S400i, S410i, S500i, V100, V200, V205, V208, VE888 , X105, X120, X130, X140, X150, X200, X400, X408, X426, X430, X438, X450, X458, X480, X610, X630, X640, X710, X475, X630, X660, X700, X800, X900. |
09-13-2008, 13:59 | #1 (permalink) |
Banned Join Date: Jul 2008
Member: 812768 Status: Offline Thanks Meter: 1 | Samsung distorted screen then reboots after flash i choose, differences only choose firmware E900XEFJ1 baud rate tried 115200 and 921600 choose customer T: Universal USB Please help, i need my phone |
09-13-2008, 15:31 | #2 (permalink) |
Member: 812768 Status: Offline Thanks Meter: 1 | its ok i found out how to do it after many flashes... i downloaded the original optiflash, not a specific model optiflash (eg. NOT e900 optiflash) then followed these instructions: 1. Install the USB driver for the cable. 2. Launch Optiflash and click on "Options > Settings > Generic" - Select "Customer T: Customer T: D830/D840/E900 (USB)" - Set "Flash Erase Passes" to "1" - Set "Operation Passes" to "Default" - Uncheck all checkboxes except "Differences Only", "Erase All Unused Regions" and "Extended Protection". 3. Select the tab "Read" and make sure that under the "Read Ranges" there is "0x20000000 - 0x21ffffff" because if it isn't, it may wipe your imei. You can check your imei by typing *#06#. 4. Select the tab "Flash and Verify" - Browse to and select your *.s3 firmware file 5. Select the tab "Default Contents" If you have a file *.cts with the firmware *.s3: - Select radio button "S-Record with Contents" - Browse to and select your *.cts file If you do not have the file *.cts: - Click on "S-Record only" - Click "OK" 6. Connect USB to device 7. Remove your SIM, your microSD card and the battery from the phone which will turn the phone off. Leave the USB cable in. 8. Whilst holding down the * key on the phone, briefly press the ON button. Your computer will recognise the device as Samsung USB Mobile. 9. Return to Optiflash, click on "Options > Settings > COM Port" - Select the COM port your phone uses. If you are not sure, you can find out by: Control Panel > System > Hardware > Device Manager > Ports (COM and LTP). - Select "921600". - In Second COM Port select "none" - Click "OK" Lastly, click "Flash" The flash procedure takes approximately 15 minutes (on mine it was 27 mins) and will be finished when the message "All is Well" appears above the green progression bar. A full reset should not be necessary once the firmware is upgraded, however, if you want to do it type *2767*3855# then wait one full minute before you restart your phone. To check your existing firmware type *#1234# into your handset. If your phone restarts in a different language follow the language selection process: MENU (left touch button) > SETTINGS (bottom right icon) > PHONE SETTINGS (2nd option) > LANGUAGE (1st option) Hope this helps some people Last edited by vistar86; 09-13-2008 at 15:38. |
The Following User Says Thank You to vistar86 For This Useful Post: |
N95 vibrate then cutoff after flash [SOLVED - Thanks Crazy Ratata] | jus_chillin | Cyclonebox | 19 | 03-29-2010 11:57 |
Samsung T809 reboots after flash to 820 help please | kodack | Samsung Flashers, Software, Firmware. | 1 | 06-29-2006 18:58 |
Sony ericsson T610 reboot after flashing | .::Zafar Communication::. | Twisterflasher | 5 | 01-28-2005 17:40 |
3330 auto reboot after flash | mp3hot | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 03-25-2003 18:12 |
phone keeps rebooting after flashing | jbes | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 09-30-2002 21:17 |
