Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Flashers, Software, Firmware.
Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms.
Old 06-04-2018, 16:50   #46 (permalink)
Member: 2842338
Dear Angelo,
thanks for this support on the cloverview-problem,
I downloaded the tar from here, but after installing xFSTK, i got:
you need an intel SoC driver.
i searched that for win 7 (do you have a recommendation?) and found something here:
(cannot post link )
www magicdriver com ... driver126861-ver_11.0.0.0. h t m l
so after plugin my Tab i got this in device mgr, which looks good:
cannot post link - neither include photos
but it ***** a group "intel Soc" and below a CloverwiewPlus device (and Intel Soc USB driver )
But when i start the xFSTK Downloader, i always have an empty window (Tab connected or not), like this:
cannot post link
Please give me a hint what to do.
I run a freshly installed Win 7 32 Bit system.
kind regards
Old 06-04-2018, 17:23   #47 (permalink)
Member: 2842338
B.T.W. i use the xFSTK 1.5.1 attached in your first post in this thread - whre to get the xFSTK 1.7.0 ?
Old 06-04-2018, 18:17   #48 (permalink)
Member: 2842338
in 1.5.1 i cannot Select device there is no "selection"
whan i try the xfstk-dldr-solo 1.5.1, with 3 file args, i get:
missing WDAPI1100 . dll - install again
Old 07-06-2018, 13:31   #49 (permalink)
Member: 1410502
Sonork: 100.1645892
Thanks Meter: 27
Please help
Originally Posted by angelo cruz View Post
the tool it´s not mine , solution is
yes you can , the tool and procedure are the same files are different .
Use this one that have proper files for gt-p5210 : p5210 boot repair by angelo cruz
ac
i need boot repair file for p5220
Old 07-15-2018, 18:06   #50 (permalink)
Member: 2851261
I have problems with Cloverview and P5210
Thanks to the Members to use xFSTK Downloader 1.7.0 in combination with 5210 Angelo Cruz
but it stops at 5% - Battery to low
i can wait 30minutes and longer, it was the same status
it doesn't breaks
the 5% doesn't changed higher
what can i do?
Akku loading up for more hours mit 2,1mAh-Charger doesn’t work
16:53:52 - XFSTK-STATUS--USBSN:8C52EA262A9BF8A2--BATI: Battery power is too low, charging up ...
16:53:52 - XFSTK-STATUS--USBSN:8C52EA262A9BF8A2--BATI:42415449: Battery voltage: 0x3(0.056545V) The threshold: 0xbf(3.600000V)
16:53:44 - XFSTK-LOG--USBSN:8C52EA262A9BF8A2--GetOpCode
16:53:34 - XFSTK-LOG--USBSN:8C52EA262A9BF8A2--ReadInAck
16:53:26 - XFSTK-LOG--USBSN:8C52EA262A9BF8A2--GetAck
16:53:20 - XFSTK-LOG--USBSN:8C52EA262A9BF8A2--GetAck - RTBD(0x4)
16:53:14 - XFSTK-LOG--USBSN:8C52EA262A9BF8A2--WriteOutPipe DBDS
16:53:08 - XFSTK-LOG--USBSN:8C52EA262A9BF8A2--WriteOutPipe 0
16:53:00 - XFSTK-LOG--USBSN:8C52EA262A9BF8A2--Write --->DBDS
16:52:36 - XFSTK-LOG--USBSN:8C52EA262A9BF8A2--ReadInPipe
thank you forwards
Old 07-25-2018, 13:55   #51 (permalink)
Crazy Poster
Member: 80338
Thanks Meter: 2
For anyone looking for the xFSTK Downloader 1.7.0 version it is here
https://drive.google.com/file/d/0B45...ew?usp=sharing
or just search google for it
https://www.google.co.uk/search?clie...UTF-8&oe=UTF-8
As soon as this version was loaded the program opened up and the relevant details showed up for me to load.
Unfortunately my battery looks goosed! So stops at 5% so now I am going to get a 3.7v charged lion battery out from one of my dead laptop batteries and try connecting it up to see if I can get it going!
Watch this space....
Old 07-12-2019, 10:58   #52 (permalink)
Member: 2907128
Sonork: very unsocial
Thanks Meter: 5
Originally Posted by d'starter View Post
angelo cruz thanks for the solution working 100%
i am excited about the solution, though buffed by the fact that device detection stays a challenge, even when i shuffle different drivers. i've actually installed the clover view to both intelsoc adapters, but failing!
kindly guide me how to get along it.
thanks
Old 08-05-2019, 14:30   #53 (permalink)
Member: 1850202
it doesn't breaks
what can i do?
thank you forwards
I have the same problem that you have. Did you found a solution to this problem?
By replacing the old battery with one that has 3.7v did it work? or did you find another solution?
Old 01-09-2020, 11:33   #54 (permalink)
Member: 971642
Sonork: shami_tahir
Thanks Meter: 2
Hi sir. Thaks u very much you are grate sir
Old 02-20-2020, 01:50   #55 (permalink)
Member: 2268955
Originally Posted by Angelo Cruz View Post
The tool it´s not mine , solution is
Yes you can , the tool and procedure are the same files are different .
Use this one that have proper files for GT-P5210 :
AC
work perfectly thx , very good work
Old 04-06-2020, 18:57   #56 (permalink)
Crazy Poster
Member: 2925718
Sonork: 100.1683235
Thanks Meter: 16
hi hellow my [email protected]@@@n try xfstk v1.7.0 it is working successfull#############
Old 04-19-2020, 15:10   #57 (permalink)
Member: 2885667
Thanks Meter: 36
i hope it will work.
Old 01-13-2021, 20:01   #58 (permalink)
nykocam's Avatar
Member: 67494
Thanks Meter: 71
win 7/64 xFSTK Downloader all version all empty page,what i can do?
isocusb drivers always error installing....need a good package for win 7/64,thanks
Old 01-13-2021, 20:02   #59 (permalink)
nykocam's Avatar
Member: 67494
Thanks Meter: 71
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.20290 seconds with 8 queries
