SYSOL Platform S500, S508, D488, E100, E330, E335, E338, E630, E635, E638, E700, E708, E800, E808, E820, P300, X100, X108, X460, X468, X490, X495, X600, X608, X620, X628, X640. |
11-30-2003, 22:04 | #1 (permalink) |
Junior Member Join Date: Nov 2003
Member: 44797 Status: Offline Thanks Meter: 0 | Samsung E715 unlocked Successfully!!! As we all know the code doesn't work on the E715; so here what you do: 1. Use the cable for the v205 to unlock it 2. Use the program samsung_v2xx-s1xx.rar (if you do a search for it on google you should find it) v2xx-s1xx unlocker by juliette simply power on your phone with no SIM, press unlock; Take out the battery and then put it back in after 10 secs. Walaah! Your phone should now be unlocked Don't ask me where I got the cable from -- we all know the anwser EBAY and yes it even works with Easy GPRS. 100% If you have any questions, i will be more than willing to help you, since nobody could be of any help to me. :P |
11-30-2003, 22:37 | #2 (permalink) |
Freak Poster Join Date: Sep 2003 Age: 55
Member: 39023 Status: Offline Thanks Meter: 0 | her is the link for julliet soft http://www.movilcom.org/liber_samsung_v200_s100.asp |
11-30-2003, 22:38 | #3 (permalink) |
Member: 39023 Status: Offline Thanks Meter: 0 | her the cable seller http://www.factory-2-you.de/shop/pro...CVK1&pid=26755 |
12-19-2003, 20:27 | #9 (permalink) |
No Life Poster Join Date: Oct 2002 Location: Alex,EGYPT. Age: 51
Member: 16449 Status: Offline Thanks Meter: 39 | hi guys... I have two phones E715 and successfully unlocked 1st one::::: unlocked 100% without any probleme by using orignal cabul for V200 by moved the key on D\L without sim card and the phone was powered on.... 2nd one:::: successfully unlocked by the same method butttttttttttt when I power the phone off and return power it on phone told me... ((phone unlocked contact ur service)) the way to reunlock it again... and same same probleme when I power off the phone then power on..((phone unlocked contact ur service)) can any body replay me how we can fix it?? note: I used many sim cards all time and the same probleme thanx for time Galaxy |
02-25-2004, 10:12 | #10 (permalink) |
Junior Member Join Date: Oct 2003 Location: UK Age: 40
Member: 41606 Status: Offline Thanks Meter: 0 | Hi, I have seen a website trying to charge me money for an unlock "code" for this phone (Samsung E715). Is this possible, is there an unlock code out there? If so, does anyone know what it is WBR |
02-25-2004, 14:14 | #11 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | Very Easy unlocking of E700 Use UST 5.6 cracked select P4xx & unlock !!! Use t100 cable for taht very Easy Regards Aamir Zia |
03-05-2004, 20:17 | #12 (permalink) |
No Life Poster Join Date: Jan 2004 Location: montenegro Age: 45
Member: 51104 Status: Offline Thanks Meter: 6 | unlock e715 ------------------------------------------------------------------------ Turn off your phone, put in a SIM of a provider that it is not locked to, and turn it back on. 2. At the wrong card message, type *#9998*3323#. A message will pop up telling you to press exit, so hit the right softkey. Choose Malloc Fail. Your phone will reboot and your SIM will work. 3. Type *0141# and then hit call. This will give you a message saying your phone is personalized. 4. Power down your phone and insert a SIM card other than the one that is in it. Power back up your phone. 5. At the SIM code prompt type 00000000, that is 8 zeroes. pozdrav |
03-13-2004, 13:18 | #13 (permalink) | |
Insane Poster Join Date: May 2003 Location: ALBANIA
Member: 29348 Status: Offline Thanks Meter: 0 | Quote:
03-13-2004, 14:21 | #14 (permalink) | |
Freak Poster Join Date: Oct 2000 Location: Romania
Member: 2375 Status: Offline Thanks Meter: 4 | Quote:
Samsung A801 Unlock Success!!! | mint centre | Easy-Unlocker | 1 | 08-05-2008 01:25 |
<< Samsung G600 unlock success : NS Pro >> | zeel_zeel | NSPRO | 0 | 05-13-2008 14:39 |
samsung t209 unlock successful | bhogpurmail | UST Pro II | 4 | 05-18-2007 04:54 |
need samsung e715 unlock code / factory reset code.. | lemmiwinks | Trident/AGERE Platform | 0 | 02-23-2007 06:52 |
Samsung Z500 unlock success!!! | reefer45 | QUALCOMM Models (3G) | 2 | 06-13-2005 16:37 |
