Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
12-13-2018, 05:48 | #1 (permalink) |
Junior Member Join Date: Jun 2018
Member: 2844140 Status: Offline Thanks Meter: 2 | How To Use Odin To Flash Stock ROM On Any Samsung Galaxy Devices Are you looking forward to flashing your Samsung device due to any reason? Downgrade or upgrade? Whatever the intention is no matter with Samsung Odin flash tool. You can use Odin for any flashing purposes without a doubt since it is being used in Samsung service centers. Samsung Odin can be used to,
How To Download Samsung Odin Flash Tool Samsung Odin is a Windows-based application and you can download it On Windows operating system. The latest version of Odin is v3.13.1 and Odin 3.13.1 download requires Windows 7,8 or 10. The specialty of the latest Odin version is its compatibility to flash latest Oreo firmware which comes in lz4. lz4 focuses on compression and decompression speed. If you are trying to flash the latest Oreo firmware be informed that the extraction method of the latest Oreo firmware vary and it cannot be open using DiskInternals Linux Reader on Windows. Pre-Requirments
Preparation To Download Samsung Odin
How To Download Samsung Odin Flash Tool And Flash A Stock ROM Step 01 - Download Samsung Odin according to the Android version you are using Step 02 - Download and Install Samsung device drivers on your computer according to your device. After installing restart your computer to apply them Step 03 - Download the accurate stock firmware file in the .tar extension Step 04 - Enable download mode in your device to be able to make a bridge between computer and the smartphone Step 05 - Connect your handset using a USB cable and run Odin application Step 06 - There you can find some buttons with codes. Click one by one and load relevant file according to the codes Reference: BL Button - BootLoader file (File name starts with "BL") Step 07 - Now, Press "Start" and it will start the flashing process Step 08 - Progress of lashing process will be displayed via progress bar near the ID: COM area Step 08 - Press "Reset" button on the ID: COM area when the process is done Step 08 - Finally, your device will restart and you can have the new firmware on your device Note: This is the general process to flash Stock ROM via Samsung Odin. The process may vary based on Stock ROM, modem file etc. |
