Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Flashers, Software, Firmware.
Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms.
Old 08-26-2015, 07:32   #1 (permalink)
Member: 1007497
Sonork: explore_m25
Thanks Meter: 8
samsung sm-t210 pattern infurtunate
Samsung SM-T210 pattern infurtunate
from other shop but they did not succeed the lady want only to format.. she has only 300 pesos for repair.. then i agreed
TRY ko magic finger pwr + Up vol + menu button not work 2nd try same
itry to look a sulotion to my friend google.com heheh then i found a other solution .. need to connect the usb micro
try again pwr. + up vol + menu + usb micro then .. miracle succeed but the problem it would not go to wipe data/ factory .... so that again the problem
so the solution you must go to wife cache( highlight ) then press pwr + up button together ... then it must go to formating that's all
hope can resolve to others... thanks here the picture
Page generated in 0.14343 seconds with 8 queries
