Help Samsung S5360 my samsung galaxy y always restarting on opening screen how to fix this ? |
not sir. when i open my phone always Samsung screen after that restart again back to logo. have solution of this ? |
i dont know how to do frimware you have file ? |
try to flash your phone via odin..... try to search in this forum there are lots of thread i think... |
http://fa-j.com/upload/uploads/jam-0b57ddf4bf831.png download firmware from this link http://forum.gsmhosting.com/vbb/f200...-file-1712757/ Download odin 1.85 press home + volume down + power and after screen appear press volume up |
samsung 5360 restart Quote:
only power key change 100% set ok my 3pc set is ok |
Fix Steps: First Method: - Remove your SIM card again from your device. - Try to Hard Reset your device, Then test it again with SIM card inside. Second Method: - Try to Flash your device again, But with another firmware version, Or use another source to get the firmware files from. Third Method: - In case the above two methods don't solve the restart problem, Then you should get a full firmware package (Boot + Modem + PDA + CSC + Pit) and flash the device again. - After flashing test the device again with SIM card inside. |
Firmware Update Steps: - Run Samsung S5360 Galaxy Y Downloader. S5360_Downloader - Download - 4shared - Check This Options: Re-Partition, Auto Reboot, F.Reset Time ( Re-Partition if you have 3 files ). - For PIT file select: totoro_0623.pit - For BOOTLOADER select: DefaultCalDataWithBoot_S5360xxxxx_REV05.tar.md5 - For PDA select: PDA_S5360xxxxx_REV05.tar.md5 - For PHONE select: MODEM_S5360xxxxx_REV05.tar.md5 - For CSC select: GT-S5360-MULTI-CSC-Oxxxxx.tar.md5 - Put the phone into Download Mode: Volume Down + Home + Power Key and connect USB to phone. - After the Program detect the phone Click Start button and wait. - When the Update complete the phone will be restarted. - Do Full reset by this code: *2767*3855#. S5360 Firmwares: Android 2.3.6: Download S5360XXLA4 S5360TSCLB2 TSC zip |
change the power switch.... that's all. post result.... gud luck..... |
anyway i need to connect my phone to pc ? anyone have link me for cdc abstract |
how i find the .pit file ? |
p.s. |
