Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Trident/AGERE Platform
Trident/AGERE Platform C200, C210, C225, C230, D100, D410, D415, D418, D428, D520, D825, D710, D720, D730, E105, E300, E310, E315, E316, E318, E360, E400, E530, E600, E608, E610, E620, E650, E658, E710, E715, E718,E720, E728, E750, E770, E810, E818, E850, E860, E880, Q100, Q105, Q200, Q300, Q400, Q605, I700, N700, P100, P108, P400, P408, P710, P718, P720, P730, P738, P777, S100, S105, S108, S200,S 208,S300, S300m, S341, S342, S400, S400i, S410i, S500i, V100, V200, V205, V208, VE888 , X105, X120, X130, X140, X150, X200, X400, X408, X426, X430, X438, X450, X458, X480, X610, X630, X640, X710, X475, X630, X660, X700, X800, X900.
Old 07-21-2004, 14:17   #1 (permalink)
Member: 3508
Thanks Meter: 71
X450 - optiflash error (ERR_FLASHTYPE)
Hi!
I'm trying to flash x450, but optiflash give me this error ERR_FLASHTYPE, so what is the problem, I tried all optiflash versions and all give me the same error! I can't read or write flash! Phone is OK but I must change language in it!
Can it be some new flash chip or...!?
Here is optiflash log:
I E183 15:06:06 SendFile=c:\12345 GSM\Unlocking\Samsung\Flashes\Optiflash4.1.1 experimental\Optiflash3.6\Models\fl_sceptre3_nice_ std_v24.sre, Mode=3
I E184 15:06:06 Power on mobile !
I E185 15:06:07 TalkToBootLoader (using COM1)
I E186 15:06:07 Talking to passive bootloader
I E187 15:06:07 Bootloader V2.2 using UART1
I E188 15:06:07 ROM mask ID: 0x00004546 ( EF)
I E189 15:06:07 ID register: 0x000203bd (Trident II)
I E190 15:06:07 Bootloader type: 3 (0)
I E191 15:06:07 Max. transfer size: 2176 bytes
I E192 15:06:07 Adjusted max. transfer size to: 1920 bytes
I E193 15:06:07 Data to transfer: 18836 bytes in 1 region(s)
I E194 15:06:07 Send: 0x00000000 - 0x0000077f (=1920)
I E195 15:06:07 Send: 0x00000780 - 0x00000eff (=1920)
I E196 15:06:08 Send: 0x00000f00 - 0x0000167f (=1920)
I E197 15:06:08 Send: 0x00001680 - 0x00001dff (=1920)
I E198 15:06:08 Send: 0x00001e00 - 0x0000257f (=1920)
I E199 15:06:08 Send: 0x00002580 - 0x00002cff (=1920)
I E200 15:06:08 Send: 0x00002d00 - 0x0000347f (=1920)
I E201 15:06:09 Send: 0x00003480 - 0x00003bff (=1920)
I E202 15:06:09 Send: 0x00003c00 - 0x0000437f (=1920)
I E203 15:06:09 Send: 0x00004380 - 0x00004993 (=1556)
I E204 15:06:09 TalkToBootloader: OK
I E205 15:06:09 Duration: 2s
I E206 15:06:09 SendFile=C:\12345 GSM\Unlocking\Samsung\Flashes\X450\X450XEDD2.s3, Mode=0
I E207 15:06:09 TalkToFlashloader (using COM1)
I E208 15:06:09 Switching over to flash loader
I E209 15:06:09 COM1 is connected to UART1
I E210 15:06:09 Sync'ing to flash loader
I E211 15:06:09 Sync'ing
I E212 15:06:09 sync'ed
I E213 15:06:09 Querying device information
I E214 15:06:09 MSG: 0x0[0x800000] 0xe0003024=0x10000c 0xe0003000=0x11054
I E215 15:06:09 MSG: 0x0[0x0] 0xe000302c=0x0 0xe0003008=0xc00f
I E216 15:06:09 MSG: 0x800000[0x800000] 0xe0003030=0x10800c 0xe000300c=0x1054
I E217 15:06:09 MSG: 0x0[0x0] 0xe0003034=0x0 0xe0003010=0xc00f
I E218 15:06:09 MSG: 0x0[0x0] 0xe0003038=0x0 0xe0003014=0xc00f
I E219 15:06:09 MSG: 0x0[0x0] 0xe000303c=0x0 0xe0003018=0xc00f
I E220 15:06:09 MSG: 0x0[0x0] 0xe0003040=0x0 0xe000301c=0xc00f
I E221 15:06:09 MSG: 0xe0003020=0xa2
I E222 15:06:09 Flash loader version: V5.08
I E223 15:06:09 Max. TX/RX size: 65536/32768
I E224 15:06:09 Mobile transfer speeds: 57600, 115200, 230400, 460800
I E225 15:06:09 IDs returned by detection: 2
I E226 15:06:09 AMD:0xb0/0x00b10000, Intel:0xb0/0x00b10000
I E227 15:06:09 AMD:0x03/0xe3030000, Intel:0x03/0xe3030000
I E228 15:06:09 Detected flash chips: 2
I E229 15:06:09 Unknown Flash Chip: 0xb0/0x00b10000, 0xb0/0x00b10000
I E230 15:06:09 SendFile: 4 (ERR_FLASHTYPE)
I E231 15:06:09 ReLoad: 4 (ERR_FLASHTYPE)
I E232 15:06:09 Error code: ERR_FLASHTYPE
E E233 15:06:09 Sorry, an error has occured ! (ERR_FLASHTYPE)
I E234 15:06:09 ThreadProtocol finished
I E235 15:06:09 ThreadProtocol: 4
I E236 15:06:09 ThreadGUI finished
Old 07-21-2004, 15:17   #2 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
Thanks Meter: 25,395
Use optiflash 3.6 fixed from http://81.196.32.51:81 with "X430,X450 new" settings.
Optiflash 3.6 work on win XP soo USE WIN XP
Old 07-21-2004, 15:51   #3 (permalink)
Member: 3508
Thanks Meter: 71
With thisone works ok!!
Thanks mate!!
Regards!
Old 07-21-2004, 16:06   #4 (permalink)
gsmrepair1's Avatar
Member: 66871
Thanks Meter: 34
not work
I E1 17:03:37 OptiFlash 3.6.0.6 started!
I E2 17:03:37 Preferences section [Samsung] selected!
I E3 17:03:50 ThreadGUI started
I E4 17:03:50 ThreadProtocol started
I E5 17:03:50 Boot loader protocol type: passive
I E6 17:03:50 Flash loader: D:\Dokumente und Einstellungen\8\Desktop\Optiflash3.6\Models\SGH-X450.sre
I E7 17:03:50 Opened COM1 at 115200 baud
I E8 17:03:50 PC transfer speeds (COM1): 57600 115200
I E9 17:03:50 Loading S-record file: <D:\Dokumente und Einstellungen\8\Desktop\Optiflash3.6\Models\SGH-X450.sre>, RangeCheck=Off
I E10 17:03:51 There is 1 memory region in the S-record file:
I E11 17:03:51 1: 0x00000000 - 0x00004457 = 17496 Bytes
I E12 17:03:51 Loading S-record file: <D:\Dokumente und Einstellungen\8\Desktop\gsm\siemens flash\X450XEDF1-RUS\X450XEDF1.s3>, RangeCheck=On
I E13 17:03:52 There are 3 memory regions in the S-record file:
I E14 17:03:52 1: 0x00000000 - 0x00000607 = 1544 Bytes
I E15 17:03:52 2: 0x00004000 - 0x00006eaf = 11952 Bytes
I E16 17:03:52 3: 0x00010000 - 0x00b91ecf = 12066512 Bytes
I E17 17:03:52 SendFile=D:\Dokumente und Einstellungen\8\Desktop\Optiflash3.6\Models\SGH-X450.sre, Mode=3
I E18 17:03:52 Hit On/Off Botton
I E19 17:03:52 TalkToBootloader (using COM1)
I E20 17:03:52 Talking to passive bootloader
I E21 17:03:52 Bootloader V2.2 using UART0
I E22 17:03:52 ROM mask ID: 0x00004546 ( EF)
I E23 17:03:52 ID register: 0x000603bd (Trident II)
I E24 17:03:52 Bootloader type: 3
I E25 17:03:52 Max. transfer size: 2176 bytes
I E26 17:03:52 Send: 0x00000000 - 0x000007ff (=2048)
I E27 17:03:53 Send: 0x00000800 - 0x00000fff (=2048)
I E28 17:03:53 Send: 0x00001000 - 0x000017ff (=2048)
I E29 17:03:53 Send: 0x00001800 - 0x00001fff (=2048)
I E30 17:03:53 Send: 0x00002000 - 0x000027ff (=2048)
I E31 17:03:53 Send: 0x00002800 - 0x00002fff (=2048)
I E32 17:03:54 Send: 0x00003000 - 0x000037ff (=2048)
I E33 17:03:54 Send: 0x00003800 - 0x00003fff (=2048)
I E34 17:03:54 Send: 0x00004000 - 0x00004457 (=1112)
I E35 17:03:54 TalkToBootloader: OK
I E36 17:03:54 Duration: 1s
I E37 17:03:54 SendFile=D:\Dokumente und Einstellungen\8\Desktop\gsm\siemens flash\X450XEDF1-RUS\X450XEDF1.s3, Mode=0
I E38 17:03:54 TalkToFlashloader (using COM1)
I E39 17:03:54 Switching over to flash loader
I E40 17:04:24 SendFile: 5 (ERR_PROTOCOL)
I E41 17:04:24 ReLoad: 5 (ERR_PROTOCOL)
I E42 17:04:24 Error code: ERR_PROTOCOL
E E43 17:04:24 Sorry, an error has occured ! (ERR_PROTOCOL)
I E44 17:04:24 ThreadProtocol finished
I E45 17:04:24 ThreadProtocol: 5
I E46 17:04:24 ThreadGUI finished
Old 07-21-2004, 16:43   #5 (permalink)
Member: 3508
Thanks Meter: 71
Does your phone works OK!?
Is you cable OK!?
I use original samsung cable for V200!
This Optiflash works 1000% with x450, because I just flashed one phone with it under WinXP and everything is OK!!
Old 07-22-2004, 08:51   #6 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
Originally Posted by gsmrepair1
not work
How many times i must repeat? Select "SGH-X430 X450 new" on optiflash 3.6 fixed & will work 100%
Old 07-22-2004, 21:48   #7 (permalink)
Stoyan's Avatar
Member: 14868
Thanks Meter: 44
Hey Elco do not be angry
just tell them to be more patient and to use their brains.
I had the same problem and tested all 5 types of Opiflash files and configs until reach the result.
SO EVERYBODY - BE MORE PATIENT and do not post on all your troubles until you didnot test everything that is posible (do not cry like a child)
So everybody GOOD LUCK in flashing.
WBR Stoyan
Old 12-11-2004, 17:03   #8 (permalink)
dorinheimbach's Avatar
Member: 41169
link does not work
pleaseeeeeeeeeeeeee
Old 12-14-2004, 08:56   #9 (permalink)
Member: 3508
Thanks Meter: 71
Originally Posted by dorinheimbach
link does not work
pleaseeeeeeeeeeeeee
Mail me on [email protected]!
Regards!
Old 01-07-2005, 16:42   #10 (permalink)
Member: 2770
Thanks Meter: 3
The above link does not working. I also has big problems with flashing a X450 and solved problem using Optiflash 3.6.0.12 from:http://www.unlock.ru/modules/mydownl...wcat.php?cid=4.
Old 01-08-2005, 10:45   #11 (permalink)
Burnt Cobba's Avatar
Member: 11325
Thanks Meter: 266
selecting P400 on optiflash 3.0.6 solves the problem too
br
al
Old 02-09-2005, 15:37   #12 (permalink)
Member: 58038
Sonork: 100.33033
Thanks Meter: 2
yes the new-x430,x450 use p400 loader .u can see it in platform file .. buth exist new x450 i use optiflash 4,51 and allways get
ERR_flashtype new ver opti flash ??? or some about the problem ?
Old 02-24-2005, 13:55   #13 (permalink)
Member: 70460
Thanks Meter: 10
optiflash 3.0.6 solves problem wich new X450 ERR_FLASH
SELECT model P400
THX Burnt Cobba!!!
ikron!!
Old 02-24-2005, 17:56   #14 (permalink)
Member: 58728
Thanks Meter: 4
You must to choose P400 boot loader, it'll work 100000000000000000000000%
Old 04-05-2005, 11:54   #15 (permalink)
ACE_UK's Avatar
Member: 3267
Thanks Meter: 2
any more links for optiflash 3.6 fixed ? above link not working ;(
[IMG] code is Off
X450 Flash Error What This? denard HWK 2 04-02-2008 07:43
X450 flash error at 68% nidal01 UFS2 + UFS3-Tornadoflasher 7 11-21-2006 08:03
x450 flash error =CostyGSM= NSPRO 4 10-13-2006 16:29
x450 flashing error DanV SYSOL Platform 1 05-20-2005 10:21
x450 optiflash help swand Trident/AGERE Platform 0 01-31-2005 13:55
Page generated in 0.37990 seconds with 10 queries
