GT-i9505 stuck on logo with recovery booting i have there one samsung i9505 nd i flash near about 10 time in odin flashing is all done but after restart its stuck on samsung logo and in corner recovery booting if somebody have solution just post here thanx:eek: |
i think no body have solution :confused: |
I also have 2 pcs same problem. I tried everything in software n repaired boot with riff box but every thing success but same issue. I am going to try hardware n reply |
I made 2 units in hardware 10000% success. Don't wast time is software |
What is the solution for it? Hardware what? |
small tips: check volume + button... try to desolder it. if your phone will power up normally you must replace the switch. |
http://imagizer.imageshack.us/v2/xq90/34/r5re.jpg Heat this red marked aria then phone will start normaly after that flash the phone with 4.4.2. using odin. after software done imei will be blank then rebuild imei number. now job is done |
i have extra mother board demo unit and i take same ic from demo unit and put it on stuck recovery mode mobiler now the phone is dead :( |
I made 2 phones both are working perfectly |
flash with 4.4.2 firmware,last time i face this problem after done |
19505 vibrates and restarts every sec flased different files of ver 4.4.2 even tried 4 files firmware with pit . Able to enter recovery and download mode details in download mode Product code:GT-I9505 current binary:Samsung official system status:Custom Knox Kernel Lock:0x0 Knox warranty Void:0x1 CSB-CONFIG-LSB:0x30 Write Protection: Enable eMMC burst mode:enabled any suggestions Regards Riaz |
Problem solved It was power switch problem Regards Riaz |
1 check battery 2 power swtich 3 try to flash on 4.4 in last check on hardware Enjoy |
i have sam probleme i n my i9505 in download mode Product code:GT-I9505 current binary:Samsung official system status:Custom Knox Kernel Lock:0x0 Knox warranty Void:0x1 CSB-CONFIG-LSB:0x30 Write Protection: Enable eMMC burst mode:enabled pls how solvet it |
First heat, then reassemble phone, then insert battery and turn on the phone? br |
