Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
01-08-2013, 14:50 | #32 (permalink) | |
Freak Poster Join Date: Jun 2009 Location: Turkey
Member: 1058593 Status: Offline Sonork: 100.1625725 Thanks Meter: 433 | Quote:
hi bro try all omap 4430 u can see 3 4 project 1 will work if sofware problem try and write result | |
01-08-2013, 20:49 | #33 (permalink) |
Junior Member Join Date: Mar 2006
Member: 239082 Status: Offline Thanks Meter: 0 | Hello Can you help me with P5100 (Galaxy Tab 2) also/ I've tried with attached tool but i've received error (omap4430hs_espresso_1000MHZ.bat): Code: п OMAPFlash v4.16 (Nov 4 2011) п -v п Entering parameter file:Targets\Projects\espresso\omap4430hs_1000MHZ.txt at li ne: 1 п -omap 4 п -t 36000 п -p OMAP4430_1GHZ_8G_HS п -2 п chip_download EMMC Targets\Projects\espresso\MLO п chip_download EMMC Targets\Projects\espresso\Sbl.bin п command cold_sw_reset п Leaving parameter file:Targets\Projects\espresso\omap4430hs_1000MHZ.txt п @Targets\Projects\espresso\omap4430hs_1000MHZ.txt п Looking for device (omap usb) п Please turn on device п Waiting for device (omap usb) п Found device (omap usb) п Requesting ASIC id п AsicId items 05 п AsicId id 01 05 01 44 30 07 04 п AsicId secure_mode 13 02 01 00 п AsicId public_id 12 15 01 F2 8C F5 50 1D C8 E6 8D BA F0 DD CB 95 CA 73 75 54 92 D2 71 п AsicId root_key_hash 14 21 01 B5 85 AC F1 DD 15 B0 6A 74 81 3B FD DD 6E CD 64 22 7C E4 C9 06 58 C6 5B 4C 53 AC 22 9B 4C 6D C0 п AsicId checksum 15 09 01 9C 66 9A D9 68 2A DC CF п Searching 2nd for: OMAP4430_1GHZ_8G_HS 443007 04 HS п Loading second file Targets\2nd-Downloaders\dnld_startup_omap4_hs_4g_es2.s2.si gned.2nd.hs.1GHZ п Entering parameter file:omapflash2nd.txt at line: 46 п -pheriphalboot_reopen п Reading board configuration file Targets\Configurations\configuration_omap4430 _8g_ver416.txt п Reading definition file .\Targets\Definitions\definitions_omap4.txt п -board_config Targets\Configurations\configuration_omap4430_8g_ver416.txt п Leaving parameter file:omapflash2nd.txt п Sending size of second file (0x000079B0 bytes) п Transferring second file to target (0x79B0 bytes) п Closing boot connection п Waiting for device (omap usb) п Found device (omap usb) п Waiting for 2nd п Error: (Unknown status message '??????-t??????-t?J?,????H 6t??????,t?????????? -tX?????3t???X??????-t??,t????P.J?????H 6tH 6t?q1tH 6t?q1t???? ???|?,t?E6t,???T? ,t????h???8q1tH 6t/q1t,M?,??1t?????q1t????<?????????????3t???X????/q1t?q1t??2tH 6t?????????????????{??H 6t????????H 6tL???????????') during peripheral boot (wai ting for 2nd) Press any key to continue . . . Code: п OMAPFlash v4.15 (Aug 12 2011) п -v п Entering parameter file:Targets\Projects\espresso\omap4430hs_1200MHZ.txt at li ne: 1 п -omap 4 п -t 36000 п -p OMAP4430_8G_HS п -2 п chip_download EMMC Targets\Projects\espresso\MLO.hs п chip_download EMMC Targets\Projects\espresso\Sbl.bin п command cold_sw_reset п Leaving parameter file:Targets\Projects\espresso\omap4430hs_1200MHZ.txt п @Targets\Projects\espresso\omap4430hs_1200MHZ.txt п Looking for device (omap usb) п Please turn on device п Waiting for device (omap usb) п Found device (omap usb) п Requesting ASIC id п AsicId items 05 п AsicId id 01 05 01 44 30 07 04 п AsicId secure_mode 13 02 01 00 п AsicId public_id 12 15 01 F2 8C F5 50 1D C8 E6 8D BA F0 DD CB 95 CA 73 75 54 92 D2 71 п AsicId root_key_hash 14 21 01 B5 85 AC F1 DD 15 B0 6A 74 81 3B FD DD 6E CD 64 22 7C E4 C9 06 58 C6 5B 4C 53 AC 22 9B 4C 6D C0 п AsicId checksum 15 09 01 9C 66 9A D9 68 2A DC CF п Searching 2nd for: OMAP4430_8G_HS 443007 04 HS п Loading second file Targets\2nd-Downloaders\dnld_startup_omap4_hs_4g_es2.s2.si gned.2nd.hs п Entering parameter file:omapflash2nd.txt at line: 45 п -pheriphalboot_reopen п Reading board configuration file Targets\Configurations\configuration_omap4430 _8g.txt п Reading definition file .\targets\definitions\definitions_omap4.txt п -board_config Targets\Configurations\configuration_omap4430_8g.txt п Leaving parameter file:omapflash2nd.txt п Sending size of second file (0x00006E60 bytes) п Transferring second file to target (0x6E60 bytes) п Closing boot connection п Waiting for device (omap usb) п Found device (omap usb) п Waiting for 2nd п Unknown status message '?3??' during peripheral boot (waiting for 2nd) Press any key to continue . . . |
01-12-2013, 22:18 | #34 (permalink) | |
Insane Poster Join Date: Sep 2005 Location: Uzbekistan Age: 39
Member: 177238 Status: Offline Thanks Meter: 11 | Quote:
01-14-2013, 14:09 | #36 (permalink) | |
No Life Poster Join Date: Oct 2005
Member: 194907 Status: Offline Thanks Meter: 114 | Quote:
Sdcard mode Copy binery from sdcard Copy binery emmc Sdcard download failed | |
01-20-2013, 07:08 | #41 (permalink) |
Major Poster Join Date: May 2011 Location: Russia,Chechen republic,Grozny Age: 41
Member: 1580337 Status: Offline Thanks Meter: 6 | I do not say that link err, I say that not help this solution, I try all bat's run but they do not help, they all same errors "Waiting for 2nd" untill I reconnect device then same errors like "Unknown status message '?3??' during peripheral boot (waiting for 2nd)". Any solution and why SPT BOX do not repair this device (P3100) |
01-20-2013, 21:42 | #42 (permalink) |
Member: 239082 Status: Offline Thanks Meter: 0 | Kiberpank, unfortunatelly no solution found to unbrick P5100. Here is posted alternative way to repait p5100 with OMAPFlash - [DISCUSSION] Unbrick using OMAP flasher - xda-developers - but this method doesn't checked yet, so you can check with your tab and post report ) |
01-21-2013, 12:35 | #43 (permalink) |
Freak Poster Join Date: Feb 2006
Member: 231850 Status: Offline Thanks Meter: 17 | п OMAPFlash v4.15 (Aug 12 2011) п Waiting for device (omap usb) п Waiting for device (fastboot)In Fastboot Mode.. п Sending 'recovery' (5680 KB) п Operation FAILED () п Elapsed time: 0:11.109 For 3110 still not working . |
02-09-2013, 15:02 | #45 (permalink) |
Freak Poster Join Date: May 2001 Location: india Age: 58
Member: 4798 Status: Offline Sonork: 100.1617239 Thanks Meter: 5 | what is this jig...do we have to assemble anything...or is it ok if power is supplied...SOMEONE pl through LIGHT..ON THIS..THANKS TO ONE & ALL |
